Topic: Yalac - Comparisons (Read 215033 times) previous topic - next topic
Yalac - Comparisons
Reply #50
' date='May 2 2006, 05:40 PM' post='388534']
yalacc (filename | --all) [--decode] (-f | [-n] | -h | -i ) [--log]
The extra c on yalacc is for command-line (that way, gui-inclined people can still use the gui, if they want to)
Also, I suggest using "log" instead of "protocol" -- it's more relevant to the english language.
How comes you did steal my latest innovation: "yalacc" !?
The preset options will possibly get a bit modified.
What about overwriting files? Would the GUI-behaviour be ok (for the tests): Overwriting without warning but with added suffix "_d"?
Yalac - Comparisons
Reply #51
Maybe add a target directory option, so that the decoded file is in another directory.  This shouldn't be necessary, though : if filenames are passed correctly, they can be from another folder, and that will not pose a problem.
Are you seriously mad that I guessed what you would call your command-line YALAC?  Sorry
Yalac - Comparisons
Reply #52
My $0.02 USD, I would like to avoid the wildcard function in the command-line version and focus on:
YALAC [-f(ast), -h(igh), -d(ecode) {default=normal}] infile [outfile]
The batch file I test with uses FOR loop, but one problem I ran into LA.EXE was not being able to control the output filename, so I had to resort to using a hack.
Yalac - Comparisons
Reply #53
In that case, (infile | --all) (compression options) (logging on) -o (outputfile) would be best.
Yalac - Comparisons
Reply #54
Yes, because i did read your posts regarding batch processing i allready knew about the need to specify the outputfile.
Would it be ok for now, if the file extensions were fixed?
Would a simple wilcard option hurt?
My current spec looks like this:
YALACC infile [outfile] [-px -l {default=normal}]
infile might be:
Dir\*        (any file in DIR with the proper extension)
Dir\File     (File FILE in DIR
File         (File FILE in current dir)
outfile may only work with a single file spec.
-p specifies preset:
F or 0 = Fast
N or 1 = Normal (Default)
H or 2 = High
I or 3 = Insane
-l switches the log file generation on.
Quick and dirty...
Yalac - Comparisons
Reply #55
Yes.
Sure, I guess  I imagined wildcard-handling being tedious to implement (for some programs).
The spec looks good. As mentioned, I use the batch redirect (>filename) to log filesize (ex. DIR __*.yaa) and operation time (TIMETHIS.EXE). Of course, it would be great to save a few minutes using the calculator if the ratio % and realtime x were output to CON and/or logfile.
Yalac - Comparisons
Reply #56
Quick and dirty...
Looks fine to me for using the presets.
I take it it will encode or decode depending on the extension of the source file?  Edit: I guess wildcard method will have to default to one or the other (most likely encode), unless the format is actually "DIR\*.wav" or "DIR\*.yaa". (NB: I'm not sure what you guys mean by the file extension being "fixed" so I may be going over old ground here )
I don't see the need to specify a switch for the output filename with that setup.
My personal preference would be that "<name>.yaa" is decoded to "<name>.wav"; if "<name>.wav" exists a prompt appears; and a switch is provided to enable automatic overwriting.  However, if we are just talking about a "Quick and dirty..." version for now then the current method is fine by me.
I've been away for a little while but I'm hoping to do some testing with 0.05 soon.  I suppose it depends when yalacc.exe will be released; maybe I should wait until then.
I'm on a horse.
Yalac - Comparisons
Reply #57
I use "%~z1" in the encoding batch file to output the new file's filesize to a log.  Same idea.
The following VBS (Windows Script) file will look at any text files in the same directory for TimeThis' "Elapsed Time" entries and write them (in seconds format) all to a new text file (e.g.: "la.txt" > "la.txt.times.txt").  It's an easy way to scrape TimeThis times from a log created using a redirect.  I'm not sure whether it may be of any use, but here it is anyway.
