Ah, right, I totally forgot about that guru, thanks for pointing out. WMA Standard then. Which settings do you wish folks?
I made a little test with WMA 9.1 standard and ten samples from Gabriel's test. I tried CBR 32kHz 48 kbps and VBR 2-pass 44.1 KHz 48 kbps. Bitrate managed VBR is not available at 32 kHz / 48 kbps. VBR q10 produces too high bitrates.
For encoding I used dbPowerAMP and had 2-pass enabled for both settings, but I doubt it does anything for CBR. The test conditions and samples were identical with my recent Vorbis 48 kbps test.
The results
ABC/HR logs
ABC/HR for Java, Version 0.5b, 11 June 2006
Testname: chanchanT WMA
Tester: Alex B
1R = WMA32kHz - 01 - chanchanT.wav
2R = WMA44kHz - 01 - chanchanT.wav
General Comments:
1R File: WMA32kHz - 01 - chanchanT.wav
1R Rating: 1.8
1R Comment:
2R File: WMA44kHz - 01 - chanchanT.wav
2R Rating: 1.5
2R Comment:
ABX Results:
WMA32kHz - 01 - chanchanT.wav vs WMA44kHz - 01 - chanchanT.wav
9 out of 10, pval = 0.01
---- Detailed ABX results ----
Playback Range: 07.722 to 09.206
2:20:25 AM p 1/1 pval = 0.5
2:20:33 AM f 1/2 pval = 0.75
2:20:45 AM p 2/3 pval = 0.5
2:20:55 AM p 3/4 pval = 0.312
2:21:14 AM p 4/5 pval = 0.187
2:21:27 AM p 5/6 pval = 0.109
2:21:37 AM p 6/7 pval = 0.062
2:21:47 AM p 7/8 pval = 0.035
2:22:07 AM p 8/9 pval = 0.019
2:22:22 AM p 9/10 pval = 0.01
____________________________________________________________________________________________________
Testname: fools WMA
Tester: Alex B
1R = WMA44kHz - 02 - fools.wav
2R = WMA32kHz - 02 - fools.wav
General Comments: Both are bad. 2 has less stereo separation but it may be more pleasant overall.
1R File: WMA44kHz - 02 - fools.wav
1R Rating: 1.8
1R Comment:
2R File: WMA32kHz - 02 - fools.wav
2R Rating: 2.0
2R Comment:
ABX Results:
WMA44kHz - 02 - fools.wav vs WMA32kHz - 02 - fools.wav
12 out of 12, pval < 0.001
Playback Range: 19.641 to 23.172
11:33:13 PM p 1/1 pval = 0.5
11:33:29 PM p 2/2 pval = 0.25
11:33:35 PM p 3/3 pval = 0.125
11:33:40 PM p 4/4 pval = 0.062
11:33:58 PM p 5/5 pval = 0.031
11:34:03 PM p 6/6 pval = 0.015
11:34:08 PM p 7/7 pval = 0.0070
11:34:12 PM p 8/8 pval = 0.0030
11:34:17 PM p 9/9 pval = 0.0010
11:34:21 PM p 10/10 pval < 0.001
11:34:26 PM p 11/11 pval < 0.001
11:34:32 PM p 12/12 pval < 0.001
ABC/HR for Java, Version 0.5b, 12 June 2006
Testname: kraftwerk WMA
Tester: Alex B
1L = WMA32kHz - 03 - kraftwerk.wav
2L = WMA44kHz - 03 - kraftwerk.wav
General Comments: no comments...
1L File: WMA32kHz - 03 - kraftwerk.wav
1L Rating: 1.0
1L Comment:
2L File: WMA44kHz - 03 - kraftwerk.wav
2L Rating: 1.0
2L Comment:
ABX Results:
Testname: Liszt WMA
Tester: Alex B
1R = WMA32kHz - 04 - Liszt_in_B.wav
2R = WMA44kHz - 04 - Liszt_in_B.wav
General Comments: Not bad when compared with some other samples. Couldn't make difference between these two.
