Topic: Multiformat 48 kbps Listening Test (Read 47046 times) previous topic - next topic
Why not, but will this be as replacement to something else?
I'd rahter see something like atrac3+ if we had to add a new contender. Why? Because it's supported by several portable players (Sony). For a community like HA.org I'd say that hardware support is a more convincing argument.
Unfortunately, atrac3+ supposes SonicStage and a lot of work to get valid samples.
Well, if we use Vorbis, HE-AAC and WMA, there is room for one more contender and this is either Real or ATRAC since I don't know any other codec that performs fair at 48 kbps (MP3 is out, Musepack is out).
Hardware support doesn't play such a high role here since we're testing WMA10+ that has no hardware support ATM.
I'd be interested in Real over ATRAC+
It's said they've made good progress, but I'm so far away from their audience.
IMO 48 kbps are directed more toward streaming application than portable players.
Of course I could be wrong.
I don't know much about Real, so don't laugh if I say bullshit, but didn't they use ATRAC as audio compression a while back (or still?)?
Edit: OK, seems that different RA versions use different codecs. RA 8 used ATRAC, RA 10 uses AAC. Does it make sense to test RA at all then?
Reply #32
What does the rest of you think about Real?
While I agree that Real is definitely on the decline, there is considerable web-streaming at or near the rate you're testing.  Should be included.
Woody
There's no point testing real. Besides, no one uses Real anymore, it's all MP3, WMA, and (HE-)AAC. And the fact that Real 10 is AAC makes it even more pointless to test.
Reply #34
Up to RA9, Real Audio cook - an in-house developed codec, created by Ken Cooke - was the preferred format for low bitrates. These days, they are more or less replacing it with AAC+ indeed.
Reply #35
Another vote for Real instead of Atrac3...
There are a lot of streaming files all around the web which are available in real format (even in online music stores). So, could be great to have some comparisons with AAC/Vorbis/WMA contenders.
edit: typo
Reply #37
I would say to not test RA at all. If you do bother, use RA9's Cook, I guess.
Reply #38
Well, what Real Audio version then? 10 is pretty pointless if it's in fact HE-AAC. Then you don't want ATRAC - RA 8 is ATRAC...
I'm just checking Helix Producer 11 and there is no target bitrate for 48 kbps with Cook Codec...  (the nearest target bitrate is 44 kbps for Cook with Stereo @44.1KHz)
However, we can have a target bitrate of 48 kbps but with HE-AAC.
Reply #40
Thought about it again... I think we should forget about Real because it comes in too many flavours and one website might be streaming Real 8, the other 10... HE-AAC is already represented by Nero, so no point testing it again. Personally, I would go with ATRAC3plus since there are also several portable players supporting it. Or does anyone want QDesign?
Reply #41
Why no skip the 4th participant, in favor of paying more attention to the other participants?
High anchor: iTunes LC-AAC 128 kbps
Nero HE-AAC
AoTuV Vorbis (aoyumi decides which version and settings to use)
WMA10+
Low anchor: Lame 3.97b2 48 kbps
Do not taunt audiophiles; they may bite.
Reply #43
Well, that is also an option, but three contenders is really too few IMHO (the whole hassle just to test three encoders).
Right, it would be somewhat of a waste of the efforts involved in this test.
If you are considering QDesign, you might as well consider MP3pro too. Neither has a future, but MP3pro is still a little more popular (and it has a little hardware support!)
Or you could go completely nuts and try ePAC, VQF, LBpack... plenty of choices, massa!
Last but not least, you could cut the crap and try the Winamp AAC encoder. Yes, yes, I know it has been tested already and Nero won, but it would still be much more interesting than any other alternative proposed here :B
Reply #44
How about doing an 80 or 96 kbps test instead to see how good these bit rates are now that 128 kbps is virtually transparent? That would bring more codecs into play.
Reply #45
Well, he's doing 48kbps presumably to follow up on the earlier multi-vendor 48kbps HE-AAC test, and see how  Nero Digital compares to other codecs at this bitrate.
Reply #47
Fair enough.
Reply #48
Please add LAME ~128 kbps as a high anchor instead of AAC.
It would be nice to check the codecs against it instead of much better AAC 128kbps.
Also use latest AoTuV, as it seemingly contains some major low bitrate improvements.
SBR+PS will own it anyway, however it should hold up well against LC.
As to the other codec: MP3Pro would still be interesting.
ruxvilti'a
