Topic: foo_uie_playlists_dropdown (Read 494636 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Reply #225
I don't know if it's my component's fault (I can't reproduce the problem), but the easiest way to check this is to temporarily turn it off (e.g. rename the component to foo_uie_playlists_dropdown.dll.bak and restart fb2k) and check if the problem still occurs.
Do the same with each problematic component - esp. Panels UI. Is there any problem when using Columns UI (and Playlists Dropdown) instead of Panels UI?
Reply #226
Well i'm using colums_ui , pnales_ui for track display :\ It would be great if there is a debug plugin  I think i'll try disabling components like you said. Thank you.
Reply #227
The download link and the title of the first post indicate that the latest version of this component is alpha 4, however the changelog describes an alpha 5. Are these simply preliminary announcements for changes in the next upcoming version or is there an alpha 5 available for download somewhere?
Reply #228
Can somebody please give a download link to v0.6 alpha 5?
Reply #230
There is no d/l link for alpha 5. I'll publish it as soon as it's ready (sooner or later).
Reply #231
any eta on alpha 5 ?
Reply #232
Is this component being developed? If so (or indeed if not), I can report that there appears to be a bug with 0.6 alpha 4 in the newest beta of FB. When you try to edit the autoplaylist properties using the playlist manager, it corrupts the playlist entries in the dropdown (so that one playlist is displayed twice and another is not displayed at all).
This error does not appear to be present in an older version (0.5.7.5 according to my components page).
Reply #233
0.6 alpha 5
Added Drag & Drop funcionality:
    * Auto expand dropdown list when dropping files (with custom delay)
I'm really looking forward to use this version. (and this feature)
Reply #234
Sorry for not responding for so long. Yes, this component is being developed. I'll look into bugs and release newer version (with D&D) as soon as it becomes stable. Currently I'm rewriting large parts of the code and reorganizing it to be more integrated with new Columns UI APIs (sounds like marketing bulls**t ).
Reply #235
Awesome, I'm looking forward to seeing it. I really like the component.
Reply #236
Hello.
Do you plan adding the possibility to edit autoplaylists queries ?
I know i can do it from the menu 'View>Playlist manager' but i think it would be nice to do it directly from your component.
Reply #238
Great, thank you
Reply #239
I get a massive lag in the userinterface (both DUI and CUI!) everytime a track changes or starts while this plugin is loaded.
Can I eliminate it with configuration or is it a bug?
I have roughly 20 autoplaylists and a collection of >30.000 tracks. It happens no matter what size the playlist are.
Reply #240
Has alpha 5 been released yet?
Reply #241
I have a strange problem with foo_uie_playlists_dropdown 0.6 alpha 4. After I installed this component, it generally works fine and I very like this . But I can't remove "other components" when foo_uie_playlists_dropdown is installed, or foobar2000 is failed to start. The term "other components" doesn't mean any specific components, I tried a number of components, all of them cause this problem. If I disable foo_uie_playlists_dropdown by rename the dll file, things goes fine again. I guess it may be caused by  accessing configuration at very beginning. I'm using foobar2000 0.9.6 beta3.
Edit: Recently I tried the same set on WinXP, everything is fine here. So it may be a Vista related issue, I also tried minimal set on Vista (default installation/settings + CUI + foo_uie_playlists_dropdown), which crashes when I activate the dropdown control. However, with some situation (more components, older settings), it works on Vista w/o problems but crashes after remove some components.
Reply #242
This component crashes my foobar (latest version 0.9.6 beta 4). The program just exits if I use this with columns ui / panel stack splitter setup, there is no crash dump. Used to work fine with my panels ui setup under foobar version 0.9.5.2. I'm using Vista 64bit.
Reply #243
New version 0.6.9.9. Download: www.fb2k.org
Changelog:
  • Requires foobar2000 0.9.6 and Columns UI 0.3.5.5 (oh, well, not really...)
  • Drag & Drop funcionality with auto-expand dropdown list while dropping files and auto-naming auto-created playlists (a lot of auto-mation here ) *)
  • Now using standard Columns UI Colours and Fonts configuration (Preferences -> Display -> Columns UI -> Colours and Fonts)
  • Added $offset_colour() and $calculate_blend_target() functions (similar to Playlist view functions)
  • Context menu for dropped list items *):
    Includes editing autoplaylists queries, operations on playlist items, cut/copy/paste, restore (playlists history) etc.
