Topic: foo_audioscrobbler 1.4.7 (Read 929977 times) previous topic - next topic
Reply #500
Please send me foo_audioscrobbler version 1.3.12, I'm using Windows 2000 currently :/
EDIT: Thx
Reply #502
Hi Florian, could caching played be enabled by default?
My foobar2000.cfg pissed itself during a power outage and I realize that I just realized I missed 2 weeks of played tracks, because I forgot to revisit this components prefs page.
If they were in the cache, all would be, OK.
elevatorladylevitateme
Reply #503
Caching is enabled by default (and can't be turned off). If foo_audioscrobbler can't connect to the submissions server it stores the played tracks in the cache -- which resides in foobar2000's config file.
Reply #505
Not work on 0.9.6.3?
I have "Your cache contains 0 track".
Reply #506
Where's the problem? The tracks are already submitted if the cache is empty.
Reply #507
Hi, the problem is I don't see last.fm update song.
Must I install other component to use with foo_audioscrobbler?
Thank you
Reply #508
Don't care about the previous post, the plugin work now... (just must be more patient  )
Thank you for the nice plug-in
Reply #509
The scrobble is at songstart, and last.fm updates immediately. So, patient is not necessary.
This output must be in console when you start a song, then it's ok:
Opening track for playback: "Q:\MUZIEK\Various Acoustic\Unplugged Volume 13 (2009)\08. Roger McGuin - Mr. Tambourin Man.mp3"
Audioscrobbler: Submitting track...
Audioscrobbler: Submission succeeded.
Reply #510
And that's a problem. When foobar, or the system, crashes it loses changes made since it was last run. This includes the scrobblercache. I've had that problem before, losing a few days worth of plays. Slightly off topic: It's also very annoying when I make layout changes and then forget to close and re-open foobar, leave it running for a few days and then my comp crashes for some reason and then I have to re-do layout, which is of course my own fault. There's not too much I can do to save the cache though, except for closing and reopening foobar regularly I guess. Perhaps the cache could be saved somewhere else, instantly to disk?
Reply #511
Or commit your way to Jesus.
Reply #513
I've been using the plug-in for a long time, recently I've been getting this error:
Audioscrobbler: Submission failed: Plugin bug: Not all request variables are set - Invalid Timestamp
I'm not sure what the problem is. I've only been able to find one other person with this problem, on the last.fm french site and he couldn't get find a fix.
Nobody has any ideas about this?  I'm quite confused.
Reply #514
Hello,
request for next version:
Is it possible to adjust the time in percent the song is scrobbled? Sometimes I play only 10 sec of a song, but it's scrobbled.
Reply #515
anybody having issues with scrobbling tracks during last couple of days? Right now: 14 tracks in cache (instead being scrobbled) and when I click Submit and look into console, I can see there:
Audioscrobbler: Could not connect to host
or
Audioscrobbler: Invalid data, full line expected
Reply #516
Only if the "enable Audioscrobber" check box is checked in the preferences page, and it isn't by default, which is what I'm asking for.
Reply #517
I prefer that the user activates the component. The Last.fm login data has to be provided anyway, so enabling the whole component is only a tick away
Reply #519
It's not scrobbled immediately. The only thing that is sent when starting a song is the now playing notification which is not permanently stored at the Last.fm server.
It's not planned to adjust the scrobbling time.
Reply #520
Probably related to some hiccups with the submission server.
yes - anyway it behaves strange. I can see the "listening now" track in last.fm "Recently Listened Tracks" table, but its like the tracks are not stored there (they stay in foobar cache instead). Then, without any apparent reason, whole cache gets scrobbled. But sometimes after several hours.
Reply #521
ok, I think I got it now. when I visit Last.fm status page, it tells me following:
Web Site     OK
Submissions     CRITICAL
Bootstraps     OK
I guess this explains my scrobbling issues
Reply #522
Anyone experiencing problems with the audioscrobbler plugin as of now?
I've been getting the: Audioscrobbler: Could not connect to host error. I'm using the latest version (1.3.16) of Florian's plugin w/ Foobar 0.9.5.6.
here's the last.fm status:
Web Site OK
Submissions OK
Bootstraps   OK
Any help appreciated.
edit: also getting this: Audioscrobbler: Invalid data, full line expected and Audioscrobbler: Could not connect to host
Reply #523
Same story here.
(forgot to say that I'm quite pissed off last.fm server problems during last days. Just wondering if they are going to fix it one day...)
Reply #524
How does the cache work?
After syncing my iPod, my plays go into the cache and I have to submit them manually, is this correct or should it submit them automatically?
Ben