timethis.vbs:
Dim objFSO, objFolder, objFile
Dim objStream, objOutput, strProcessed
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objFolder = objFSO.GetFolder("./")
For Each objFile in objFolder.Files
  If GetExtension(objFile.Name) = ".txt" Then
    Set objStream = objFile.OpenAsTextStream(1)
    strProcessed = ProcessFile(objStream.ReadAll)
    objStream.Close
    If strProcessed > "" Then
      Set objOutput = objFSO.OpenTextFile(objFile.Name & ".times.txt", 2, True)
      objOutput.Write strProcessed
      objOutput.Close
    End If
  End If
Next
Set objOutput = Nothing
Set objStream = Nothing
Set objFile = Nothing
Set objFSO = Nothing
Function ProcessFile(ByVal strString)
  Dim objRegExp, objMatch, colMatches
  Dim strLine, i, arrPart, sngSeconds
  Set objRegExp = New RegExp
  objRegExp.Pattern = "TimeThis :  Elapsed Time :  (\d+:\d+:\d+\.*\d*)"
  objRegExp.IgnoreCase = True
  objRegExp.Global = True
  Set colMatches = objRegExp.Execute(strString)
  For Each objMatch in colMatches
    arrPart = Split(objMatch.SubMatches(0), ":")
    sngSeconds = (arrPart(0) * 60 * 60) + (arrPart(1) * 60) + arrPart(2)
    strLine = strLine & CStr(sngSeconds) & vbCrLf
  Next
  Set objRegExp = Nothing
  ProcessFile = strLine
End Function
Function GetExtension(ByVal strFile)
  GetExtension = LCase(Mid(strFile, InstrRev(strFile, ".")))
End Function
I'm on a horse.
Yalac - Comparisons
Reply #58
This specification is only a fast approach for the tests. It will change for the public release.
YALACC -mode infile [outfile] [-px -lx -overwrite]
-e          mode encode
-d          mode decode
infile      specify file(s) to be processed
  Dir\*       any file in DIR with the proper extension
  Dir\File    File FILE in DIR
  File        File FILE in current dir
outfile     specify output file or directory, see infile
-px         select encoder preset x
              F or 0 = Fast
              N or 1 = Normal (default)
              H or 2 = High
              I or 3 = Insane
-lx         select log file level x
              0 = no log file (default)
              1 = log compression results
              2 = log compression results and encoder diagnostics
-overwrite  overwrite existing wave files when decoding
In- and output files always have to contain the proper extension ".yaa" or ".wav". Yalac files will always be overwritten without warning. Wave files will be overwritten (again without warning), if the -overwrite switch has been specified. Otherwise the program will stop with an error message.
It's ok to wait until V0.06 for further testing. It's great, that destroid has tested V0.05 and that there were no unexpected results. That's enough for now.
Yalac - Comparisons
Reply #59
Current Progress (V0.06)
Sorry if i should talk to much...
Done:
- Preset FAST and NORMAL now are using Apply Window, which gives about 0.05 percent better compression (on my test corpus).
- Other slight improvements can give another 0.05 percent improvement to FAST and NORMAL on most files.
- Selection of Partition calculator resolution 64 gives another 0.05 percent improvement to FAST. It should now  achieve the same compression as the (slow) FAST preset of V.04.
- Optimizations of the channel decorrelation make FAST 30 percent and NORMAL 10 percent faster (than V.0.05) on my system (caution: maybe CPU-dependent).
- Command line version is done. In addition to my last spec it let's you overwrite the predictor order of the presets.
To do (for V.0.06):
- More speed optimizations of the channel decorrelation.
- Optimization of the compression efficiency of the channel decorrelation. Some files give 0.50 percent better compression in my evaluation. Average may be about 0.20 (dont know yet).
Maybe i will cancel the optimizations of the channel decorrelation for now and release V0.06 this weekend.
  Thomas
Yalac - Comparisons
Reply #60
Take your time if you should wish to, but I don't think our testers will mind an intermediary release ;-)
@Synthetic soul : You'll probably see this, so once we get the command-line encoder, could you make a package with batch files and batch file processors to process the logs / data?  Then, we could all send our results to you and you could sort them in your database...
That would be really great!
Peace,
Tristan.
Yalac - Comparisons
Reply #61
' date='May 5 2006, 02:22 PM' post='389567']
I didn't want to stress the testers too much... For me it would be better to test an intermediary release. If some release shouldn't perform well, it is easier to find the reason, if not too much had been changed at once.
I could sent Synthetic soul soon a possibly buggy pre release to check the command line interface with his scripts. It's only an option.
Yalac - Comparisons
Reply #62
I'm not sure what the priority is for testing 0.06.  Would we be comparing against other encoders, or is the idea that we simply run Yalac on numerous files using all its presets?
