Topic: foo_audioscrobbler 1.4.7 (Read 928549 times) previous topic - next topic
Reply #1100
i mean the foobar console. you can open this via the main View menu. it tells you when it submits tracks and it also reports errors whenever it is unable to do so.
Reply #1101
Yeah, already figured that out (in fact it wasn't even in my components folder!) and updated the first post;now all works well. Thanks!
Reply #1102
I'm having a really difficult time trying to get foo_audioscrobbler to work with foo_dop.
It works if I'm just playing tracks on foobar2000, but not with tracks I've imported from my iPod through the foo_dop component. This is devastating. I've been scrobbling since 2006 - almost 10 years. I've tried a variety of things to get this working, including rolling back to older versions of foobar from when I know it was working (i had created backups). No matter what I try I always get the following error in the console:
iPod manager: Apple iPod/iPhone connected. Device Instance Path: USB\VID_05AC&PID_1261\000A27001391F41D
Audioscrobbler: Handshake successful.
Audioscrobbler: Submitting 10 of 16 cached tracks...
Audioscrobbler: Submission failed: Plugin bug: Not all request variables are set - Invalid Timestamp
It seems to have stopped working January 1st, 2014. Seems like some kind of programming bungle involving timestamps..? Does anyone know how to fix this? Please? Is anyone still able to scrobble through foo_dop ?
Reply #1103
Recently (I think after adding few WSH Panel mods, but what do they have to do with foo_audioscrobbler?) my scrobbler started jamming - after listening to a few songs he stops on handshake, therefore not scrobbling any further songs (luckily he's adding them to queue for scrobbling). After restarting foobar I can scrobble them from history (With "Submit" button) but, still, it's quite irritating, I have to restart foobar like once per hour/two. Is there any solution?
plugins I use:
Core (2013-06-14 09:44:34 UTC)
    foobar2000 core 1.2.8
foo_albumlist.dll (2013-02-11 11:28:58 UTC)
    Album List 4.5
foo_audioscrobbler.dll (2010-06-04 07:27:04 UTC)
    Audioscrobbler 1.4.7
foo_cdda.dll (2013-03-07 09:48:32 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2013-06-14 09:09:50 UTC)
    Converter 1.5
foo_customdb.dll (2009-05-09 17:17:06 UTC)
    Custom Database 0.0.9a
foo_discogs.dll (2014-02-20 10:31:29 UTC)
    Discogs Tagger 1.32
foo_dop.dll (2011-06-28 17:25:35 UTC)
    iPod manager 0.6.9.7
foo_dsp_eq.dll (2013-02-11 11:28:58 UTC)
    Equalizer 1.0
foo_dsp_std.dll (2013-06-14 09:10:08 UTC)
    Standard DSP Array 1.3
foo_facets.dll (2011-08-18 18:06:16 UTC)
    Facets 1.0
foo_fileops.dll (2013-02-11 11:28:10 UTC)
    File Operations 2.2
foo_input_std.dll (2013-06-14 09:44:34 UTC)
    Standard Input Array 1.0
foo_masstag.dll (2014-01-16 17:48:38 UTC)
    Masstagger 1.8.4
foo_plorg.dll (2011-05-05 18:03:00 UTC)
    Playlist Organizer 2.4
foo_quicktag.dll (2010-09-01 09:15:08 UTC)
    Quick Tagger 1.0.3
foo_rgscan.dll (2013-06-14 09:09:54 UTC)
    ReplayGain Scanner 2.2
foo_clownware.dll (2013-02-14 10:17:08 UTC)
    UI Hacks 2013-02-14
foo_ui_std.dll (2013-06-14 09:44:34 UTC)
    Default User Interface 0.9.5
foo_uie_wsh_panel_mod.dll (2013-06-16 15:26:39 UTC)
    WSH Panel Mod 1.5.6
foo_unpack.dll (2013-02-11 11:28:10 UTC)
    ZIP/GZIP/RAR Reader 1.6
Reply #1104
Is there any way to exclude folders from being submitted? I have 2 separate music folders, A and B, and don't want B to submit anything. I really don't want to add a %skip% tag.