1R File: WMA32kHz - 04 - Liszt_in_B.wav
1R Rating: 2.8
1R Comment:
2R File: WMA44kHz - 04 - Liszt_in_B.wav
2R Rating: 2.8
2R Comment:
ABX Results:
Testname: orion_ii WMA
Tester: Alex B
1R = WMA44kHz - 05 - orion_ii.wav
2R = WMA32kHz - 05 - orion_ii.wav
General Comments: totally distorted, unusable
1R File: WMA44kHz - 05 - orion_ii.wav
1R Rating: 1.0
1R Comment:
2R File: WMA32kHz - 05 - orion_ii.wav
2R Rating: 1.0
2R Comment:
ABX Results:
Testname: sandman WMA
Tester: Alex B
1L = WMA32kHz - 06 - sandman.wav
2R = WMA44kHz - 06 - sandman.wav
General Comments: Terrible, in ABX test 1 was slighly better
1L File: WMA32kHz - 06 - sandman.wav
1L Rating: 1.3
1L Comment:
2R File: WMA44kHz - 06 - sandman.wav
2R Rating: 1.1
2R Comment:
ABX Results:
WMA32kHz - 06 - sandman.wav vs WMA44kHz - 06 - sandman.wav
10 out of 10, pval < 0.001
Playback Range: 25.081 to 26.204
12:08:18 AM p 1/1 pval = 0.5
12:08:24 AM p 2/2 pval = 0.25
12:08:29 AM p 3/3 pval = 0.125
12:08:37 AM p 4/4 pval = 0.062
12:08:42 AM p 5/5 pval = 0.031
12:08:50 AM p 6/6 pval = 0.015
12:09:00 AM p 7/7 pval = 0.0070
12:09:10 AM p 8/8 pval = 0.0030
12:09:30 AM p 9/9 pval = 0.0010
12:09:39 AM p 10/10 pval < 0.001
Testname: Stravinsky_Capriccio WMA
Tester: Alex B
1L = WMA32kHz - 07 - Stravinsky_Capriccio.wav
2L = WMA44kHz - 07 - Stravinsky_Capriccio.wav
General Comments: Surprisingly good
1L File: WMA32kHz - 07 - Stravinsky_Capriccio.wav
1L Rating: 3.7
1L Comment:
2L File: WMA44kHz - 07 - Stravinsky_Capriccio.wav
2L Rating: 3.7
2L Comment:
ABX Results:
WMA32kHz - 07 - Stravinsky_Capriccio.wav vs WMA44kHz - 07 - Stravinsky_Capriccio.wav
7 out of 8, pval = 0.035
Playback Range: 03.390 to 05.396
12:21:22 AM p 1/1 pval = 0.5
12:21:43 AM f 1/2 pval = 0.75
12:22:04 AM p 2/3 pval = 0.5
12:22:31 AM p 3/4 pval = 0.312
12:22:47 AM p 4/5 pval = 0.187
12:22:57 AM p 5/6 pval = 0.109
12:23:24 AM p 6/7 pval = 0.062
12:24:38 AM p 7/8 pval = 0.035
Testname: TomsDiner WMA
Tester: Alex B
1R = WMA44kHz - 08 - TomsDiner.wav
2L = WMA32kHz - 08 - TomsDiner.wav
General Comments: Very good. 1 has a bit more lowpass.
1R File: WMA44kHz - 08 - TomsDiner.wav
1R Rating: 3.6
1R Comment:
2L File: WMA32kHz - 08 - TomsDiner.wav
2L Rating: 3.9
2L Comment:
ABX Results:
WMA44kHz - 08 - TomsDiner.wav vs WMA32kHz - 08 - TomsDiner.wav
Playback Range: 08.601 to 12.424
12:30:19 AM p 1/1 pval = 0.5
12:30:34 AM p 2/2 pval = 0.25
12:30:48 AM p 3/3 pval = 0.125
12:31:20 AM p 4/4 pval = 0.062
12:31:39 AM p 5/5 pval = 0.031
12:31:45 AM p 6/6 pval = 0.015
12:31:51 AM p 7/7 pval = 0.0070
12:32:01 AM p 8/8 pval = 0.0030
12:32:05 AM p 9/9 pval = 0.0010
12:32:15 AM p 10/10 pval < 0.001
Testname: twist_shout WMA
Tester: Alex B
1R = WMA32kHz - 09 - twist_shout.wav
2L = WMA44kHz - 09 - twist_shout.wav
General Comments:
1R File: WMA32kHz - 09 - twist_shout.wav
1R Rating: 1.5
1R Comment:
2L File: WMA44kHz - 09 - twist_shout.wav
2L Rating: 1.2
2L Comment:
ABX Results:
WMA32kHz - 09 - twist_shout.wav vs WMA44kHz - 09 - twist_shout.wav
Playback Range: 19.912 to 23.161
12:37:00 AM p 1/1 pval = 0.5
12:37:14 AM p 2/2 pval = 0.25
12:37:40 AM p 3/3 pval = 0.125
12:37:51 AM p 4/4 pval = 0.062
12:38:06 AM p 5/5 pval = 0.031
12:38:44 AM p 6/6 pval = 0.015
12:38:56 AM p 7/7 pval = 0.0070
12:39:09 AM p 8/8 pval = 0.0030
12:39:24 AM p 9/9 pval = 0.0010
12:39:51 AM p 10/10 pval < 0.001
Testname: waiting WMA
Tester: Alex B
1R = WMA32kHz - 10 - waiting.wav
2L = WMA44kHz - 10 - waiting.wav
General Comments: 2 has more lowpass and it is more distorded.
1R File: WMA32kHz - 10 - waiting.wav
1R Rating: 1.5
1R Comment:
2L File: WMA44kHz - 10 - waiting.wav
2L Rating: 1.2
2L Comment:
ABX Results:
WMA32kHz - 10 - waiting.wav vs WMA44kHz - 10 - waiting.wav
Playback Range: 04.376 to 06.668
12:44:23 AM p 1/1 pval = 0.5
12:44:31 AM p 2/2 pval = 0.25
12:44:40 AM p 3/3 pval = 0.125
12:44:43 AM p 4/4 pval = 0.062
12:45:00 AM p 5/5 pval = 0.031
12:45:16 AM p 6/6 pval = 0.015
12:45:35 AM p 7/7 pval = 0.0070
12:45:55 AM p 8/8 pval = 0.0030
12:46:06 AM p 9/9 pval = 0.0010
12:46:19 AM p 10/10 pval < 0.001
I would use CBR 32 kHz 48 kbps since it was a bit better.
EDIT
In general, I think that codecs that are this bad should be used in mono mode (I used stereo). If WMA and possibly some other codecs like AAC LC, MP3 (especially) were tested in mono mode that would produce more or less better audio quality (depending on the original amount of channel separation). Then the public test would also measure how important the stereo effect is for the users.
