Topic: >1 columns playlists? (Read 2463 times) previous topic - next topic
Does anyone know if it's possible to have a secondary columns ui playlist in your layout?  For example, I have a playlist that acts as my queue (called Queue), and I'd like that playlist to be visible below my main Library playlist, so that I can see what's in the Queue at all times (this would be especially useful in a party scenario where people can see what's been queued and then queue their own stuff).
Cheers!
why don't you try it yourself... and don't forget to share the results...
ahh i would, but i my programming skills are just a bit too rusty
with newest foobar it shouldnt be a problem. just add another playlist in your layout window...
I've added another Columns playlist, but its pointing to my normal library playlist...I don't see a way to specify which playlist appears...
it doesnt appear that columns_ui was meant to have more than 1 playlist visible at a time. all columns_playlists and playlist_switchers mirror each other. this function probably has to be added/changed in the code of columns_ui.
Yep it's looking that way...maybe they could just add the function to the "Configure" button in the layout section to specify which playlist is applied to that specific columns ui