Reply #1105
the plays from my ipod classic are not being scrobbled. the console displays this error:
iPod manager: Device properties: DBVersion: 3, FireWireGUID: 000A27002127C69C
iPod manager: Apple iPod/iPhone connected. Device Instance Path: USB\VID_05AC&PID_1261&MI_00\000A27002127C69C&AAPL0
Error reading iTunesPrefs file: Object not found
Reply #1106
Hey folks!  This plugin has recently stopped working as of June 8th.  Every time I try to scrobble a track this appears in the console:
Audioscrobbler: Still awaiting handshake. Cache contains 523 tracks.
It seems it is also not just me having this issue, as per the comments on this page (with some getting other, more verbose errors):
http://www.last.fm/group/foo_audioscrobbler
Any suggestions?  Cheers
Reply #1107
last.fm have had serious ongoing problems for the last 5-6 days now but it appears to have settled down in the last day. i'm not having any problem scrobbling at the moment.
Reply #1108
Ah OK.  Still having problems my end but I'll give it a few more days and hope it resolves itself.  Cheers
Reply #1109
here's something you could try...
- hold down shift and then click on the File menu>browse configuration folder which will open windows explorer.
- close foobar
- open the configuration folder in explorer
- move the file named foo_audioscrobbler.dll.cfg somewhere safe.
- now start foobar again and goto file>preferences>tools>audioscrobbler. enter your last.fm username/password again (this is because we moved your old config file)
- play a track and see if it handshakes/scrobbles.
if it doesn't, then last.fm are still having issues. close foobar and then you can copy your old file back into the configuration folder, overwriting the new one that was just created.
if the new congfiguration works, you can close foobar and put the old file back in place. if you start foobar and you still have issues, it might be because the cache is too big. you may have to consider ditching your old file with all the cached scrobbles from the last few days and starting fresh.
Reply #1110
I think last.fm is definitely the one to be blamed here since even their official client is spotty at best when it comes to scrobbling songs, not to mention the loading spinners keep going forever.
Reply #1111
I can only speak for myself, but foo_audioscrobbler is the only last.fm client I've ever used that has NEVER done wrong by me (lost tracks, double submissions, other strange behavior, etc). Whenever I experience problems it does indeed turn out to be on last.fm's end.
Its only flaw is lack of updates. I'd love to see a new version with libre.fm support... but you can't have it all, I suppose.
Reply #1112
I never had problems with  foo_audioscrobbler except for the last few days, when last.fm have this issues on the site, with connectivity..
Now is ok...
Reply #1113
Anyone having issues with audioscrobbler on version 1.3.3 beta? The console says it's stuck on awaiting a handshake.
EDIT: Or is the site having issues again?
Reply #1115
Any idea why songs in the TTA format don't get scrobbled? There seem to be no messages from audioscrobbler in the console.
Reply #1116
i suppose using the length as a rough guide is no use if you add seeking into the mix.
the only way i know of to keep track of the real time elapsed is by writing a script for WSH panel mod. i'll knock up a quick bodge job.
edit: add this panel to your layout: http://www.hydrogenaudio.org/forums/index....showtopic=70363
then put this script in it. https://dl.dropboxusercontent.com/u/2280132...e%20elapsed.txt
it's only plain text. sue me.
screenshot:
Dear MARC2003
Can you provide the code for this panel, I really like and want it too
Thank you so so much
Reply #1117
i don't have a copy of that anymore.
Reply #1118
Last.fm changed their layout and the scrobbler no longer works
Reply #1121
no problems here either. last.fm certainly are doing their best to annoy users with their new website and are also breaking lots of other API feeds but scrobbling has been fine.
Reply #1122
Yes, unfortunately.
Last.fm Playcount Sync: {"error":{"code":3,"message":"Invalid Method - No method with that name in this package"}}
Reply #1123
Audioscrobbler: Now playing notification failed due to bad session ID
Audioscrobbler: Handshake failed: The system time is far off. Please correct your system time.
Audioscrobbler: Handshake failed.
anyone else getting these in their console? my system time is just fine and there were no problems whatsoever with anything before the layout update. i haven't even touched anything. it's been like this for a couple of days now at least. i'm suspecting the fault is at their end since they're still in the process of migrating, but would like a confirmation.
Reply #1124
it's still working here. check the date as well as the time??