I'm quite happy to pass some batch files on if it will help people test, but I'm not sure the database I used in my initial test is adequate for this round of testing.
The way I see it, if we are simply testing how Yalac performs, we need to test a greater variety of files (mono; 24bit; etc).  The database is only really set up to deal with 44.1KHz 16bit stereo files.  If you consider what my pages detailed, it would really just be a table to show that fast is faster than normal, and high compresses better than normal.  We know that already (well, we can assume).
Don't get me wrong, I think amalgamating the results is a great idea.  Joseph Pohm and I have communicated regarding a similar thing.  I think I'm being a little short-sighted and just need some help to understand how and what we would all be testing.
I'm on a horse.
Yalac - Comparisons
Reply #63
To be honest, i don't have an elaborated plan for test design beyond my current interests.
I did work on
- mainly speed optimizations
- improvements of my source code quality
- some slight compression improvements (found some opportunities while evaluating my source code).
Hence current tests should check
a) if the speed optimizations are present on different platforms (especially CPU's)
b) if the speed and source code optimizations didn't affect the reliability
c) if the changes made for the slight compression improvements don't hurt on other files.
For this purposes an evaluation based upon the existing test sets and a comparison with previous results would be quite helpful. For a) and b) the tests sets don't have to be really representative.
Most work for V0.07 will probably again consist of speed optimizations of the channel decorrelation. V0.06 brings algorithmic, V0.07 will bring assembler optimizations.
Reason: I want to improve the channel decorrelation in terms of compression efficiency. The current speed optimizations should guarantee, that later increases of the algorithm complexity will not hurt speed too much. And i really like Yalac to be fast...
V0.08 should contain an improved channel decorrelation. Then it will be really useful to test it on heterogenous file sets to tweak it. Mono and 24-Bit files wouldn't be important here.
Besides testing for my development purposes i am surely interested into comparisons with other compressors! Why else should i look for some tenth of a percent better compression...
I hope this shows some direction for possible further testing.
  Thomas
P.S.: Some time in the future i will activate my ominous pre filter, which gives up to 4 percent better compression on some rare problem files! But this one needs really much evaluation on big test sets.
Yalac - Comparisons
Reply #64
Yes, thank you.  So in essence we should be testing Yalac 0.06 against previous Yalac tests, to ensure that speed and compression have improved.  Also, we should ensure that decompressed files are not corrupt.  We can compare against other codecs using the new Yalac results and the previous results for the other codecs (if we are testing on the same corpus).
With this in mind I don't see how all results can be amalgamated into my system, unless testers are prepared to  format their previous results into something I can easily import.
I'm on a horse.
Yalac - Comparisons
Reply #65
@Synthetic soul : If you make your batch files available, or give us VBScripts or whatever, the few testers that we are can convert our data to your format, and send it to you!  It's just a problem of whether you can do something with the data afterwards.
Yalac - Comparisons
Reply #66
No,  V0.06 will bring both. That's the reason, why i didn't send V0.06 to the testers last weekend.
By the way: Preset FAST is now 60 percent faster than V0.05 on my system! This may be the limit, please don't expect more optimizations here. And we have to try, if this improvement will show up on other systems to.
  Thomas
Yalac - Comparisons
Reply #67
V0.06 is done
Changes:
Compression efficiency and presets:
- Selection of Partition calculator resolution 128 gives another 0.05 percent improvement to FAST. It should now achieve the same compression as the (slow) FAST preset of V.04.
Speed:
- Algorithmic and assembler optimizations of the channel decorrelation.
- Rework of my basic signal processing functions. Dangerous: I didn't touch them for years and i did know why!
- Because my compiler doesn't support proper code alignment, i had to do some strange things to help him out. I hope that there will be no trouble on operating systems with more strict security checks.
- Implementation of a memory manager to avoid cache trashing caused by too many simultaneous uses of the same cache line set.
- Rework of my File-IO. To my surprise this has been most important for the speedup of decoding. Possibly i will have to do some adaptions for specific operating systems.
- Changed floating point precision from double to single. Can sometimes reduce compression efficiency by 0.01 to 0.02 percent.
