Topic: iPod manager (Read 2380652 times) previous topic - next topic
0 Members and 14 Guests are viewing this topic.
[seemingly abandonware] iPod manager
Reply #1376
Any comment on my last post??
And just a question...
When foo_dop writes the album art db, does it read the album art from either the ID3 tag itself or the specified file and store this image in a 'small album art' and 'large album art' format?
Like the two album art sizes you see on the iPod... are these sizes chosen when the album art db is written, or are they simply the original pixel size as was stored? Eg: I store mine in my ID3 tags with the pixel ration 300:300. When the db is written, is this taken and shrunken... or is that further down the line in the firmware department?
Reply #1377
Sync problem solved for me, thanks so much.
Ah good
What was this .dll written in?
I'm not sure I want to know what you mean.... but anyway I can't really help you with hacking the component, sorry.
Also, could you consider an option to autodisconnect the ipod after syncing or or sending playlists to ipod?
Hmm I find it relatively straight forward using safely remove hardware or the component's menu item.
Just some ideas:
-Right click in the system notification area and on the customise notification icons screen set it to always show the safely remove hardware icon.
-Single left click the safely remove hardware icon, not right click etc.
The button doesn't show the icon from the ipod devices panel in columns ui
Well that's just an icon of an iPod, it doesn't indicate the action of synchronisation so much (do you want all the commands to have the same icon? ) If you like it so much you can extract it with some resource extracting program and select it manually, but designing icons for all the commands is slightly time-consuming..
the button also is not able to launch sync with ipod.  Am I doing something wrong here?
If you want to use the context command, you need to select a context, have another look.
Regarding artwork, I think I read it somewhere that this isn't available, but is there a way to send embedded tagged artwork to the ipod thu foo_dop?
Just enable the use of the foobar2000 artwork reader and it will read embedded artwork.
Thanks for your reply. The problem is that I can't access a screen in which the tags are visible and selectable. The only way that I'm aware of to view the iPod database (as is) using foo_dop is to use the Manage Contents window, and you can't do any tag operations in that window. (Additionally, the file order is different than the iPod Media Library tab in fb2k's main window.)
But then are you saying the files on the iPod and computer lost their tags but the iPod database is OK (?) I am not sure how such a thing would happen, but there is no way to export the actual contents of the database using the component unfortunately.
Are you sure though no tags show up if you use "Load library"? I mean the component would have set the metadata in the database from that in the tags which means one of two things:
-you modified the tags of the files directly on the iPod
-the problem is not due to a change in the tags but some change in reading them
-or there is some other iPod app or something involved
You may be able to find some utils to export the database to XML or smth if you do some digging around on Google etc..
That is correct.
Reply #1378
Just some ideas:
Actually, I was trying to save those steps.  iTunes added the same function where it automatically disconnects the ipod after syncing because you typically are done after a sync and want to get moving on.
BTW, got the sync button working, thanks.
Reply #1379
Just a quick question: When sending files to the ipod and it says how many files are remaining i.e "16 remaining", why does it change from numeric to words when 10 and below? It just looks a little strange.
Could you please change this back to digits, or if not, capitalise the first letter of each word.
Reply #1380
Yes, actually, I used Floola's option to back up artwork to my files. (Sorry that I didn't mention it before.) It didn't work correctly and now I'm in this situation. (It was my fault being so hasty to try it without securing a backup.) Indeed, when I reload the database in fb2k, the 284 files' tags are missing; but when I use Manage Contents (or use Floola), things look just fine. Well, if anyone has recommendations for me, I'm open. Many thanks, musicmusic, for your help and for such a great plug-in.
Reply #1381
Can you post the complete log please (in [codebox ] tags)? The crash log will be saved in your foobar2000 profile folder.
[edit] Never mind, I believe I know what the problem is..
I uploaded a new build 0.6.2.3 please try that.
I was experiencing the same crash, and the new build fixed it. Thanks musicmusic.
