Topic: Eac Wont Detect My Drives! (Read 3857 times) previous topic - next topic
Man this sux, whenever i fire EAC it will only display the generic dvd drive of daemon tools, already uninstalled it, runned norton windoctor to clean the registry and still i cant see my plextor 24x. I need serious help here
I had trouble with this when I used Adaptec's latest ASPI drivers.  I went back to ForceASPI's version, 4.60 I believe, and then EAC worked fine again.
Every passing minute is another chance to turn it all around.
Adaptec's 4.60 ASPI drivers work great for me under Win98 and Win2k; 4.70 has caused me some issues under both OS's so I went back to 4.60.
God kills a kitten every time you encode with CBR 320
I'll second (or third) that w/ forceaspi.  I'm running win xp pro sp 1 and adaptec's aspi 4.7x is totally botched.  Forceaspi works terrific for me.
-Jeff
-Jeff
I fourth that. Win XP. But instead of downgrading to ASPI 4.60, i chose to install ASAPI, the alternative ASPI layer.
try adding the wnaspi32.dll to your EAC folder. http://www.nero.com/en/index.html#download
example C:\Program Files\Exact Audio Copy <---place it here
Damn! Same problem by me. EAC just detects virtual drives or drives, which are not connected with an Audio-cable to my soundcard.
Usually I don't need such a cable, because I always rip and never hear Audio before ripping. But because of this problem, that EAC don't want to detect my drives, I build in one to test my drive - and I can listen to music from the drive with WinAMP... But EAC doesn't believe, that there's a drive with an Audio-CD
Even Nero accepts my CDs and is able to save tracks.
wnaspi.dll can't be downloaded from nero.com. ftp://ftp6.nero.com/wnaspi32.dll is unreachable for the moment.
Any ideas? I wonder why EAC suddenly doesn't work... I installed daemon tools long time ago, and I could rip fine... I didn't install any aspi-drivers since then...
  Hope, I can rip again, so fast as possible
Wenn jemand Mitgefühl braucht - ich kann's vorheucheln
I'm a happy Adaptec's ASPI user with the help of a single registry key. Combination of WinXP, EAC, latest ASPI and this works fine here.
I'll try this Aspifix too. Tanks.
But my EAC is working now. I found the wnaspi.dll from Nero, and copied it to EAC. Yet it didn't work, but after clicking "use installed external Aspi-Interface" in EAC-Options, my drives showed the songtitles under EAC again.
So I can rip now  but I hope, I'll have no disadvantages with "external Aspi-Interface", instead of "native Win32-Interface"...
Any comments to that of other users, using these settings?
And there is still one thing not working: EAC can't connect to the host of CDDB-database. Hope the reason for this is the CDDB-Server, not my EAC....
Ok, I have no problems any more... right present for christmas...
EAC is working fine, as it did before. Aspi-drivers seems to be important under WinXP, and is seems, that they often cause problems...
For all having the same problem:
Download Asapi.exe from e.g. http://www.vob.de/de/Downloads.htm
With this ASAPI Interface, u'll have no problems any more, as far as u change win32-Interface to Aspi-Interface in EAC-Options...
bye