Probably other systems will benefit far less from my optimizations than my good old pentium 3. Maybe that the optimizations are compensating weaknesses of my CPU that are not present on modern CPUs. Nevertheless i want to provide some data as a baseline:
Speed up of encoding:
Preset FAST    55 %
Preset NORMAL  20 %
Preset HIGH    10 %
Speed up of decoding:
Preset FAST    25 %
Command line:
Command line version is done. Unfortunately the binary is nearly as large as the GUI-Version. Delphi seems to put most of the basic GUI libraries into the binary of a console application, if the code uses exception handling. The initialization of the program may take considerably longer than without the GUI libraries. The compression speed of small audio files may suffer from this overhead.
In addition to my latest specification there is a new command line switch:
  -cx  Evaluate test ©ase x.
If i will ask the testers to evaluate the effect of internal encoder parameter variations, they can switch between them via this option. For instance: Please try -c1 to -c5.
Other:
- Clean up of source code. Could give new errors...
- File format changed!
Release:
I hope to send the new version to the following testers within the next 24 hours:
Destroid
Josef Pohm
Shade[ST]
Synthetic Soul
Only reason for this selection: I haven't heard from the other testers within the last 10 days and i don't want to fill their mail box with new versions they possibly currently don't need.
Any of them can sent me an email anytime, and i will sent the current version.
What should be tested:
Comparison with V0.05:
- The speed and compression performance of presets FAST, NORMAL and HIGH.
- The decoding speed.
Evaluation of internal encoder options:
I wrote a SSE-Implementation of the Levinson-Durbin-algorithm used for the calculation of the predictor coefficients. It is disabled by default.
You can activate it via command line option -c1 and check it with Preset HIGH. There is definitely no reason to check it with other presets!
On my system this option gives only 1 - 2 % more speed on HIGH. I would like to know, if other systems are getting more out of it, before i will try more SSE optimizations.
Plans for V 0.07:
- Improvement of the compression efficiency of the channel decorrelation.
  Thomas
Yalac - Comparisons
Reply #68
My exams are now done, I'd be glad to test the encoder on my system.
Could synthetic soul provide batch files to test?
Thanks,
Tristan
Yalac - Comparisons
Reply #69
On SSE optimization :
=== New test ===============================================
Linear Predictor
  Predictors:                                32
  Optimize quantization:                  Nein
  Apply window:                              Ja
Frames
  Duration:                                100 ms
Channel decorrelation
  Enable:                                    Ja
  Full search:                            Nein
Frame partition calculator
  Resolution:                                64
  Search level:                              1 (0 - 3)
Bit coder
  Optimize Choice:                        Nein
  Optimize Partition:                      Nein
Diagnostics
  Verify:                                  Nein
  No output:                              Nein
  Use MMX:                                  Ja
  Use SSE:                                  Ja
=== Bitcoder ===============================================
Resolution
  N:                                          0
=== LPC Predictors =========================================
Number
    4                                      4.31  %
    8                                      9.88  %
  12                                    19.68  %
  16                                    22.57  %
  24                                    17.48  %
  32                                    26.08  %
  48                                      0.00  %
  64                                      0.00  %
  80                                      0.00  %
  96                                      0.00  %
  112                                      0.00  %
  128                                      0.00  %
  160                                      0.00  %
  192                                      0.00  %
  224                                      0.00  %
  256                                      0.00  %
  Mean:                                  19.48 *
Resolution
  N:                                    115927
  Minimum:                                5.00
  Mittelwert:                              8.96
  Maximum:                                11.00
  Verteilung
    5                                    0.001 %  (1)
    6                                    0.203 %  (235)
    7                                    4.246 %  (4922)
    8                                  17.197 %  (19936)
    9                                  56.678 %  (65705)
    10                                  20.745 %  (24049)
    11                                    0.931 %  (1079)
    12                                    0.000 %  ()
    13                                    0.000 %  ()
    14                                    0.000 %  ()
    >                                    0.000 %  ()
ShiftNum (Resolution reduction)
  N:                                    115927
