Topic: foo0.9, $caps2() (Read 3302 times) previous topic - next topic
foo0.9, $caps2()
Hey.
Some would say it's nothing, but I've found a bug which irritates me... ;>
I'm using $caps2() in trackinfo panel and playlist view, and foobar interprets two Polish diacritic characters ( 'ś' and 'ż') as a space.
Here's a sample:
Would be nice if someone fixes it. :]
foo0.9, $caps2()
Hey.
I'm using $caps2() in trackinfo panel and playlist view, and foobar interprets two Polish diacritic characters ( '?' and '?') as a space.
Here's a sample:
That seems a bit improbable. If they were caps beforehand, $caps2() does not change them to lower case. You would want to use $caps() instead.
foo0.9, $caps2()
When I use $caps() happens exactly the same. I can live with that... Just wanted someone to notice it and fix it in next beta/stable.
foo0.9, $caps2()
I've had exactly the same problem as you when using $caps2 function in foobar 0.9.3.4 against polish diacritic characters. Every character after ? or ? is converted to capital. It caused a lot of problems to me already after I've ran my scripts against my polish tracks base (2000+ songs). I had to develop workaround script to revert that changes. Hope that foobar2000 developers will fix that in next release.
