Topic: foo_audioscrobbler 1.4.7 (Read 928578 times) previous topic - next topic
foo_audioscrobbler is a Last.fm/Audioscrobbler component for foobar2000 1.0 and later.
Features
  • It works independent of the Last.fm client application.
  • It supports the current submission protocol.
  • It sends now playing notifications to your Last.fm profile.
  • Optionally, it can import played tracks from your iPod via the foo_dop component.
  • It has an own group on Last.fm.
Download foo_audioscrobbler 1.4.7 (where you can also read the release notes)
Join the foo_audioscrobbler group on Last.fm
Important note: If your submissions do not appear on you Last.fm profile page, please first check the Submissions Server Status.
Ooh lovely. I'd try this straightaway, but Preston North End (my home city) are playing Leeds in the playoff finals, it's just about to start, so i'll have to wait a couple of hours to try it:D
Thank you.
does the plugin without the installer need libcurl.dll?
Wow, thanks!
How does this compare to the Audioscrobbler beta program that the Last.fm people are pushing?
Thank you.
No, even the installer doesn't include libcurl. It's a complete rewrite without libcurl, because libcurl caused some problems.
It's comparable to the standalone plugin we had for foobar2000 0.8.3 (but hopefully without the bugs :B). It does the same as the new beta Audioscrobbler, except that you won't need to run the additional Audioscrobbler application in the system notification area.
Actually it is. There is an English word for it too, the word is `overkill'. Or do you by chance pack an installer with every single file you send to your friends via email? I hope you don't.
@OP:
So far the plugin has worked without problems. Thank you for this update.
@OP:
Then just run the installer and save the dll it installs. Not hard for a l33t installer hater like you eh?
I actually agree with you personally, i'd rather have the dll, but I  think the OPs response was provoked by you calling an installer 'crap'. Other people find them useful and you could have been a bit more polite.
Can you please stop talking about the installer. There is the choice, just download what you prefer.
Personally I don't need the installer, but I kept it because all previous releases of the component are shipped with an installer. I thought I could circumvent a discussion about it, by simply keeping it like it was before.
Obviously I was wrong.
Ah, sorry about that.
I've got round to trying this and i'm getting this in my console:
Not submitting. Cache contains 1 tracks.
Not submitting. Cache contains 2 tracks.
Not submitting. Cache contains 3 tracks.
Not submitting. Cache contains 4 tracks.
Not submitting. Cache contains 5 tracks.
Not submitting. Cache contains 6 tracks.
Not submitting. Cache contains 7 tracks.
Not submitting. Cache contains 8 tracks.
last.fm appears to be up. Any ideas?
What do you get on the console when you start foobar2000. Is there some message about handshaking?
Ah, I got it to work by deleting my config file. Thank you.
Submitting track to Audioscrobbler...
Submission failed: bad authorization.
Submitting 2 cached tracks to Audioscrobbler...
Submitting 3 cached tracks to Audioscrobbler...
Submitting 4 cached tracks to Audioscrobbler...
Submitting 5 cached tracks to Audioscrobbler...
it was working fine earlier...
Did you try to restart foobar2000? Normally a re-handshake should solve BADAUTH issues.
I updated the component, but everytime I close foobar2000, the program window disappears, but the process remains active. To be sure it's not another component (I updated several), I renamed the extension to .dl_ and foobar2000 closes entirely now.
Unfortunately, the hanging issue seems to be still there.
If you are interested, this is what the console reads:
Startup time : 0:00.160779
Handshaking: Client up to date.
Submit interval set to 1 seconds.
Handshake successful.
I also noticed foobar.exe ghost after installing foo_audioscrobbler. Deleted it and haven't had any since.
FWIW, I don't get a ghost process when I quit fb2k, and I have this component installed.