  Minimum:                                3.00
  Mittelwert:                              3.00
  Maximum:                                3.00
  Verteilung
    0                                    0.000 %  ()
    1                                    0.000 %  ()
    2                                    0.000 %  ()
    3                                  100.000 %  (115927)
    4                                    0.000 %  ()
    5                                    0.000 %  ()
    6                                    0.000 %  ()
    7                                    0.000 %  ()
    >                                    0.000 %  ()
Resolution / Predictor number        Min    Mean    Max    StdDev
    4                                    6.00    8.97  11.00    0.67 Bit
    8                                    5.00    8.69  11.00    0.88 Bit
  12                                    6.00    9.01  11.00    0.73 Bit
  16                                    6.00    9.08  11.00    0.73 Bit
  24                                    6.00    8.97  11.00    0.85 Bit
  32                                    6.00    8.93  11.00    0.75 Bit
  48                                    0.00    0.00    0.00    0.00 Bit
  64                                    0.00    0.00    0.00    0.00 Bit
  80                                    0.00    0.00    0.00    0.00 Bit
  96                                    0.00    0.00    0.00    0.00 Bit
  112                                    0.00    0.00    0.00    0.00 Bit
  128                                    0.00    0.00    0.00    0.00 Bit
  160                                    0.00    0.00    0.00    0.00 Bit
  192                                    0.00    0.00    0.00    0.00 Bit
  224                                    0.00    0.00    0.00    0.00 Bit
  256                                    0.00    0.00    0.00    0.00 Bit
ShiftNum / Predictor number          Min    Mean    Max    StdDev
    4                                    3.00    3.00    3.00    0.00 Bit
    8                                    3.00    3.00    3.00    0.00 Bit
  12                                    3.00    3.00    3.00    0.00 Bit
  16                                    3.00    3.00    3.00    0.00 Bit
  24                                    3.00    3.00    3.00    0.00 Bit
  32                                    3.00    3.00    3.00    0.00 Bit
Bits for whole predictor set          Min    Mean    Max    StdDev
    4                                      33      45      53      3 Bit
    8                                      49      76      97      7 Bit
  12                                      74    110    141      8 Bit
  16                                      98    144    181      13 Bit
  24                                    139    196    271      21 Bit
  32                                    182    245    334      23 Bit
  48                                      0      0      0      0 Bit
  64                                      0      0      0      0 Bit
  80                                      0      0      0      0 Bit
  96                                      0      0      0      0 Bit
  112                                      0      0      0      0 Bit
  128                                      0      0      0      0 Bit
  160                                      0      0      0      0 Bit
  192                                      0      0      0      0 Bit
  224                                      0      0      0      0 Bit
  256                                      0      0      0      0 Bit
Bits per predictor                    Min    Mean    Max    StdDev
    4                                    8.25  11.15  13.25    0.71 Bit
    8                                    6.13    9.52  12.13    0.83 Bit
  12                                    6.17    9.19  11.75    0.71 Bit
  16                                    6.13    9.01  11.31    0.84 Bit
  24                                    5.79    8.15  11.29    0.87 Bit
  32                                    5.69    7.66  10.44    0.73 Bit
Absolute Sum of coefficients          Min    Mean    Max    StdDev
    4                                    8.67  11.62  13.51    0.77 Bit
    8                                    9.09  11.91  14.36    0.88 Bit
  12                                    9.75  12.65  14.85    0.79 Bit
  16                                  10.04  13.13  15.29    0.95 Bit
  24                                  10.44  13.02  16.03    0.98 Bit
  32                                  10.60  13.06  15.81    0.83 Bit
Absolute Sum of shifted coefficients  Min    Mean    Max    StdDev
    4                                    5.67    8.62  10.51    0.77 Bit
    8                                    6.09    8.91  11.36    0.88 Bit
  12                                    6.75    9.65  11.85    0.79 Bit
  16                                    7.04  10.13  12.29    0.95 Bit
  24                                    7.44  10.02  13.03    0.98 Bit
  32                                    7.60  10.06  12.81    0.83 Bit
=== Frame partition ========================================
SubFrameNum
  N:                                      72252
  Minimum:                                1.00
  Mittelwert:                              1.60
