Topic: 0.9 SDK: set_playing_playlist() with random (Read 1789 times) previous topic - next topic
Hi;
I have some code that uses the static_api_ptr_t to the playlist manager to call set_playing_playlist.
If a next/previous command is then issued using the playback_control it correctly selects the song from the new playlist.
If a random command is issued however it seems to not use the playing_playlist just set, but rathar the active playlist.
I just wanted to point that out; if that is the intended behavoir it is no big deal.