  • Removed live-sorting feature (to-do: "Sort by..." context-command)
  • Changed default title/style strings
  • %filesize_natural% now returns formatted total playlist file size, e.g. 62.1GB or 322KB (use %filesize% to retrieve file size in old-style bytes)
  • Changed %index% and %total% to more 'standard' %list_index% and %list_total%
  • Changed versioning scheme to match other components and extensions
  • No more lag on track start/change
*) - there is a known issue related to Drag&Drop and Context Menu. Click on the component, then activate a playlist using context-menu. Then, when the component loses focus, it will return to its selected-playlist-state from before your context-menu action. I'm trying to solve this.
Note that if you use this component in your Panels UI config, you may have to add it to your layout once again after upgrading. That's because Panels UI identify ui extention by its caption (which has changed in this version). This may also apply to other UI panels.
The lag should no longer occur with this version (could you check it with your config?), unless you use %length%, %filesize% or %filesize_natural%, but this is absolutely normal and causes lags even in CUI Playlists Switcher and Playlist Manager.
What do you mean by "remove other components"? Remove them from you layout? Remove them from components directory? Does this problem still occur with 0.6.9.9?
Could you try 0.6.9.9 with your version of Vista 64bit?
Reply #244
The new version is perfect, works like a charm:) Thanks for such a great foobar2000's component.
Reply #245
I have an issue with the new version. All playlists that has been played say (playing) in the menu, with this script.
$if(%isactive%,' (active'$if(%isplaying%,', playing')')',$if(%isplaying%,' (playing)'))
It worked fine in the previous version.
Reply #246
Thank you
I have an issue with the new version. All playlists that has been played say (playing) in the menu (...)
Thanks for the report. It should be fixed now, please re-download from www.fb2k.org.
Reply #248
Hello
I cannot access the properties page. When I select it, foobar produces an error report and freeze (need close from task manager).
WinXPSP3, Intel Core2Duo.
Failure:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 06AEADD6h
Access violation, operation: read, address: 00000059h
Call path:
entry=>app_mainloop=>preferences_page::create=>titleformat_object::run
Code bytes (06AEADD6h):
06AEAD96h:  C3 CC CC CC CC CC CC CC CC CC 6A FF 68 90 FB AF
06AEADA6h:  06 64 A1 00 00 00 00 50 83 EC 24 53 55 56 57 A1
06AEADB6h:  30 C0 B0 06 33 C4 50 8D 44 24 38 64 A3 00 00 00
06AEADC6h:  00 8B F9 A1 C8 D8 B0 06 8D 2C 7F C1 E5 05 33 DB
06AEADD6h:  38 5C 28 59 0F 85 F9 00 00 00 89 5C 24 2C 89 5C
06AEADE6h:  24 30 89 5C 24 34 C7 44 24 28 64 61 B0 06 8D 44
06AEADF6h:  24 1C 50 89 5C 24 44 E8 CE 6A FF FF C6 44 24 40
06AEAE06h:  01 8B 30 8B 44 24 28 8D 54 24 14 8D 4C 24 28 52
Stack (0012E774h):
0012E754h:  AD20ACD8 00000001 804DA3EE AD20AD10
0012E764h:  7FFDF700 00000000 00000000 89C125DC
0012E774h:  1E3D7CEF 084BC688 00000006 0012E920
0012E784h:  10006579 00000000 00503DB0 084BC688
0012E794h:  00000006 10006579 00000073 00000073
0012E7A4h:  0012E920 06AE4816 0012E8F4 06AFFB90
0012E7B4h:  FFFFFFFF 06AE4826 1E3D7C57 0012E977
0012E7C4h:  0012EA2C 00000000 00503DB0 0012EA44
0012E7D4h:  00019D90 00000000 00A40000 00000007
0012E7E4h:  00000010 00000028 7C910040 FFFFFFFF
0012E7F4h:  0001003D 06B05CF4 00000000 00000000
0012E804h:  00000000 00000014 7C910021 00A40838
0012E814h:  06B30000 00000000 00000029 00000009
0012E824h:  01A401B0 00000048 00A40000 00000002
0012E834h:  0012E8C8 06AFFC83 FFFFFFFF 7C90E900
0012E844h:  06B342C8 FFFFFFFF 0000000E 06AF1015
0012E854h:  06B30000 0012E87C 06AEDFDC 0012E8A0
0012E864h:  084A5D50 00000009 0012E8AF 00000009
0012E874h:  0012EAE0 0012E8AF 0012E8B0 06B30000
0012E884h:  00000001 0000005B 0000000F 01000003
Registers:
EAX: 00000000, EBX: 00000000, ECX: 00000000, EDX: 0012EA44
ESI: 00000006, EDI: 00000000, EBP: 00000000, ESP: 0012E774
Crash location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Loaded modules:
foobar2000                      loaded at 00400000h - 00539000h
ntdll                            loaded at 7C900000h - 7C9AF000h
kernel32                        loaded at 7C800000h - 7C8F6000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F02000h