  Maximum:                                3.00
  Verteilung
    1                                  61.543 %  (44466)
    2                                  16.442 %  (11880)
    3                                  22.015 %  (15906)
    4                                    0.000 %  ()
    5                                    0.000 %  ()
    >                                    0.000 %  ()
=== Joint Stereo ===========================================
Modes
  N:                                      36126
  Minimum:                                0.00
  Mittelwert:                              1.25
  Maximum:                                2.00
  Verteilung
    0                                  21.641 %  (7818)
    1                                  31.288 %  (11303)
    2                                  47.071 %  (17005)
    >                                    0.000 %  ()
=== Results ================================================
01. American Idiot.yaa
64.18 % -  29.1 * -    5.987 sec
02. Carl Orff - Fortune plango vulnera.yaa
48.95 % -  41.5 * -    3.855 sec
02. Carl Orff - Veris leta facies; Omnia Sol temperat.yaa
31.18 % -  61.1 * -    5.622 sec
02. Parallel Universe.yaa
59.39 % -  48.8 * -    5.548 sec
02. Wolfgang Amadeus Mozart - O Isis und Osiris (Sarastro - Chor).yaa
41.39 % -  53.2 * -    3.700 sec
03. Who's sorry now.yaa
27.95 % -  48.1 * -    3.782 sec
04. Burke - Johnston - Pennies From Heaven.yaa
55.58 % -  44.5 * -  13.726 sec
04. Carl Orff - I. Primo vere - Omnia sol temperat.yaa
39.80 % -  54.0 * -    2.002 sec
04. Japanese sandman.yaa
22.89 % -  49.2 * -    4.314 sec
05. Koop - Summer Sun.yaa
64.10 % -  17.1 * -  13.122 sec
05. Wolfgang Amadeus Mozart - Rex tremendae majestatis.yaa
44.97 % -  28.3 * -    4.970 sec
06. The Subject Was Faggots.yaa
44.04 % -  25.7 * -    7.470 sec
08. Morgana King - It's De-lovely.yaa
36.95 % -  38.2 * -    3.521 sec
08. Wolfgang Amadeus Mozart - Requiem in D Minor, KV 626, VIII. 08.
Lacrimosa.yaa  40.82 % -  31.5 * -    7.984 sec
11. Nil (Instrumental).yaa
20.58 % -  40.7 * -    3.367 sec
11. Throb.yaa
54.05 % -  45.4 * -    6.019 sec
Compression:    45.44 %
Duration:      95.03 sec
Speed:          38.01 * real time
Linear Predictor
  Predictors:                                32
  Apply window:                              Ja
Frames
  Duration:                                100 ms
  Enable:                                    Ja
  Full search:                            Nein
  Resolution:                                64
Bit coder
Diagnostics
  Verify:                                  Nein
  No output:                              Nein
  Use MMX:                                  Ja
  Use SSE:                                Nein
Resolution
  N:                                          0
Number
    4                                      4.31  %
    8                                      9.88  %
  12                                    19.68  %
  16                                    22.57  %
  24                                    17.48  %
  32                                    26.08  %
  48                                      0.00  %
  64                                      0.00  %
  80                                      0.00  %
  96                                      0.00  %
  112                                      0.00  %
  128                                      0.00  %
  160                                      0.00  %
  192                                      0.00  %
  224                                      0.00  %
  256                                      0.00  %
  Mean:                                  19.48 *
Resolution
  N:                                    115927
  Minimum:                                5.00
  Mittelwert:                              8.96
  Maximum:                                11.00
  Verteilung
    5                                    0.001 %  (1)
    6                                    0.203 %  (235)
    7                                    4.246 %  (4922)
    8                                  17.197 %  (19936)
    9                                  56.678 %  (65705)
    10                                  20.745 %  (24049)
    11                                    0.931 %  (1079)
    12                                    0.000 %  ()
    13                                    0.000 %  ()
    14                                    0.000 %  ()
    >                                    0.000 %  ()
  N:                                    115927
  Minimum:                                3.00
  Mittelwert:                              3.00
  Maximum:                                3.00
  Verteilung
    0                                    0.000 %  ()
    1                                    0.000 %  ()
    2                                    0.000 %  ()
    4                                    0.000 %  ()
    5                                    0.000 %  ()
    6                                    0.000 %  ()
    7                                    0.000 %  ()
    >                                    0.000 %  ()
    4                                      33      45      53      3 Bit
    8                                      49      76      97      7 Bit
  12                                      74    110    141      8 Bit
