Topic: foo_audioscrobbler 1.4.7 (Read 929263 times) previous topic - next topic
Reply #400
Also, does handshake successful mean there's a constantly open connection while foobar/the plugin is running? Surely if there is this could be a security risk?
as far as I know, since you see "Handshake Successful" each time a track is submitted, that it only opens the connection when it submits, then closes it afterwards.
Reply #401
There are not constantly open connections with the plugin. Handshaking is done once on startup and the connection is closed after the plugin received the session id from the Last.fm server.
Reply #402
Using foobar2000 v0.9.4.5 and 1.3.2 I get the errors in my foobar console.
Submitting 10 of 111 cached tracks to Audioscrobbler...
Submission failed: bad authorization.
Yet I know the password and username work - I can use them to login to last.fm - but it says "bad authorization"?
Any suggestions? I would hate to lose 100+ cached tracks.
EDIT: Changed my password to something else and all is fine. All 113 tracks got submitted.
Reply #403
Any chance of incorporating rockbox support?  Maybe a menu option that leads to a popup allowing you to choose the drive letter of a rockbox-enabled DAP (thereby submitting the contents of the ".scrobbler.log" contained at the root)?
A PHP script for submitting these log files is available on sourceforge, but it'd be nice to scrobble my rockbox (say what?) without going to a webpage:
http://paulstead.com/scrob/
First:
Thanks for the HP, is nice.
But however it would be really great, if I could use the audioscrobbler to upload my log.
Reply #404
i have a little problem to scrobble this artistnames: [ Sin.thetic Squad ], [Cynical_Mass].
and i think the problem is the []
the log in the header is:
a=%5BCynical%5FMass%5D
is this a problem from this plugin or from last.fm/post.audioscrobbler.com or by me ?
chatterer
Reply #405
I have a problem with submitting trackinfo to the last.fm server.
It started on sunday when daylightsaving (+1 hour in germany) was engaged.
The foobar console says:
[21:14:58] Audioscrobbler: Handshake failed: The system time is far off. Please correct your system time.
[21:14:58] Audioscrobbler: Handshake failed.
But my computers clock is exact.
What may be the problem?
Reply #406
Did you make sure to change your time zone and not your clock (if it was not automatic). You may have your computer on the wrong time zone, thus your clock is out if converted to GMT.
Reply #407
I have gmt+1 for germany.
And enabled "automatically adjust clock for daylight saving changes".
Reply #408
Another user reported this issue at Last.fm and I really have no idea why this is happening. I'll try to compile a debug build that should put some light into this.
According to a discussion I've been following on the official IRC channel, it's also not unique to foo_audioscrobbler. (though I haven't heard anything from Last.fm staff).
Reply #409
The debug build revealed that the system time was indeed one day off.
Reply #410
I'm getting this error message from last.fm. using version 1.3.16.
Some tracks you submitted have not been added to your profile for the following reason:
Spam protection triggered: You submitted a track dated earlier than your last submission.
i've got no idea why. must have been some cached tracks...
thought you might be interested, maybe a bug
greets
Reply #411
greets
I get the same error message when I go to my page on last.fm. Using the 1.3.16 version.
Reply #412
greets
Same here.
Reply #413
I guess in my case it way foo_dop submitting tracks that have been played on my iPod after syncing...
But honestly - what kind of spam protection is that?
np: 4'33"
Reply #414
Hi !
great plugin !
but now I have a problem - I have to use Win2k sometimes at work so I have to use foobar2000 0.9.4.5 because newer releases need XP system. But when I try to install foo_audioscrobbler (i tried v1.3.15 and 1.3.16) I get this error message when I run foobar:
Failed to load DLL: foo_audioscrobbler.dll
Reason: The specified procedure could not be found.
Does anybody know where is a problem ?
thanks
Reply #415
Hi there.
I got this warning with new 0.9.5.3:
The following components are incompatible with this foobar2000 version and will function partially or incorrectly:
- foo_audioscrobbler.dll : Audioscrobbler
Please update these components to their latest versions if possible.
Is there an updated version of this plugin? Or is scrobbler working correct now? Warning messages obviously can't be disabled... :/
Reply #416
Well, which version are you using? I'm not getting this warning with version 1.3.16 and foobar2000 0.9.5.3 here...
np: 4'33"
Reply #417
Weird... foobar claims it's 1.3.9. I'll try your version.
Edit.
Typo.
I think I copied wrong version to my foobar folder. Works now.
Reply #418
I just finished new version of foo_audioscrobbler Cache Viewer 2.2. It's completely rewritten, now under .NET 2.0 (sorry, .NET haters ). Works with latest foobar2000 (v0.9.5.3) and component (v1.3.16).
download link
If it shows some error message, please send me mail with foobar2000.cfg to email address: morfeus281 @ at @ zoznam.sk
Reply #419
I don't see why anyone would need that -- but that's probably only me.
What I want to clarify at this point is, that your Last.fm username and password are also stored in the foobar2000.cfg.
So please have this is mind when sending your configuration files to random people.
Reply #420
Yeah I know that it is saved there, but I have no reason to abuse it to screw with people's statistics.
Reply #421
The plugin worked a short time, but now i get this error:
Startup time : 0:02.041282
Audioscrobbler: Handshake successful.
Audioscrobbler: Submitting 10 of 79 cached tracks...
Audioscrobbler: Connection error
And when i try to submit with the submit button it repeats the Submitting->connection error.
Reply #422
nope everything ok on my side...probably short downtime of last.fm server or your isp
Reply #424
i  have similar problem "Audioscrobbler: Connection error"
firewalls is turned off.
