Poll
Do you use FLAC or WAVPACK?
FLAC
[ 325 ] (55%)
WAVPACK
[ 222 ] (37.6%)
Neither, I use another losless codec
[ 44 ] (7.4%)
Total Members Voted: 718
Topic: Do you use FLAC or WAVPACK? (Read 97557 times) previous topic - next topic
Reply #126
Hi, I'm new with wavpack and I wonder if it's possible to extract the cue sheet from a .wv as we do with FLAC (metaflac  --export-cuesheet-to=FILE thefile.flac) or the only way is using foobar ?
Thx
Reply #127
WVUNPACK.EXE or WAVPACK.EXE cannot do this, although I have seen discussion with David regarding the ability to automatically extract the cuesheet upon decoding.  This would be double-ace for a self-extracting file IMHO.
My latest mod of Case's Tag will let you do this quite easily, e.g.:
TAG.EXE --tocuea myfile.wv
--tocue <scheme>  : output cuesheet tag to file, name generated from <scheme>
--tocuen <name>   : output cuesheet tag to file <name>
--tocuea          : output cuesheet tag to file, name generated from source
I'm on a horse.
Reply #128
FLAC. Better name. Better file-extension.
But I don't use lossless much, because it's largely a waste of space. Ogg is my thing.
Reply #129
The best part of this codec isn't the speed or the compression, but the foresight of the developer. Every aspect of the codec is exceptionally well thought out. [..] FLAC properly places the emphasis on the simplicity and speed of the decoding. [...] The size difference with regard to WavPack is negligible, so I don't really vote based on this. [...] FLAC has the blessing of Xiph as well as some major players in the hardware and software industries.
Couldn't have said it better, but I can be more brief
Reply #130
*lol* A typical statement for a DAE guy ;D ;D ;D
Well, my 2 Cents:
Im also a convinced FLAC-user, it's fast and flexibel. Moreover, it enjoys a lively "scene" around this
codec making it imho to the codec with best future prognosis.
Reply #131
WavPack.
I started using lossless compression at just about the same time that Rockbox was ported to the iriver H100 series.  WavPack was functional before FLAC in Rockbox, so I chose WavPack.
Since then, I simply haven't had any good reason to switch.  Hardware compatibility is not really an issue.  My portable players run Rockbox and I use Foobar on my PCs, so WavPack is available everywhere I need it to be.  (Besides which, I use 3.97b2 -V5 --vbr-new most of the time for portable use, and WavPack is mostly for archiving.)
Reply #132
Accidentially mad a NULL vote.
I'm planning to move from OptimFrog to WavPack due to tag, speed and size considerations (Optimfrog needs too many CPU cycles and I have plenty of
space left)
Reply #133
correct me if im wrong, but flac doesnt support higher bit depths and samplingrate.
as i use lossless audiocodecs for archiving my audio projects, i use wavpack, since it also supports 24 bit etc...
is flac still lacking those features?
Reply #134
FLAC supports 24-bit audio fine. My understanding is that the FLAC format also handles 32-bit ints, but the reference encoder does not implement it, and FLAC has no support for float data. WavPack handles all integer bitdepths up to 32-bit and also 32-bit floats.
Both codecs handle all sampling rates.
Reply #135
When i use lossless (rarely) it's FLAC.
Both developers seem to be cool, yet FLAC sounds cooler I think
Reply #136
WavPack user.
Single File w/ embedded cue and eac log with -h
To me, WavPack is the perfect balance between the compression size of Monkey's Audio and the Decoding Speed of FLAC.  Plus if I need another lossless type for playback in hardware...pop it into foobar2000 and convert. Done!
After all, we have all chosen lossless so that we are not stuck with ONE format.
- Gow
Zune 80, Tak -p4 audio library, Lossless=Choice
Reply #137
Monkey's Audio 3.99 user (4.01b2 GUI) and batch files.
I liked what Gow had to say and decided to say that I happily broke from the pack and voted other!
I just wish it would store a checksum of the raw pcm data and support piping like flac.
Reply #138
Another great thing about FLAC is the --apply-replaygain-which-is-not-lossless switch in the reference decoder. I use it all the time when I convert to lossy (Ogg Vorbis) so that I do not have to replaygain the lossy files. This is important for me because my HW player do not read the replaygain tags. If FLAC decoder did not have this I could work around that, but it is nice to have it.
Triza
Reply #139
@bryant
ah youre right, foobar doesnt put the highest bit depth to 32 per default. so i encoded at 16 all the time.
Reply #140
Triza
Foobar can do this as well when using the embedded converter for any supported codec. I use it all the time to encode my wavpacks to ogg vorbis.
Reply #141
i just tried flac compared to wavpak and must say that wavpack has a slight better compression rate.
Reply #142
Triza
OK, but I only use Foobar only for playing on my media PC. The main rig is Linux and I do convert with scripts.
Triza
Reply #143
The version at shntool supports piping; I used it to convert my APE collection to WV.  I'm not sure if it supports STDIN, but definately STDOUT.  I think it will do both.
I'm on a horse.
Reply #144
I use Flac because.....
1. Has Hardware Support
2. Is Actively Developed (Thanks Josh!)
3. Widespread Software Support
4. So I can wear my FLAC shirt without being a liar!
Reply #145
I use Monkey's.  It compresses better than either. I don't care about how fast it seeks or its license, or any of that other stuff as I'm not an idealist, nor do  I use it for anything besides archival purposes in ape+cue.
Reply #146
Thanks Synthetic Soul.
I've used the version that you mentioned; I just wish the developer would implement it himself.
Reply #147
WavPack because of its awesome hybrid mode. I'm currently ripping all my cds to the hybrid mode with 320 kbps lossy. i'm gonna burn all the correction files to a DVD-R in case i need to transcode to lossy or to burn an audio cd.
I tried FLAC too, i'm blown away by it's decompression speed (it was like 147 X) but WavPack has better compression speed. i'll be sticking with wavpack.
Reply #148
Ah, sorry; sucking eggs and all that.  Yes.  It seems stupid to not implement piping in the default encoder/decoder.  One of the many reasons that I appreciate WavPack more.
I'm on a horse.
Reply #149
I use WavPack.
(Yes I like the red foobar2000 wv icon)
Unfortunately, I'm quite unhappy when I use Linux. There are few options then.
Basically I just dislike XMMS.
Quod Libet is a really nice piece of program but just refuses to play some of my wv files while other just play fine. Me being blind or something?
Quod Libet uses the gstreamer-wavpack plugin and there are some problems with earlier versions (like 0.8) of that. I don't know my way around Linux yet to know how to upgrade, but that's what you need to do (you might need an updated app also, I don't know). The problem was that WavPack "high" mode files crash the plugin. And, files before 4.0 will not work either, in case you have some of those. I have the same problem with Rhythmbox.
Hope this helps...
I updated everything (Ubuntu, GStreamer and Quod Libet) in the last weeks and now everything works fine indeed. Now I'm a happy man using Linux AND WavPack.
You're a great guy bryant.
