Topic: Foo_osd (Read 128109 times) previous topic - next topic
Foo_osd
Reply #125
-Change the default green colour
You can already change the default green color.
If you just go to the Format tab in the On-Screen Display options, select Volume Display in the drop-down list, and add:
$rgb(63,255,63)
to the top of the Format text box.  If you edit those numbers you can get any color you like. $rgb(255,0,0) will be red $rgb(0,0,255) will be blue, etc.
Foo_osd
Reply #126
$rgb(63,255,63)
Oh i must have been blind (Cit. Tim Buckley  )
I was trying to change it only with the colours button, and not directly in the code...
Thank you very much!!!
Now only the rounded corners are needed
Foo_osd
Reply #127
Hi
Great plugin!
I have small audio setup, where 1 laptop is a part of it, and it is more or less dedicated to play music via foobar2000.
This plugin is perfect for this.
My proposals for further developments:
1. It would be great if plugin or foobar itself would prevent system screenserver or monitor shutdown (similiar like in video players small checkbox) when music is playing or pause is pressed. Then with hide option checked I would have on the screen OSD while computer is idle.
2. OSD for full screen. Another option is to have this OSD as a screen saver.
3. Album art as a background.
I don't have any experience with plugins, so please forgive if any point is not possible at all.
Foo_osd
Reply #128
Is it possible to cache a value for the next time Interval Update happens?
E.g., I want to use %playback_time% (e.g., 0:15) to retrieve a substring from a tag.  But I want that value to display for many seconds after 0:15, not JUST for the second between 0:15 and 0:16.
Foo_osd
Reply #129
I'm not sure what this means, but attempting to reply to the following example -
condition = over 15 seconds:
$ifgreater(%playback_time_seconds%,14,<OVER>,<UNDER>)
condition = over 15 seconds, and under 20 seconds:
$ifgreater(%playback_time_seconds%,14,$ifgreater(%playback_time_seconds%,19,<DONE>,<OVER>),<UNDER>)
Does that help, or is there more to it?
Foo_osd
Reply #130
@kode54: Thanks for latest update to foo_osd! Now volume bar looks much nicer.
Few questions/requests:
1) How do I specify different foreground and background/outline colors for text and volume bar?
2) The background color I have set (black) is not being used for text outline (see screenshot below). Instead it seems to be inverting the foreground color. Can I set the outline to a fixed background color?
3) Why is text not centered on screen? Please can you adjust the calculations?
Foo_osd
Reply #131
You can't at this time. I suggest using different overlays for the text and for the volume bar, as with the default configuration. Yes, all of that configuration data can be configured differently for each overlay you create, and there is no hard limit to the number of overlays you can create.
The background color is not used for the outline color. You must specify six hex codes, or use $rgb(r,g,b,r,g,b) to specify two different colors.
The default overlays are slightly off-center, so title information appears above the default volume bar. Please adjust the positions on the first tab of the configuration page.
The positions are relative to the selected screen. If the Window setting is Left, the overlay will be placed to the left of that position, so that its right edge falls on that spot. Center, it will be centered on that spot. Right, it will be placed to the right of that spot. The vertical position is always the vertical center of the window.
Foo_osd
Reply #132
I have a fair few dance music mixes that last 1 hour+.
How would I go about getting the track info (artist and title) to display every 10 minutes or so while the track is playing?
Foo_osd
Reply #133
kode54,
I run Desktops, which I discovered accidentally and like it much. It feels more like Linux desktop switching and it's instant unlike MS Virtual Desktops toy.
foobar global shortcuts work as expected, but OSD doesn't show in current desktop, but in the one foobar in run from.
Can you do some magic?
Foo_osd
Reply #134
@romor, I'm using Dexpot which is similar to Desktops and the on-screen display works fine regardless of which "desktop" I'm in, I'd suggest giving that a try. I believe it's free for private use.
http://www.dexpot.de/
Foo_osd
Reply #135
Thanks for the tip, using it right now
It performs very well yet feature rich
Foo_osd
Reply #136
Yeah, working around that other desktop switcher would be quite troublesome. I would have to launch a separate thread, or possibly separate executable, and set its default desktop to the current input desktop. That's assuming the desktop permissions allow me to switch to it like that. (Separate desktop objects are what are normally involved with switching to the screen saver and the login screen.)
Foo_osd
Reply #137
At many times the OSD is shown but not hide after timeout. How solve this mistake?
It reproduce some times when doubleclicked sound in playlist.
foo_osd ver 1.73, foobar2k ver 1.2.3
Foo_osd
Reply #138
Any chance of supporting the new global notification messages in Windows 8? Then Foobar could also update info on lockscreen.
This OSD plugin works fine on Windows 8 by the way, but I like the idea of a global notification message system.
Foo_osd
Reply #139
Sounds like a job for a completely different component.
Foo_osd
Reply #140
Just a single question - is it possible in future, that foo_osd will show notifications/confirmations about actions taken with keyboard shortcuts? Like functions turned on/off. Fo example: I'm pressing Shift+S and I see "No Display Standby: turn on" , I'm pressing it again and I see "No Display Standby: turn off". Or Ctrl+Shift+S and I see "Save configuration: executed" ?  Is it possible with foobar to get such informations and display them?
Foo_osd
Reply #141
A status bar tracker? Hmm, I'm not sure if that's even possible.
Foo_osd
Reply #142
Basically that's what I was asking for - whether foobar offers some kind of interface, that lets catch this kind of informations (calls for changing settings/running components/executing functions) and use them - for exaple to display it in external component
I was just wondering, because it could be very convenient option.  Sometimes I press keyboard shortcuts erroneously and I'm surprised that something is not working as it - but in fact it wasn't turned on/off as I haven't pressed proper key. Additionally some infrequently used keyboard shortcuts are bit messed in my memory  . If I got something like this then I would be shure what function I triggered  . But this is just a question / idea. Not another feature request
Foo_osd
Reply #143
My OSD's style-setting is 'Display forever', the position is centered, 'top:' = 1.
Please have a look at my screenshot: I want to have the black background that surrounds the displayed text flush with the height of the title bar of active windows so that it does no longer hide parts of their menus.
I cannot figure out how to achieve this. Does anyone know?
Foo_osd
Reply #144
I wanted to make OSD display forever if foobar is paused, and hide after couple of seconds otherwise, but I think that's not possible.
If so, and there is empty space for a tick box in "Automatically pop-up on" group, is it worth adding something like "... don't hide on pause"?
Foo_osd
Reply #145
Is it possible to, somehow, trigger the display whenever I rate a song? (I have a hotkey for rating, of course)
Foo_osd
Reply #146
No. I already asked about similar functionality. Foobar doesn't provide interface that could be used for such functionality.
Foo_osd
Reply #147
I understand. Thanks.
Foo_osd
Reply #148
Hello,
I am still a noob about foobar and just installed OSD, nice feature, thanks for your work!
However, I can't see the text when I'm within a graphical fullscreen application, e.g. a game. For example, I tried Borderlands 2 and League of Legends and it's not shown. Both applications ran in fullscreen, not windowed-mode.
Is this something that foo_osd can't provide? Would it help to use a windowed-mode or so?
Thanks for your feedback and best regards!
Foo_osd
Reply #149
Hm, can somebody tell me if it's possible at all? That would be great! Thanks!
