Nero AAC Recommended Settings
The latest encoder can be downloaded from:
http://www.nero.com/eng/technologies-aac-codec.html
Approx. average bitrate <-> Quality table
Bitrate Quality
~16 0.05
~33 0.15
~66 0.25
~100 0.35
~146 0.45
~192 0.55
~238 0.65
~285 0.75
~332 0.85
~382 0.95
Using VBR mode (-q) will give the best quality. The default setting is -q 0.5, which will give about 160-170kbps on average. For ABR, use the -br options. For CBR, use -cbr. Note that the bitrate is in bits per second, not kilobits.
Note that using 2-pass encoding makes no sense in VBR mode!
When encoding from the commandline, sending the input over stdin is supported, but then you should also use -ignorelength. This is not needed when using temporary files.
The package includes a commandline MP4 tagger.
Settings:
foobar2000 0.9.x or later (recommended over 0.8.3):
Choose MP4 (Nero) as Output format.
EAC:
Either (simple, no tagging):
-q 0.5 -if %s -of %d
Or (more complicated):
User-defined Encoder, file ending .mp4
Program used: C:\Windows\system32\cmd.exe
additional commands:
/c ""C:\path\to\neroaacenc.exe" -q 0.425 -if %s -of %d && "C:\path\to\Neroaactag.exe" %d -meta:artist="%a" -meta:album="%g" -meta:track="%n" -meta:title="%t" -meta:genre="%m" -meta:year="%y""
Make sure that “Add ID3 Tag" is disabled.
dbPoweramp
-q 0.5 -if [InFile] -of [OutFile]- don't forget to include at least one blank space character before your first argument,
- The "[InFile]" and "[OutFile]", as written above, are not variables looking for a substitution. With dBPowerAmp, you literally write them in just like that, as they appear above, with the square brackets.
