Topic: best codec for CBR 128 kbps encoding? (Read 8544 times) previous topic - next topic
Hi folks, please don't ask me WHY 128 cbr, I just want to know which mp3 encoder is the recommended one for this work... since I heard a few bugs of 3.97b2 in low CBR encoding (like definetly audible artifacts) I doubt on this encoder... or is it nevertheless the best one to choose?
thx 4 answers
FB2K,APE&LAME
If you want to choose from popular encoders then yes, Lame 3.97b2 would be your best bet when compared to the Fraunhoffer encoder (sorry for spelling) that is offered in the free version of Winamp, Windows Media Player, MusicMatch, and iTunes.  I am not sure if listening tests have been conducted on the Helix mp3 encoder which is included with RealPlayer.
You should really, really, really go with -V 5 --vbr-new Lame 3.97b2 if you want a target bitrate of 128kbps.  Then again, your hardware may not support VBR mp3's.  In order to get a better understanding of your situtation, you may want to summarize why you want CBR encoding instead of VBR or even ABR.
just interested in CBR. I know VBR and ABR would be more useful. Stay on my question please. thank you anyway for your answer
FB2K,APE&LAME
[I will try to write my post so that I don't violate T.O.S. 8. It is just hard to answer this type of question without violating the T.O.S.]
My favourite encoder at 128kbps cbr is Helix encoder. Main reasons I think it is better than LAME at 128k cbr: Better pre-echo. Tested mainly on "scooter" sample. Lower low-frequency "sandpaper" distortion. Tested on "Birds" sample and others. Faster. Encodes a 5min. song in 5 seconds.
I think it sounds much like the FastEnc encoder, but it's free.
I mainly encode electronic music, so for other genres the encoder choose could be different.
Again, I'm really just recommending what I'm using and what I think is the best.
J.M.
yes that's right this is a question hard to answer without violating the T.O.S. I'm sorry for that.
FB2K,APE&LAME
thx 4 answers
Did you abx what you heard ?. Either way mp3 isn't great at 128k cbr. 3.97 is the most stable for that bitrate in my tests.
PS - I can't imagine anything not supporting ABR, --abr 128 should be considered. If quality isn't enough then up it to 144~160k
To the O.P. - jmartis raises a good point.  You're not going to hear a huge difference in quality between mp3 encoders at 128 CBR, so perhaps a choice should be made on encoding speed.  Don't know where I saw the encoding speed test results (thinking it was someone from the HA forums that conducted them) but the Helix encoder is PDQ (Gogo is "built for speed" too).  If quality is of paramaount importance then you might want to try some ABX tests with all the available encoders (FhG, Lame, Helix, Gogo).  FYI Helix is available with mediacoder.
Just for the record it appears clear that the O.P. is aware that CBR is inferior to VBR and ABR.  Let's remember that there are indeed valid applications for CBR, including streaming, audio within AVI video container (VBR is non-standard), and predictable file sizes (yes, ABR is predictable too  ).
I've read several places that the AAC encoder is a good choice for making 128 kb/s CBR files.
I have no personal experience with AAC, but it would probably be worth your while to read up on the AAC forum as they did several listening tests at the 128 kb/s range.
JXL
Edit:  Woops, missed the part where he wanted a mp3 encoder
Well I know for sure that I can't stand anything for more than a few seconds that was encoded at 128 k/bits CBR using Blade as the encoder, let alone any other bitrate it encodes at.
I can however put up with properly encoded recent LAME versions to LAME 3.97b2 128 k/bits mp3's (properly meaning someone, or some software like Audacity hasn't disabled Joint-Stereo). I can also put up with more recent (WMP10, etc) FhG Pro 128 k/bit mp3's.
What about FhG mp3senc?
we was young an' full of beans
Take a look on the 128 kbps MP3 collective listening test:
http://www.rjamorim.com/test/mp3-128/results.html
There are strong differences in quality between different encoder - and as usual the difference is more obvious with low bitrate (like 128 kbps). It may be interesting to note that LAME made serious improvement with ABR/CBR since this test (3.97 introduced an adaptive ATH adjustement which increased quality on several samples - tests in the MP3-TECH forum are proving this).
The "FhG" encoder, which one is it? (Fast/mp3enc, the new mp3sEnc (surround), build63i -family, other?)
looks like some bad one if it is beaten by Xing.
J.M.
http://www.rjamorim.com/test/mp3-128/presentation.html
Quality of Fhg "fastenc" encoders is overestimated IMO (and Xing "crapness" was also exagerated - as shown in the results).
If I'm not mistaken, the FastEnc VBR only encodes in plain Stereo. In my testing it seems to be really better in CBR. (just to mention, the "AudioActive" encoder is actually FhG 1.2 build 63i  )
J.M.
J.M.
FastEnc's VBR also encodes in joint stereo, depending on the quality setting.
Appologies.  I assumed that old, crappy encoders aren't under consideration.
Sorry, I should have been clearer here.  My point was that by going with mp3 at 128kbps CBR (instead of a different codec / higher bitrate / VBR) that most of the decision on quality is already made right there.  Yes, formal listening tests (the one you reference is for VBR btw) have revealed the differences in quality between encoders, however I think most would agree that current mp3 encoders at this bitrate are going to sound "decent", though probably not transparent or acceptable to most audiophiles.
So based on the listening test, if we're going strictly for highest quality we'd choose Lame.  Though my personal preference (and hence suggestion) would be to trade a small, possibly imperceivable reduction in quality (keeping in mind that we've already limited ourselves by chosing 128kbps CBR mp3) of a for more appreciable gain in encoding speed.
Mmmhhhh... some encoders are clearly less decent than LAME at this bitrate I would say. Anyway, the question was: what is the best MP3 encoder at CBR 128, and not which is the fastest-but-decent one
LAME is IMO the obvious answer to the original question. For faster encoder, HELIX is maybe as good as fastenc and also faster. Gogo is -according to the same test- a working contender too.
[Opinion]
If I ever need to use cbr 128kbps I will either use
lame 3.93.1 -q 2 -b 128 --nspsytune
or
l3codecp.acm 1.2.0.63
[/Opinion]
The only way to find out which is 'best' is to test a bunch of different encoders, and see which one you like the best.. then use it.
Vorbis-q0-lowpass99
lame3.93.1-q5-V9-k-nspsytune
[Opinion]
or
[/Opinion]
The fhg 1.2 build 63 is buggy (it was mentioned earlier; try to encode ma11short sample, really unlistenable  )
J.M.
guruboolez, how old is this test? which lame version was tested there? why isn't helix tested yet in 128 kbps CBR ?
FB2K,APE&LAME
http://www.rjamorim.com/test/index.html
MP3 at 128kbps
from 2004-01-14 to 2004-02-01
Additional info:
Real (Helix) encoder was tested. The CLI encoder was released 18 months later.
