Topic: foo_audioscrobbler 1.4.7 (Read 929250 times) previous topic - next topic
Reply #650
Hello together.
It's seems I have similar difficulties as some of you: I've recently updated my fb from 9.4.4.X to its newest version with all new components etc. I've entered my data in Audioscrobbler's part of preferences. Possibly it's absolutely not audioscrobbler's problem, but could you help with or  redirect me to where I could be helped with
following probs -
1) Last.fm program is not opening anymore, when fb is started. And when I force it to start it doesn't show what will be payed at the moment.
2) even downgrading to 1.3.16 had no positive effect
Has anyone an idea how it could be solved?
MANY thanks in advance!
Reply #652
Thank you, it also seems to fix sending the app music is scrobbled from. (I jumped from 1.4.0 to 1.4.2) last.fm webpage kept showing that I was scrobbling from XBMC (on my xbox), though I was using foobar.
Reply #653
Songs aren't scrobbled for streams from a playlist.  If you add the stream directly then they do.
To verify, use this playlist
http://provisioning.streamtheworld.com/asx...GT=AOLWebPlayer
nothing gets scrobbled.
Add any of the streams in the playlist directly and they will be scrobbled.
<entry><ref href = "http://208.80.54.100:80/CBS_R20_831P_F128CMP3?amp;DIST=AOL&SRC=AOL&amp;TGT=AOLWebPlayer"/></entry>
<entry><ref href = "http://208.80.54.100:3690/CBS_R20_831P_F128CMP3?amp;DIST=AOL&SRC=AOL&amp;TGT=AOLWebPlayer"/></entry>
<entry><ref href = "http://208.80.54.100:443/CBS_R20_831P_F128CMP3?amp;DIST=AOL&SRC=AOL&amp;TGT=AOLWebPlayer"/></entry>
Reply #654
i get the "previous submission still in progress" thing. i'm not surprised by that (my net connection is really crappy so no surprise some programs can't cope with that), just it's annoying. right now i have 70 songs in the cache. is there any way to stop the previous submission so that the cache could be submitted? or if that's not possible, then dump the cache so it's not lost? (i'll be upgrading to 1.4.2 from 1.4.1 asap after this cache problem is over)
Check my blog! Yay!
Reply #655
I appreciate the new(-ish) field remappings feature, but I must be using it wrong, because I'm not seeing any changes to my scrobbles.  For the Title field, I entered "[%title%][ (%version%)]".  Yet, the version still doesn't show on last.fm.  Thoughts?
Reply #656
Last.fm automatically applies normalisation and correction to the submitted track information which might be triggered here.
Reply #657
True.  And my tracks always have a MUSICBRAINZ_TRACKID, which has been known to cause "corrections" to stale (since fixed) musicbrainz titles.  Still, I ran with this setting for months, and never saw a single %version% come through.  It's possible last.fm stripped this info from every single title, but I don't feel it's very likely.
Reply #658
Parentheses are special characters, you ought to use the quotes.
[font= "Courier New"][%title%][ '('%version%')'][/font]
(TIP: Try the title formatting in Default UI preferences or wherever else there is a preview.)
Reply #660
Download foo_audioscrobbler 1.4.2
Enjoy
Hmm, the download link on your MP3Tag site doesn't seem to work for me at the moment. Furthermore I would rather need the old version 1.3.12, because that seems to be the last which supports Windows 2000. Is it still available somewhere?
ZZee ya, Hans-Jürgen
BLUEZZ BASTARDZZ - "That lil' ol' ZZ Top cover band from Hamburg..."
INDIGO ROCKS - "Down home rockin' blues. Tasty as strudel."
Reply #661
It works if your browser passes the HTTP referrer to the site.
http://download.mp3tag.de/fb2k/versions/fo...bler-1.3.12.zip
Reply #662
OK, the problem seems to be my "Free Download Manager" that cannot handle the link correctly (maybe because of several . in the URL), it downloads the HTML page instead. If I quit FDM and let Internet Explorer do the download, it works.
Thank you very much.
Reply #663
Same problem, but also using 1.4.2
I would prefer not to reset my settings page again so that it can scrobble.
Submitting the cache doesn't seem to work.
Here's the log from the console:
Audioscrobbler: Handshake successful.
Audioscrobbler: Submitting 10 of 90 cached tracks...
Audioscrobbler: Previous submission still in progress
It can never actually submit them though. I've waited for around an hour at a time.
Reply #665
Just backed up my app data folder of foobar and reset the settings for audioscrobbler.
It scrobbled 2 songs before putting the rest of the songs in the cache which was unable to submit them.
Reply #666
I'm getting "previous submission still in progress" as well.
EDIT: Closed fb2k, reopened, clicked "Submit" in the preferences dialog, and BINGO!
Reply #667
Tried that a couple times, never worked.
Reply #668
Darn.  I only had 8 tracks in my cache, how many did you?
Moderation: Removed unnecessary full quote of the preceding post.
Reply #669
It only scrobbles once before sending a song to cahce after which it cannot scrobble.
Is anyone aware of necessary windows services for this to run properly? =|
Reply #670
Ack.
It works now, sometimes. Kind of.
It only uploaded a couple of the entries in the cache, and it had the timestamps completely off. My stystem time is correct, but is there something wrong with the way foobar is fetching it? I don't see anything in the console that suggests it, the handshake seems to succeed every time.
Reply #671
Hello
Thanks for the plugin. It was on my list of requirements before converting from iTunes 9.
Installed FB2K 0.9.6.8 and AudioScrobbler plugin 1.4.2 and configured my last.fm credentials.
Checked 'Enable Audioscrobbler' in FB2000.
Last.fm 1.5.4.25467 installed and running on Windows XP.
Last.fm plugins installed for iTunes and Media Player
Playing tunes from the 'Default' playlist doesn't scrobble.
Have I missed something ?
Peace, love, empathy
Andy
Reply #672
do you have your tracks in the foobar media library? if not uncheck "Only Submit Tracks From The Media Library"
apart from that im not sure, if this isnt the problem hopefully someone else can enlighten more
Reply #673
Oh hang on. Looking at Console log
Audioscrobbler: Submitting track...
Opening track for playback: "C:\Documents and Settings\Andy\My Documents\My Music\Foobar2000\National\Boxer\Mistaken For Strangers.flac"
Audioscrobbler: Submission succeeded.
Opening track for playback: "C:\Documents and Settings\Andy\My Documents\My Music\Foobar2000\National\Boxer\Brainy.flac"
Maybe it's slow as I am sync'ing to iTouch.
Reply #674
Mystery solved. My recent plays do indeed show up in last.fm
What confused me was that when I previously used Windows Media Player and iTunes (may the Lord have mercy on my soul), the last.fm application showed 'Currently playing...' with the current track whereas FB200 doesn't (appear to).
Andy