Reply #1382
I just want to thank you again for a Very nice component!    A lot better than being stuck with iTunes.
I believe this was asked, but I can't remember if it got answered - will this plugin ever support photo and video syncing??
Reply #1383
I found out how to do some more stuff with the iPod touch/iPhone, so I need someone to test
Someone with an iPod touch or iPhone please grab this version, and click the "Run Test" button on the on the mobile devices prefs page. It should popup with loads of random information if I did everything right.
Assuming it works: Please paste this info here (or PM if you prefer). There will be some personal info (serial number, IMEI, ..) please censor those values out.
If it doesn't work, tell me what happens :B
Reply #1384
I ran the new test version and got this:
2:
3:
4:
4:
Reply #1386
Strange, not quite what I wanted :/
I uploaded a new build - slightly more debug output, may give some insight as to why it's not working.
Also check if timing matters, for example try it just after the component recognises the device or just try it a few times.
[edit] uploaded an alternate build to try also, this one will automatically popup with the box after it detects the device.
Reply #1387
I've ran the second version, came up with this:
Ref: 06591638
"ChapterImageSpecs": {
"3005"
"PixelFormat": "4C353535"
"3006"
"3012"
"AssociatedFormat": 2
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
"3005"
"3006"
"3012"
2:
Ref: 06591D18
"ActivationStateAcknowledged": 1
3:
Ref: 06594158
"BatteryCurrentCapacity": 95
4:
Ref: 06592348
"TotalSystemCapacity": 314572800
5:
Ref: 06592348
"Calendars": {
"Calendars": {
"Calendars": {
"Calendars": {
6:
Ref: 06592450
"iPod"
7:
Ref: 0659AFC8
"iPod"
Reply #1388
Aha cool
It didn't display all the data properly because of a typo - can you try this build? Thanks
BTW use [codebox ] tags rather than [code ] ones, saves some space
Reply #1389
Ref: 065E1620
"3005"
"OffsetAlignment": 4096
"Crop": 0
"GammaAdjustment": 2.2000000
"Interlaced": 0
"RenderHeight": 320
"AlignRowBytes": 1
"RenderWidth": 320
"BackColor": "00000000"
"RowBytesAlignment": 16
"FormatId": 3005
"ColorAdjustment": 0
"Sizing": 1
"3006"
"Crop": 0
"Interlaced": 0
"RenderHeight": 55
"AlignRowBytes": 1
"RenderWidth": 55
"BackColor": "FFFFFFFF"
"FormatId": 3006
"Sizing": 1
"3012"
"Crop": 0
"Interlaced": 0
"RenderHeight": 63
"AlignRowBytes": 1
"RenderWidth": 88
"FormatId": 3012
"Sizing": 2
"iPhoneCheckpointVersion": 1
"iTunesStoreCapable": 1
"ConnectedBus": "USB"
"64Bit": 3
"FairPlayID": <unsupported data type>
"RentalsSupported": 1
"BatteryPollInterval": 60
"DBVersion": 3
"VideoCodecs": {
"H.264LC": {
"AAC": {
"AppleDRM": 1
"MaximumBitRate": 256
"MaximumSampleRate": 48000
"LC": {
"Multichannel": 0
"VariableBitRate": 1
"Level": 30
"MinimumWidth": 32
"Profile": "B"
"MaximumResolution": 307200
"MaximumWidth": 640
"ComplexityLevel": 1
"AppleVideoDRM": {
"MaximumEncryptionPercentage": 6.2500000
"MaximumHeight": 480
"MinimumHeight": 32