Secur32                          loaded at 77FE0000h - 77FF1000h
GDI32                            loaded at 77F10000h - 77F59000h
USER32                          loaded at 7E410000h - 7E4A1000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D7000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
UxTheme                          loaded at 5AD70000h - 5ADA8000h
COMDLG32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
LPK                              loaded at 629C0000h - 629C9000h
USP10                            loaded at 74D90000h - 74DFB000h
IMHook                          loaded at 12300000h - 12308000h
MSVCR80                          loaded at 78130000h - 781CB000h
NTMARTA                          loaded at 77690000h - 776B1000h
SAMLIB                          loaded at 71BF0000h - 71C03000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
RocketDock                      loaded at 00AD0000h - 00AE2000h
PSAPI                            loaded at 76BF0000h - 76BFB000h
MSCTF                            loaded at 74720000h - 7476C000h
lgscroll                        loaded at 10100000h - 1010E000h
msctfime                        loaded at 755C0000h - 755EE000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
OLEAUT32                        loaded at 77120000h - 771AB000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_uie_trackinfo_mod            loaded at 00BA0000h - 00BF6000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
gdiplus                          loaded at 4EC50000h - 4EDF6000h
foo_abx                          loaded at 00C20000h - 00C51000h
foo_lastfm_radio                loaded at 00C80000h - 00CC5000h
foo_input_hvl                    loaded at 00CF0000h - 00D7C000h
foo_uie_queuemanager            loaded at 00DA0000h - 00DD9000h
mscoree                          loaded at 79000000h - 79046000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A400000h
mscorlib.ni                      loaded at 790C0000h - 79BB7000h
mscorjit                        loaded at 79060000h - 790BB000h
rsaenh                          loaded at 68000000h - 68036000h
System.ni                        loaded at 7A440000h - 7ABC5000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF68000h
foo_chronflow                    loaded at 03560000h - 035C1000h
WINMM                            loaded at 76B40000h - 76B6D000h
OPENGL32                        loaded at 5ED00000h - 5EDCC000h
GLU32                            loaded at 68B20000h - 68B40000h
DDRAW                            loaded at 73760000h - 737AB000h
DCIMAN32                        loaded at 73BC0000h - 73BC6000h
foo_input_tak                    loaded at 03750000h - 03793000h
tak_deco_lib                    loaded at 037A0000h - 037BF000h
foo_input_monkey                loaded at 03900000h - 03945000h
foo_input_alac                  loaded at 03970000h - 03990000h
foo_psf                          loaded at 039B0000h - 03A91000h
foo_gep                          loaded at 03AC0000h - 03B74000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_converter                    loaded at 03BA0000h - 03C0C000h
foo_input_shorten                loaded at 03C30000h - 03C5D000h
foo_input_ds                    loaded at 03C80000h - 03CAD000h
foo_freedb2                      loaded at 03CD0000h - 03D10000h
foo_skip                        loaded at 03D30000h - 03D4D000h
foo_msnalt                      loaded at 03D70000h - 03D8A000h
foo_playcount                    loaded at 03DB0000h - 03DDA000h
foo_sid                          loaded at 03E00000h - 03E7B000h
foo_uie_albumlist                loaded at 03EA0000h - 03EDD000h
foo_uie_vis_channel_spectrum    loaded at 03F00000h - 03F3D000h
foo_input_adplug                loaded at 03F60000h - 03FDC000h
foo_run                          loaded at 04000000h - 0402E000h
foo_rgscan                      loaded at 04050000h - 040AB000h
foo_uie_elplaylist              loaded at 040D0000h - 04137000h
foo_input_reverse                loaded at 04160000h - 0418E000h
libmmd                          loaded at 041A0000h - 04451000h
foo_infobox                      loaded at 04470000h - 044B5000h
foo_vis_shpeck                  loaded at 044E0000h - 0451E000h
foo_navigator                    loaded at 04540000h - 04574000h
foo_unpack_lha                  loaded at 045A0000h - 045C0000h