  48                                      0      0      0      0 Bit
  64                                      0      0      0      0 Bit
  80                                      0      0      0      0 Bit
  96                                      0      0      0      0 Bit
  112                                      0      0      0      0 Bit
  128                                      0      0      0      0 Bit
  160                                      0      0      0      0 Bit
  192                                      0      0      0      0 Bit
  224                                      0      0      0      0 Bit
  256                                      0      0      0      0 Bit
SubFrameNum
  N:                                      72252
  Minimum:                                1.00
  Mittelwert:                              1.60
  Maximum:                                3.00
  Verteilung
    1                                  61.543 %  (44466)
    2                                  16.442 %  (11880)
    3                                  22.015 %  (15906)
    4                                    0.000 %  ()
    5                                    0.000 %  ()
    >                                    0.000 %  ()
Modes
  N:                                      36126
  Minimum:                                0.00
  Mittelwert:                              1.25
  Maximum:                                2.00
  Verteilung
    0                                  21.641 %  (7818)
    1                                  31.288 %  (11303)
    2                                  47.071 %  (17005)
    >                                    0.000 %  ()
64.18 % -  39.6 * -    4.403 sec
48.95 % -  34.5 * -    4.641 sec
31.18 % -  31.3 * -  10.980 sec
59.39 % -  43.7 * -    6.196 sec
41.39 % -  53.7 * -    3.663 sec
27.95 % -  60.7 * -    2.996 sec
55.58 % -  50.5 * -  12.088 sec
39.80 % -  58.9 * -    1.834 sec
22.89 % -  62.3 * -    3.409 sec
64.10 % -  38.5 * -    5.836 sec
44.97 % -  42.3 * -    3.321 sec
44.04 % -  50.0 * -    3.836 sec
36.95 % -  51.3 * -    2.625 sec
Lacrimosa.yaa  40.82 % -  41.7 * -    6.033 sec
20.58 % -  58.0 * -    2.366 sec
11. Throb.yaa
54.05 % -  44.6 * -    6.136 sec
Duration:      80.38 sec
Speed:          44.93 * real time
Linear Predictor
  Predictors:                                32
  Apply window:                              Ja
Frames
  Duration:                                100 ms
  Enable:                                    Ja
  Full search:                            Nein
  Resolution:                                64
Bit coder
Diagnostics
  Verify:                                  Nein
  No output:                              Nein
  Use MMX:                                  Ja
  Use SSE:                                  Ja
Resolution
  N:                                          0
Number
    4                                      4.31  %
    8                                      9.88  %
  12                                    19.68  %
  16                                    22.57  %
  24                                    17.48  %
  32                                    26.08  %
  48                                      0.00  %
  64                                      0.00  %
  80                                      0.00  %
  96                                      0.00  %
  112                                      0.00  %
  128                                      0.00  %
  160                                      0.00  %
  192                                      0.00  %
  224                                      0.00  %
  256                                      0.00  %
  Mean:                                  19.48 *
Resolution
  N:                                    115927
  Minimum:                                5.00
  Mittelwert:                              8.96
  Maximum:                                11.00
  Verteilung
    5                                    0.001 %  (1)
    6                                    0.203 %  (235)
    7                                    4.246 %  (4922)
    8                                  17.197 %  (19936)
    9                                  56.678 %  (65705)
    10                                  20.745 %  (24049)
    11                                    0.931 %  (1079)
    12                                    0.000 %  ()
    13                                    0.000 %  ()
    14                                    0.000 %  ()
    >                                    0.000 %  ()
  N:                                    115927
  Minimum:                                3.00
  Mittelwert:                              3.00
  Maximum:                                3.00
  Verteilung
    0                                    0.000 %  ()
    1                                    0.000 %  ()
    2                                    0.000 %  ()
    4                                    0.000 %  ()
    5                                    0.000 %  ()
    6                                    0.000 %  ()
    7                                    0.000 %  ()
    >                                    0.000 %  ()
    4                                      33      45      53      3 Bit