"MPEG4": {
"AAC": {
"AppleDRM": 1
"LC": {
"Multichannel": 0
"MinimumWidth": 16
"MaximumWidth": 720
"MaximumAverageBitRate": 5000
"Profile-Level-ID": 3
"MaximumHeight": 576
"MinimumHeight": 16
"H.264": {
"AAC": {
"AppleDRM": 1
"LC": {
"Multichannel": 0
"Level": 30
"MinimumWidth": 32
"Profile": "B"
"MaximumPixelsPerSecond": 10368000
"MaximumResolution": 414720
"MaximumWidth": 720
"AppleVideoDRM": {
"MaximumEncryptionPercentage": 12.5000000
"MinimumHeight": 32
"AlbumArt": {
"3005"
"Crop": 0
"Interlaced": 0
"RenderHeight": 320
"AlignRowBytes": 1
"RenderWidth": 320
"FormatId": 3005
"Sizing": 1
"3006"
"Crop": 0
"Interlaced": 0
"RenderHeight": 55
"AlignRowBytes": 1
"ExcludedFormats": 20
"RenderWidth": 55
"FormatId": 3006
"Sizing": 1
"3007"
"Crop": 0
"Interlaced": 0
"RenderHeight": 88
"AlignRowBytes": 1
"RenderWidth": 88
"FormatId": 3007
"Sizing": 2
"3001"
"BottomInset": 1
"Interlaced": 0
"LeftInset": 1
"RightInset": 1
"AlignRowBytes": 1
"Sizing": 1
"RenderHeight": 256
"RenderWidth": 256
"Crop": 0
"TopInset": 1
"FormatId": 3001
"PixelOrder": 1
"3002"
"BottomInset": 1
"Interlaced": 0
"LeftInset": 1
"RightInset": 1
"AlignRowBytes": 1
"Sizing": 1
"RenderHeight": 128
"RenderWidth": 128
"Crop": 0
"TopInset": 1
"FormatId": 3002
"PixelOrder": 1
"3003"
"BottomInset": 1
"Interlaced": 0
"LeftInset": 1
"RightInset": 1
"AlignRowBytes": 1
"Sizing": 1
"RenderHeight": 64
"RenderWidth": 64
"Crop": 0
"TopInset": 1
"FormatId": 3003
"PixelOrder": 1
"FairPlayCertificate": <unsupported data type>
"FairPlayGUID": "154e9c302b118c8a51e90012758c8a8e3d35a485"
"SyncDataClasses": {
"Contacts"
"Calendars"
"Bookmarks"
"Mail Accounts"
"FamilyID": 10001
"AppleDRMVersion": {
"Maximum": 4
"Format": 2
"Minimum": 0
"PodcastsSupported": 1
"AudioCodecs": {
"AAC": {
"AppleDRM": 1
"LC": {
"PerceptualNoiseSubsitution": 1
"Audible": {
"AAC": 1
"Type4": 1
"Type2": 1
"Type3": 1
"Type1": 0
"WAV": {
"MaximumBitDepth": 16
"Multichannel": 0
"Stereo": 1
"Mono": 1
"AppleLossless": {
"AppleDRM": 1
"MaximumBitDepth": 32
"Multichannel": 0
"Stereo": 1
"Mono": 1
"MaximumBitDepthUntruncated": 16
"MP3": {
"MaximumDataRate": 320
"Stereo": 1
"Mono": 1
"AIFF": {
"Multichannel": 0
"Stereo": 1
"Mono": 1
"CustomerRingtones": 1
"MinITunesVersion": "7.4"
"ImageSpecifications": {
"3004"
"Crop": 1
"Interlaced": 0
"RenderHeight": 55
"AlignRowBytes": 1
"RenderWidth": 55
"FormatId": 3004
"3011"
"BorderWidth": 1
"BottomInset": 4
"RenderHeight": 79
"Crop": 1
"Interlaced": 0
"RenderWidth": 79
"AlignRowBytes": 1
"BorderColor": "26000000"
"FormatId": 3011
"RightInset": 4
"3008"
"Crop": 0
"Interlaced": 0
"RenderHeight": 480
"AlignRowBytes": 1
"RenderWidth": 640
"Rotation": 0
"FormatId": 3008
"3009"
"Crop": 0
"Interlaced": 0
"RenderHeight": 120
"AlignRowBytes": 1
"RenderWidth": 160
"Rotation": 0
"FormatId": 3009
"OEMID": 0
2:
Ref: 065E3F20
"TimeZone": "Europe/London"
"SerialNumber": "1B805ENU0JW"
"SomebodySetTimeZone": 1
"DeviceCertificate": <unsupported data type>
"ActivationState": "Activated"
"ProductVersion": "1.1.4"
