Topic: --alt-presets and lame DLLs (Read 5779 times) previous topic - next topic
I had a request to provide alternative mapping of the --alt-presets within the modified DLL. Therefore, we now have two versions. DLL1 is as before:
1.   Normal (q=5) = --alt-preset standard
2.   Low (q=9) = q=2 (all other switches available)
3.   High (q=2) = --alt-preset extreme
4.   Voice (for voice recordings) = q=5 (all other switches available)
5.   R3Mix preset = --r3mix
6.   Very High Quality (q=0) - --alt-preset insane
For items 1, 3, 5 and 6, all other switches are non-functional. Even if you can change the settings, they are ignored.
DLL2 now maps as follows:
2.   Low (q=9) = --alt-preset fast standard
4.   Voice (for voice recordings) = --alt-preset insane
6.   Very High Quality (q=0) - remains as originally
For items 1, 2, 3, 4, and 5 , all other switches are non-functional. Even if you can change the settings, they are ignored.
If you use Peter Pawlowski's Cool_lame filter, these DLLs also work with that BUT you only get items 1 thru 4 because of the preset limitations within the filter options.
The request arose so that there were four --alt-presets usable thru cool_lame, but it works with CDex too.
You can get these at the usual place:
http://www.inf.ufpr.br/~rja00/
later today.
john33
Yeah!
You can get the sources there too.
john33
You would make me incredibly happy if I could have
--alt-preset <bitrate>
available in a LAME.dll...
Maybe I'm asking too much, but it would make me so happy not having to keep so much free space available in my VOB->MP3 conversion for ripping... (that way I would skip the temporary uncompressed WAV step...)
What do you think? (the currently available standards in the modified dlls are a little too large in size and too unpredictable in bitrate...)
Actually adding support for this would be relatively easy (and is actually planned).. the difficult part would be getting the programs which use the .dll to update their interface to directly support this preset.
Kblood,
Let me have a look and see if there is some way I can 'hack' that in. No promises, but I will have a look.
In the nice, properly implemented way Dibrom is, of course, abolutely correct, but give me a little while to have a look.
john33
Maybe this is TOO ugly for you, but wouldnt it be a simply thing to make the dll use --alt-preset instead of --abr ?
For instance the VobToMp3 program using azid dll and lame dll for making a ac3/vob directly to mp3 without intermediate files lets you use --abr , so there it would be very useful, I think...
But hey, thats just a QuickN'Dirty solution that would fit me
Other ways might be better for the long run
regards
/stefan
oh. btw , I would just like to thank you all for the hard work with the site, and especially Dibrom for the neverending tweaking of lame.
OK... I'm officially in dll hell now. Does ANYONE know if the cvs dll like Mitok's supports the alt presets?
They shouldn't, they are based on the official .dll, which does not support my presets.  The only .dll which does is the unofficial one from john33.
And so the saga continues....
Kblood wanted to be able to use Dibrom's ABR presets in the DLL.
Well, after a very ugly hack and some lengthy testing, I think it's there!  There will soon be a DLL3 available at:
which is a variation on DLL2 as follows:
6.   Very High Quality (q=0) = remains as originally UNLESS VBR Method VBR-ABR is selected. If VBR-ABR is selected, then --alt-preset nnn (ie. --alt preset ABR) is performed for ABR bitrates between 80kbps and 320kbps. With ABR selected, all other switches are non-functional.
I have spent the last several hours testing this BUT I would really appreciate someone else testing it to make sure it is OK. If your testing suggests that it is AOK, then I will post this in place of DLL2 in future and, also, post the source. I really don't want anyone else looking at the source until I am fairly sure it is OK. I am sure that if Dibrom were to look at it he would weep bucket loads!!
So, please test and feedback your results.
(These are Rev9a BTW.)
thanks,
john33
Well, yes, just using common, untweaked ABR would be acceptable, but having those presets available, I would feel a little dumb myself not using them... Unless I have no means of freeing up space, I will go the long but optimal route VOB->WAV->MP3.
And I was thinking precisely of using that program  (www.doom9.org anyone? )
john33:
Great!!! Thanks a lot!! That's efficiency! As soon as I lay my hands on it I will try it (with the latest VobToMp3, now called BeSweet...) and let you know the results.
Now my dvd-backup sessions have got (or gotten) much nicer
The DLLs are already available at the usual place.
Have fun!
Roberto.
Cool!
Thanks man! I will test this tonight.
regards
/stefan
Not wishing to be defeated on all fronts!! You will soon find a revised DLL3 Rev10 at the usual site:
The revised sources are there too. I have cleaned up the code, somewhat, and my testing shows the results using the ABR setting to be bit identical with my own lame.exe(not Intel). If you are using the Intel compile of the exe, you will find the DLL produces slightly smaller files.
Also, if you set an ABR of less than 80kbps, it will default to 80kbps.
I am pretty sure that this is now correct!!
john33
Already uploaded.