    8                                      49      76      97      7 Bit
  12                                      74    110    141      8 Bit
  48                                      0      0      0      0 Bit
  64                                      0      0      0      0 Bit
  80                                      0      0      0      0 Bit
  96                                      0      0      0      0 Bit
  112                                      0      0      0      0 Bit
  128                                      0      0      0      0 Bit
  160                                      0      0      0      0 Bit
  192                                      0      0      0      0 Bit
  224                                      0      0      0      0 Bit
  256                                      0      0      0      0 Bit
SubFrameNum
  N:                                      72252
  Minimum:                                1.00
  Mittelwert:                              1.60
  Maximum:                                3.00
  Verteilung
    1                                  61.543 %  (44466)
    2                                  16.442 %  (11880)
    3                                  22.015 %  (15906)
    4                                    0.000 %  ()
    5                                    0.000 %  ()
    >                                    0.000 %  ()
Modes
  N:                                      36126
  Minimum:                                0.00
  Mittelwert:                              1.25
  Maximum:                                2.00
  Verteilung
    0                                  21.641 %  (7818)
    1                                  31.288 %  (11303)
    2                                  47.071 %  (17005)
    >                                    0.000 %  ()
64.18 % -  57.1 * -    3.055 sec
48.95 % -  51.5 * -    3.109 sec
31.18 % -  61.7 * -    5.567 sec
59.39 % -  44.9 * -    6.025 sec
41.39 % -  54.5 * -    3.609 sec
27.95 % -  62.4 * -    2.913 sec
55.58 % -  22.9 * -  26.612 sec
39.80 % -  9.8 * -  11.049 sec
22.89 % -  37.1 * -    5.727 sec
64.10 % -  22.7 * -    9.888 sec
44.97 % -  33.4 * -    4.212 sec
44.04 % -  46.7 * -    4.111 sec
36.95 % -  54.6 * -    2.464 sec
Lacrimosa.yaa  40.82 % -  25.0 * -  10.069 sec
20.58 % -  60.2 * -    2.277 sec
11. Throb.yaa
54.05 % -  29.8 * -    9.163 sec
Duration:      109.87 sec
Speed:          32.87 * real time
With FAST mode, it seems SSE slows things down.  Further lookout for this type of behavior would be necessary.
Yalac - Comparisons
Reply #70
' date='May 13 2006, 01:49' post='391904']
You are really fast!
But please don't post the whole protocol file. Most of the info isn't helpful yet.
Summary of your results:
Run1: MMX + SSE
Run 2: MMX
Run 3: MMX + SSE
You see the speed difference between Run 1 and Run 3, which use the same settings? And regarding Run 2: I advised to test SSE on Preset HIGH. You did use Preset FAST with 32 Predictors. But SSE will never be used with less than 64 Predictors!
Hence all three test runs have used exactly the same optimizations: Always MMX, never SSE.
The big speed variations are most probably beeing caused by variations of your test systems: Disk caching issues or disturbances by background activity. Under controled conditions all three runs should have achieved about the same speed (maybe within the range of +/- 10 %; on my system i achieve +/- 3 %).
BTW: Activation of the protocol function slows encoding down.
Yalac - Comparisons
Reply #71
It seems my disk caching is quite unstable, then.  I did hear thrashing sounds between the encoding of two songs.  Also, run 1 is command-line; runs 2+3 are GUI.
I am currently testing Insane mode with/without SSE on my corpus (which compresses quite a bit, as you can see..)
Results will be posted in approx 5 min.
Yalac - Comparisons
Reply #72
' date='May 13 2006, 02:48' post='391912']
That's important. There can be speed differences between command line and gui versions.
Yalac - Comparisons
Reply #73
These results are actually quite surprising, as they show discrepancies in the SSE optimizations versus compression ratio.  It should normally be the same, no?
Insane (search level 4) + SSE
Compression:    44.65 %
Duration:     1289.32 sec
Speed:           2.80 * real time
Insane (search level 3) + SSE
Compression:    44.66 %
Duration:      955.93 sec
Speed:           3.78 * real time
Insane (search level 3) + No SSE
Duration:     1161.98 sec
Speed:           3.11 * real time
Yalac - Comparisons
Reply #74
' date='May 13 2006, 03:06' post='391920']
I am quite new to SSE... I would have thought, that it gives the same results as single precision arithmetic performed by the floating point unit (FPU). Mabe it differs in the handling of rounding and underflows (i didn't care for the setting of the right SSE-Flags). But 0.01 percent deviation shouldn't be too important. But we should keep an eye on it (?).
Far more interesting for me to see a significant speed benefit for SSE. At least big enough to try a bit more SSE optimizations later.
  Thomas
P.S. Could you please post your CPU-type? Encoding speed for INSANE is more than two times higher than on my system. Surprising, because the speed of FAST isn't higher than on my system. FAST seems to be very sensitive to disk io performance.