foo_alsong_lyric                loaded at 045E0000h - 0462C000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
iphlpapi                        loaded at 76D60000h - 76D79000h
foo_fileops                      loaded at 04690000h - 046D6000h
foo_mouse_gesture                loaded at 04700000h - 04729000h
foo_midi                        loaded at 04750000h - 047FC000h
foo_lock                        loaded at 04820000h - 04838000h
foo_uie_trackinfo                loaded at 04860000h - 04885000h
foo_dumb                        loaded at 048B0000h - 0493D000h
foo_dsp_bs2b                    loaded at 04960000h - 04980000h
foo_uie_graphical_browser        loaded at 049A0000h - 04A34000h
foo_lyricsdb                    loaded at 04A50000h - 04A7F000h
WININET                          loaded at 63000000h - 630DC000h
Normaliz                        loaded at 04A90000h - 04A99000h
urlmon                          loaded at 1A400000h - 1A52B000h
iertutil                        loaded at 5DCA0000h - 5DE55000h
foo_ui_columns                  loaded at 04CD0000h - 04E03000h
foo_dsp_xover                    loaded at 04E30000h - 04EB7000h
foo_bubble_coverflow            loaded at 05AE0000h - 05B69000h
foo_facets                      loaded at 05B90000h - 05C11000h
foo_comserver2                  loaded at 05C40000h - 05C96000h
foo_ac3                          loaded at 05CC0000h - 05CEF000h
foo_unpack_jma                  loaded at 05D10000h - 05D31000h
foo_ui_std                      loaded at 05D60000h - 05E34000h
foo_menu_addons                  loaded at 05E60000h - 05EBD000h
foo_input_dts                    loaded at 05ED0000h - 05F3A000h
foo_masstag                      loaded at 05F60000h - 05FA3000h
foo_uie_wsh_panel                loaded at 05FD0000h - 05FFF000h
foo_dsp_resampler                loaded at 06030000h - 06064000h
foo_uie_console                  loaded at 06090000h - 060AC000h
foo_uie_peakmeter                loaded at 060D0000h - 06103000h
foo_dsp_std                      loaded at 06130000h - 06178000h
foo_playback_custom              loaded at 061A0000h - 061E5000h
WINSPOOL                        loaded at 73000000h - 73026000h
foo_albumlist                    loaded at 06230000h - 0629B000h
foo_adpcm                        loaded at 062C0000h - 06315000h
foo_input_std                    loaded at 06340000h - 0647C000h
foo_input_mslive                loaded at 064A0000h - 064E1000h
WMVCore                          loaded at 15110000h - 1536C000h
WMASF                            loaded at 11C70000h - 11CAA000h
foo_uie_typefind                loaded at 06510000h - 06540000h
foo_lunar2                      loaded at 06560000h - 06581000h
foo_discogs                      loaded at 065B0000h - 06647000h
foo_uie_quicksearch              loaded at 06660000h - 066A6000h
foo_uie_vis_peakmeter_spectrum  loaded at 066D0000h - 0670F000h
foo_prettypop                    loaded at 06730000h - 0677F000h
foo_lyricsgrabber                loaded at 06830000h - 06884000h
foo_uie_tabs                    loaded at 068A0000h - 068CA000h
foo_uie_lyrics                  loaded at 068F0000h - 0694C000h
foo_input_tta                    loaded at 06970000h - 0699B000h
foo_uie_panel_splitter          loaded at 069C0000h - 06A0F000h
foo_input_ofr                    loaded at 06A30000h - 06A6D000h
OptimFROG                        loaded at 06A80000h - 06AB2000h
foo_uie_playlists_dropdown      loaded at 06AE0000h - 06B1A000h
foo_unpack                      loaded at 06B40000h - 06B6D000h
foo_cdda                        loaded at 06B90000h - 06BD1000h
btmmhook                        loaded at 06E20000h - 06E35000h
mscms                            loaded at 73B30000h - 73B45000h
icm32                            loaded at 66E90000h - 66ED1000h
SXS                              loaded at 7E720000h - 7E7D0000h
jscript                          loaded at 63380000h - 63407000h
xpsp2res                        loaded at 09600000h - 098C5000h
msi                              loaded at 3FDE0000h - 40221000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BBAD000h
mlang                            loaded at 75CF0000h - 75D81000h
DSOUND                          loaded at 73F10000h - 73F6C000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
CRYPT32                          loaded at 77A80000h - 77B15000h
MSASN1                          loaded at 77B20000h - 77B32000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
