Topic: foo_audioscrobbler 1.4.7 (Read 930211 times) previous topic - next topic
Reply #475
I have a problem..
When I try to submit, it said "Not submitting. Cache contains 31 tracks.
I've tried to restart foobar, but nothing happen.. It's still not submitting..
Reply #476
I would love the option to mark a track as 'loved' on LastFM directly from Foobar. I guess an option in the right click menu would be enough.
Please don't make this plug-in bloated. This is just a track info submitter.
I am going to have to second this sentiment. All this needs to do is upload tracks played.
Bloated? Seriously, I don't see how a "love track" feature could ever bloat the plugin. This is a basic function of last.fm that has gotten even more attention since the redesign of last.fm. Now you can easily access a list of a person's loved tracks via her profile page.
A right click menu item would do. And for those that couldn't stand the "bloat", a feature to disable the menu item in the foo_audioscrobbler settings.
I see this feature being requested over and over again. Please Florian, at least consider it.
Reply #477
Well put 12345. I second that.
Reply #478
You wouldn't even need that, there's already a page to customize the context menu. It would just need one command to be added, wouldn't need anything on the prefs>Audioscrobbler page...
And I agree, a love command would be great.
Reply #479
Isn't love and hate meant for tracks that you play on the website last.fm or listen to in a stream from last.fm? I think it's not meant to love or hate tracks that are inside your library allready.
So it's maybe better to request such a feature that goes with the last.fm-streaming component. Maybe that author is willing to write something like that.
Reply #480
Love can be for anything, library or stream, ban is only for stream. So it would only make sense for this component to have a love command, but I still think it should...
Reply #481
Ban is only for tracks from streams, but it is still requires an audioscrobbler submission, along with a 5 digit key to prove it is from a stream.
foo_lastfm_radio makes this key available as an info field: $info(lastfm:trackauth).
Reply #482
An older version of the plug-in only submitted the first %artist% tag (ignoring any further artists tagged to the track). I liked it that way. The current plug-in submits all of the tagged artists, separated by commas, which I like a lot less. If I could just set it to submit "$meta(artist,1) - $meta(title)", I'd be happy as a clam. Possibly make the submitted data configurable? It makes sense to, since one of the great things about foobar2000 anyways is how customizable it is. This would also forestall any further whining by people like me on here.  A quick skim through the thread shows I'm not the first person to have an issue w/ this. Just my $.02.
-Devin.
O Agatha, you are tiresome.
Reply #483
Updated foobar to the newest (0.9.6) version, and Last.fm stopped working. Then I tried this stand alone 3rd party plugin instead of Last.fm software, but it keeps saying "Audioscrobbler: Still awaiting handshake. Cache contains 5 tracks." I've tried to restart foobar a few times, makes no difference..
EDIT:
Updated the plugin to 1.3.7, now it says "Not submitting. Cache contains 8 tracks." ...
EDIT2:
Actually after restarting foobar, again, it says "Cannot connect to server."
Reply #484
EDIT:
EDIT2:
It happens with me too..
I still don't know why..
Reply #485
EDIT:
EDIT2:
hmm, i run 0.9.6 on vista and have no problems with submitting tracks...
+1 for love context menu entry
Reply #487
How about an option to map which string is used for artist, title etc.?
The issue is that I use tags like composer, band and subtitle and on those tracks it can't submit the info since it doesn't look in those tags.
Reply #488
+1 for "LOVE TRACK" submission feature.
Reply #489
+1
Reply #490
I really miss a "toggle scrobbling"  command(not an otpion)
thus we will be able to give it keyb shortcut or a menu button...
Reply #491
Thanks for great plugin, but there would be some way (command) to disable/enable scrobbling and a variable for getting what is set.
Reply #492
some suggestion... foobar is now much more portable, could you make and 'portable' option for you plugin which will ask for last.fm username and password (or at least password) on the first submission? username and pass (or only pass) will be removed from memory on foobar close. I often share my newer version of configured foobar with friends soo this could be usefull to not remove every time plugin setting
Reply #493
...you just admitted to violating foobar's terms of use on its own forum...
foobar2000 audio player
Copyright © 2001-2008, Peter Pawlowski
Portions copyright © 2005-2006 Holger Stenger
Portions copyright © 2003-2005 Gian-Carlo Pascutto
Icons copyright © 2007 Florian Trendelenburg
Installer script and button icons copyright © 2003-2007 Janne Hyvärinen
All rights reserved.
Redistribution and use in binary form, without modification, are permitted provided that the following conditions are met:
Redistributions must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
Neither the name of the author nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
Redistribution of modified binaries or modified setup packages allowed only with prior written permission of the author.
elevatorladylevitateme
Reply #494
oh, sorry about that... I don't know how can I justify my move... they just want my version of foobar, never sharing it as a normal foobar installation, always as my configured foobar with components in it, theme, custom buttons on the front, all that only for their convenience and with full knowledge about that, and never sharing it on the internet
Reply #495
Possible bug:
when changing foobar's location of configuration files from user profile folder to application folder, the audioscrobbler stops submitting. Handshake not succesfull it say's, keeping tracks in cache. When overwriting the component with a freshly downloaded foo_audioscrobbler.dll (same version as I had before) it all got working again.
Reply #496
Let me get this straight... you interpret the TOS such that it prohibits Person A from performing an install on his/her computer, getting it all nice & pretty with some 3rd party plug-ins/components, and then providing that config for family, friends, and neighbors to use because they're too computer- and software-challenged to do it themselves? No binaries have been modified, and the installed config is not a "setup package" in the sense typically meant by software license terms. Please elaborate.
Reply #497
I've been using the plug-in for a long time, recently I've been getting this error:
Audioscrobbler: Submission failed: Plugin bug: Not all request variables are set - Invalid Timestamp
I'm not sure what the problem is. I've only been able to find one other person with this problem, on the last.fm french site and he couldn't get find a fix.
Reply #498
Is there any way for this component to include context menu items so that you can "love" a track from within Foobar2000?
Reply #499
I second that, it would be useful to have an action "audioscrobbler toggle" assigned to some keystroke, and some information in console or elsewhere about if audioscrobbler is on or off.
