Topic: foo_winamp_spam 0.9 beta (Read 347724 times) previous topic - next topic
Winamp API emulator is designed to create a fake Winamp 1.x window which will act as a wrapper between applications written to use the Winamp API and foobar2000. Only a small subset of the Winamp API is implemented, but most of the useful functionality is there.
I've updated my Winamp API emulator to support foobar2000 0.9. Unfortunately I don't have any applications installed to test a number of features such as remote control of "Winamp" (pause/play/stop/next/prev/etc), I've only tested the "query" commands such as the ones provided by r1dll.
Beta3 is here, please post feedback.
http://r-1.ch/foo_winamp_spam-0.9beta3.7z
It's working here with my mIRC script, well I can get the filename but not the current playtime & total file length nor the Kbps of the file, for the rest I'm not sure. All of these worked with 0.8.3 so it should be possible, good luck and thank you already
[a href="index.php?act=findpost&pid=375278"][{POST_SNAPBACK}][/a]
How are you trying to get those values? I've tested it with R1DLL which uses the Winamp API and it seems to work fine.
i use winamp cd case to view album art... and it worked in foobar 0.8.3 but its not working now in v 0.9
Evillyrics is now working though, i just dont know why winamp cd case isn't
also, some scripts that worked in samurize with foobar v0.8.3 are not working either
but thanks so much for updating, at least evillyrics is working now =)
edit** also, controls on the winamp cd case work to control foobar, for example clicking next track in winamp cd case changes the track in foobar, but still it's not recieving the information or something
**edit again
heres some pics that might help solve the problem
this is foobar v0.8.3, in the 'fake' or whatever window it shows the playlist number
foobar v0.9, the playlist number in the winamp window is 0, so im guessing thats the key to the problem
I'd never use it again cause sometime ago i had it in my fb2k 0.8.3 config, and my fb ate about 50 mb ram only cause of this plugin, sry ... never again
i could give some more clues y it did that, but not in my actual state
Ok, it should be compatible with Winamp CD case now. Unfortunately I still can't get the playlist number to work, it seems the API call fails.
  t_size plIndex, trackIndex;
 if (static_api_ptr_t<playlist_manager>()->get_playing_item_location (&plIndex, &trackIndex))
I have that in my on_playback_new_track and it always returns false. Perhaps the playing item isn't updated until after on_playback_new_track returns? Where should I be using this...
Beta2:
http://r-1.ch/foo_winamp_spam-0.9beta2.7z
thanks! that was really quick! works great!
thanks again soo much
I can get all the infos with beta2 BUT there seem to be a problem, requests take between 3 and 4 seconds to get returned. I think with beta1 it was instantaneously returned. And with 0.8.3 version I'm sure it is. (Edit: I just tried; doing a loop request for data I get 1every answer 3seconds with 0.9 and 5-6 per second with 0.8.3)
I can't seem to replicate this, all my IPC_ requests are fulfilled nearly instantly. What messages are you sending?
Well it's strange, if I try to individually requesting the filename through r1dll or tracklenght & trackposition through another dll I use everything is returned very quickly, but when I use the mirc script it takes several seconds.. but it can't be the script part as it's very fast with the old foobar.. I just don't get it, it's 7.30am here and I have to go to bed. I'll see tomorrow.
Hello. I'm using your plugin for sending songs name into Evil Lyrics. It is working perfect in foobar 0.8.3 but this new version changes few letters we use in Croatian language. Character encoding is ISO-8859-2:
It works well with mir.dll plugin for mirc to show what I am listening to
[span style='font-size:8pt;line-height:100%'][edit] I guess that Advanced Media Player Info for samurize has nothing to do with foo_winamp_spam[/span]
Ok, I think I fixed this. The main problem though is the Winamp API has no unicode support so everything has to be converted to multibyte which greatly limits support of international characters.
With Advanced Media Player Info, try opening the foobar2000 console and checking for any foo_winamp_api warnings.
[a href="http://r-1.ch/foo_winamp_spam-0.9beta3.7z]http://r-1.ch/foo_winamp_spam-0.9beta3.7z[/url]
Shouldn't the API emulator settings appear in "tools"? I think "display" is ment for settings that change the visible appearance of the player.
EDIT: another note, foo_winamp_spam seems to "spam" my console. Happens when I launch Evillyrics
WARNING : foo_winamp_spam: Unsupported WM_USER, lParam 1243292.
WARNING : foo_winamp_spam: Unsupported WM_USER, lParam 1242024.
Odd. I get the same thing too. None of those message ids appear in the Winamp SDK so I've no idea what EvilLyrics is trying to do.
increased cpu usage in latest version...definitely cause of winamp_spam
EDIT:
Just needed a new profile...working ok now
Someone couldn't mirror this could they? I can't connect to r-1.ch ... it just times out all the time no matter the browser I try.
It works well but I get these "Unsupported WM_USER" messages also. They don't appear when using beta 1 version, only in beta 2 and 3.
great, evillyrics is working!
thank you very much!
My English sucks, sorry!
EDIT:
[a href="index.php?act=findpost&pid=375600"][{POST_SNAPBACK}][/a]
what do you mean you needed a new profile?
bc im having this problem and i need a fix
EDIT:
[a href="index.php?act=findpost&pid=376069"][{POST_SNAPBACK}][/a]
delete the foobar2000.cfg file from your folder
Cant express how happy i am this has been ported to 0.9
mIRC now playing script (gtsdll) and Winamp CD Case are working again \o/
Thanks allot r1ch.
[a href="index.php?act=findpost&pid=376153"][{POST_SNAPBACK}][/a]
i did that and foobar v0.9 still remains at 10%+
but without the plugin its rarely above 0%
I'm getting the same console spam here.
Also, quick question.  Anyone have any ideas why my keyboard would only be able to control foobar when it's in the foreground? I get my LCD information just fine, but none of the buttons work unless foobar is in focus.