wdmaud                          loaded at 72D20000h - 72D29000h
msacm32                          loaded at 72D10000h - 72D18000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
midimap                          loaded at 77BD0000h - 77BD7000h
KsUser                          loaded at 73EE0000h - 73EE4000h
RASAPI32                        loaded at 76EE0000h - 76F1C000h
rasman                          loaded at 76E90000h - 76EA2000h
NETAPI32                        loaded at 5B860000h - 5B8B5000h
TAPI32                          loaded at 76EB0000h - 76EDF000h
rtutils                          loaded at 76E80000h - 76E8E000h
USERENV                          loaded at 769C0000h - 76A74000h
msv1_0                          loaded at 77C70000h - 77C94000h
sensapi                          loaded at 722B0000h - 722B5000h
mswsock                          loaded at 71A50000h - 71A8F000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
hnetcfg                          loaded at 662B0000h - 66308000h
wship6                          loaded at 58D40000h - 58D47000h
DNSAPI                          loaded at 76F20000h - 76F47000h
wshtcpip                        loaded at 71A90000h - 71A98000h
browseui                        loaded at 75F80000h - 7607D000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 10006579h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "stricmp_utf8_ex" (+00000000h)
Address: 00503DB0h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 06AE4816h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06AFFB90h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06AE4826h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 7C910040h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 06B05CF4h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 7C910021h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 06AFFC83h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 7C90E900h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "strchr" (+00000113h)
Address: 06AF1015h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06AEDFDCh, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 004784D7h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 7C919D90h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+00000210h)
Address: 7C919D8Ah, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+0000020Ah)
Address: 06AF104Ch, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06AE9CD9h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06AE1BF4h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 0047751Dh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004E4654h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 0050419Ch, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00478C3Fh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004783ABh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004C2937h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 06AEE11Fh, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06AFF1DAh, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06AE39D1h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06AEB5D0h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06B05EF8h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 005041ACh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 06B05EECh, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 10106B06h, location: "lgscroll", loaded at 10100000h - 1010E000h
Symbol: "setStromboliWnd" (+000002F6h)
Address: 06B05F04h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06AE1900h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06B0652Ch, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 00416D82h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 06AFF570h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06AEB9D6h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 101069C0h, location: "lgscroll", loaded at 10100000h - 1010E000h
Symbol: "setStromboliWnd" (+000001B0h)
Address: 7E42ACD1h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "MonitorFromPoint" (+000000DCh)
Address: 7E42ACE0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "MonitorFromPoint" (+000000EBh)
Address: 7C90E453h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 7E4565C0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetRawInputDeviceInfoW" (+00000068h)