"WiFiAddress": "00:00:00:00:00:00"
"ProductType": "iPod1,1"
"iTunesHasConnected": 1
"FirmwareVersion": "iBoot-204.3.14"
"DeviceClass": "iPod"
"TimeZoneOffsetFromUTC": 3600.0000000
"UniqueDeviceID": "154e9c302b118c8a51e90012758c8a8e3d35a485"
"SIMStatus": "kCTSIMSupportSIMStatusReady"
"ModelNumber": "MB376"
"ProtocolVersion": "1"
"Uses24HourClock": 1
"SBLockdownEverRegisteredKey": 0
"BuildVersion": "4A102"
"DeviceName": "iPod"
"TrustedHostAttached": 1
"DevicePublicKey": <unsupported data type>
"HostAttached": 1
"TimeIntervalSince1970": 1214851467
3:
Ref: 065E3DF8
"BatteryCurrentCapacity": 100
"BatteryIsCharging": 0
4:
Ref: 065E2348
"VoicemailUsage": 7168
"PhotoUsage": 435407300
"CalendarUsage": 32768
"AmountDataReserved": 36700160
"CameraUsage": 0
"AmountSongsReserved": 52428800
"AmountCameraReserved": 0
"NotesUsage": 0
"AmountCameraAvailable": 0
"MediaCacheUsage": 492
"TotalDataAvailable": 17872216064
"TotalDataCapacity": 32165425152
"TotalDiskCapacity": 32479997952
"AmountDataAvailable": 17783087104
"TotalSystemAvailable": 42475520
5:
Ref: 065E2348
"Calendars": {
"Mail Accounts": {
"ReadOnly": 1
"Bookmarks": {
"Contacts": {
6:
Ref: 065E3F50
"iPod"
7:
Ref: 065E98E8
"iPod"
Reply #1390
Perfect!  Very useful, thanks, this is the missing info I was always looking for.
So it works from the automatic popup box but not from the prefs page? Hmm probably thread related.
Reply #1391
No, the data can be accessed in the preferences menu also. What features are you planning to use this info for? I've noticed that there is a battery indicator.
Reply #1392
OK. But then I'm not quite sure why it didn't work first time then..
Various things:
1. So I don't need to hardcode the artwork formats (for these devices), I can obtain them using this method now. This ensures better compatibility with future devices etc.
2. So you will be able to view some basic info using the Properties command like normal iPods.
3. Battery status.
4. Maybe some other stuff, I don't know yet if this disk usage stuff is of any use.
Reply #1393
Great work on this component so far!
I'm having a bit of trouble sending some flac encoded albums to my ipod touch. For albums of less than 10 tracks, when I send them to the ipod (nero aac encoded) i get an error message saying that the first and last tracks could not be added to the ipod as conversion failed. I can send these tracks individually and they transfer fine. Also albums of 10 tracks or more do not seem to be affected.
Reply #1394
Was that with version 0.6.2.3?
Reply #1395
Yes, since 0.6.2 if I remember correctly.
Reply #1396
Try 0.6.2.3, if it doesn't work please write down the exact error message (screenshot if you like).
Reply #1397
Here is what I get with 0.6.2.3
Screenshot
Reply #1398
Is that embedded cuesheet / chapters? (edit: clearly yes) Maybe that's something to do with it, I'll check..
[edit] I can reproduce, looking into the problem..
Reply #1399
It should be rectified in 0.6.2.4, but please verify. Thanks