Address: 7E4194BEh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 7E42C174h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "SetPropW" (+000000BBh)
Address: 06AFFD1Bh, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 7E418734h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E423CE4h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "EnumDisplaySettingsA" (+0000027Dh)
Address: 7E44048Fh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 7E423D08h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "EnumDisplaySettingsA" (+000002A1h)
Address: 7E423B30h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "EnumDisplaySettingsA" (+000000C9h)
Address: 7E423D3Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 773F8EB4h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0000D004h)
Address: 773F99C0h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0000DB10h)
Address: 7E418BD9h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 7E423D5Ch, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 7E418816h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+00000169h)
Address: 7E428EA0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000180h)
Address: 7E428EB0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000190h)
Address: 7E428EECh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+000001CCh)
Address: 7E4273CCh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "SendDlgItemMessageW" (+00000000h)
Address: 7E428E53h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000133h)
Address: 7E42AF42h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDlgCtrlID" (+00000027h)
Address: 7E42436Eh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDlgItem" (+00000000h)
Address: 7E4292E3h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "SendMessageW" (+00000049h)
Address: 06AEB948h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 77F15B70h, location: "GDI32", loaded at 77F10000h - 77F59000h
Symbol: "SelectObject" (+00000000h)
Address: 774228BDh, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+00036A0Dh)
Address: 77F1E458h, location: "GDI32", loaded at 77F10000h - 77F59000h
Symbol: "GetCharWidthA" (+00000261h)
Address: 7C832F41h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "LocalUnlock" (+00000078h)
Address: 7C832F49h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "LocalUnlock" (+00000080h)
Address: 7E42947Ch, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IsWindow" (+00000169h)
Address: 7C809EF0h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "IsBadReadPtr" (+0000005Fh)
Address: 5AD8B3BBh, location: "UxTheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "GetThemeTextMetrics" (+00000128h)
Address: 5ADA1AF8h, location: "UxTheme", loaded at 5AD70000h - 5ADA8000h
Address: 5AD73935h, location: "UxTheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "DrawThemeText" (+0000093Dh)
Address: 7E42413Ch, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefDlgProcW" (+00000402h)
Address: 06B13350h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 7E42B372h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "MoveWindow" (+000000D4h)
Address: 7E42651Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IsDlgButtonChecked" (+00001720h)
Address: 06B12DF0h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06AE0000h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06B1332Ch, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 40000500h, location: "msi", loaded at 3FDE0000h - 40221000h
Address: 06B1334Eh, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 4000004Ch, location: "msi", loaded at 3FDE0000h - 40221000h
Address: 7E42683Eh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "CreateDialogIndirectParamAorW" (+00000033h)
Address: 7E41EA84h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "CreateDialogParamW" (+00000049h)
Address: 06B03EC4h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06AEC642h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06AEC590h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06B03EA8h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 5AD8B43Ah, location: "UxTheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "GetThemeTextMetrics" (+000001A7h)
Address: 06B12D44h, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06B12D9Ch, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06B12DDCh, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06B12DECh, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06B0DB1Ch, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 06AEB21Bh, location: "foo_uie_playlists_dropdown", loaded at 06AE0000h - 06B1A000h
Address: 004657C1h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 03F2BE64h, location: "foo_uie_vis_channel_spectrum", loaded at 03F00000h - 03F3D000h
Address: 004C4056h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00465C22h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00465B37h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00466625h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00403AD6h, location: "foobar2000", loaded at 00400000h - 00539000h
Version info:
foobar2000 v0.9.6
UNICODE
Windows 5.1
Additional info:
ABX Comparator 1.3.3  (foo_abx)
Playlists Dropdown 0.6.9.9  (foo_uie_playlists_dropdown)
Navigator 0.63  (foo_navigator)
mslive 0.4.9 (SSE)  (foo_input_mslive)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
freedb Tagger 0.6  (foo_freedb2)
CD Audio Decoder 2.1.3  (foo_cdda)
SoX Resampler 0.3.0  (foo_dsp_resampler)
Cover Flow 0.19  (foo_bubble_coverflow)
Lyric Show Panel 0.3.3.4 [Nov 11 2008 - 19:42:37]  (foo_uie_lyrics)
Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]  (foo_uie_trackinfo_mod)
Default User Interface 0.9.5  (foo_ui_std)
BRR decoder and converter 0.7  (foo_adpcm)
Album List 4.3  (foo_albumlist)
Channel Spectrum panel 0.17.2  (foo_uie_vis_channel_spectrum)
Converter 1.2  (foo_converter)
COM Automation server 0.7 alpha 6  (foo_comserver2)
ALAC Decoder 1.0.1  (foo_input_alac)
WSH Panel (uie) 0.7.2  (foo_uie_wsh_panel)
DirectShow input 0.1  (foo_input_ds)
Track info panel 0.8  (foo_uie_trackinfo)
Typefind 0.2 beta 2  (foo_uie_typefind)
Reverse Playback 0.1.3 (Intel SSE)  (foo_input_reverse)
File Operations 2.1.1  (foo_fileops)
DTS decoder 0.2.2  (foo_input_dts)
Graphical Browser rev015  (foo_uie_graphical_browser)
ELPlaylist 0.6.3.0(beta)  (foo_uie_elplaylist)
Peakmeter Panel 0.0.4.2 beta  (foo_uie_peakmeter)
Interplay ACM decoder 1.0  (foo_adpcm)
Menu Addons 0.4 (Intel SSE)  (foo_menu_addons)
Last.fm Radio 0.5.1  (foo_lastfm_radio)
Album list panel 0.3.3  (foo_uie_albumlist)
ZIP/GZIP reader 1.0  (foo_unpack)
Shorten decoder 0.4.2a  (foo_input_shorten)
Facets 2008-02-25  (foo_facets)
Pause on Lock 0.4  (foo_lock)
Chronial's Coverflow 0.3.0  (foo_chronflow)
Discogs Tagger 1.15  (foo_discogs)
ReplayGain Scanner 2.0.8  (foo_rgscan)
bs2b 2.1.1  (foo_dsp_bs2b)
Run services 0.3.4  (foo_run)
Hively Tracker decoder 1.0  (foo_input_hvl)
OKI-ADPCM decoder 0.14  (foo_adpcm)
Lunar 2 PCM decoder 0.5  (foo_lunar2)
XA ADPCM decoder 1.2  (foo_adpcm)
GCN DSP decoder 1.3  (foo_adpcm)
TTA Audio Decoder (unofficial) 2.4.2  (foo_input_tta)
Playback Statistics 2.1.7  (foo_playcount)
Console panel 0.3  (foo_uie_console)
Standard DSP Array 1.0  (foo_dsp_std)
AC3 decoder 0.9.1  (foo_ac3)
Panel Stack Splitter 0.3.6.2(alpha)  (foo_uie_panel_splitter)
Queue manager panel 0.2.3  (foo_uie_queuemanager)
Game Emu Player 1.5  (foo_gep)
Alsong lyric plugin 0.0.2  (foo_alsong_lyric)
Monkey's Audio Decoder 2.1.3  (foo_input_monkey)
LHA unpacker 1.3  (foo_unpack_lha)
Lyrics Grabber 0.2.5 Beta  (foo_lyricsgrabber)
mouse gesture host 0.4.1  (foo_mouse_gesture)
sidplay2 1.13  (foo_sid)
foobar2000 core 0.9.6  (Core)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
MIDI synthesizer host 1.7  (foo_midi)
ADX decoder 1.7  (foo_adpcm)
kode's ADPCM decoders 1.2  (foo_adpcm)
AdPlug 1.0  (foo_input_adplug)
Shpeck - Winamp vis plugins wrapper 0.3.0  (foo_vis_shpeck)
DUMB module decoder 0.9.8.4  (foo_dumb)
Highly Experimental 2.0.6  (foo_psf)
Pretty Popup 1.2.4  (foo_prettypop)
Skip Track 0.3  (foo_skip)
RAR reader 1.1  (foo_unpack)
Columns UI 0.3.5.5  (foo_ui_columns)
TAK Decoder 0.4.2  (foo_input_tak)
JMA unpacker 1.0  (foo_unpack_jma)
Crossover 0.38  (foo_dsp_xover)
Playback Statistics Custom 1.4.3  (foo_playback_custom)
Masstagger 1.7.1  (foo_masstag)
Special file info box 2.0.4  (foo_infobox)
MSN Now Playing (alt) 2.4  (foo_msnalt)
OptimFROG Lossless/DualStream Decoder 1.21b  (foo_input_ofr)
RAC decoder 1.0  (foo_adpcm)
foo_lyricsdb 0.0.7 beta 5  (foo_lyricsdb)
Peakmeter Spectrum Visualisation 0.2.0.0 beta  (foo_uie_vis_peakmeter_spectrum)
Reply #249
I've experienced this crash too. It only occurs when the dropdown isn't actually visible in the current layout, though.
