Topic: Mp3 Backup Software? (like "burn To The Brim") (Read 2709 times) previous topic - next topic
Hi.
I'm looking for a software that will be to backup my MP3 collection on cdrs, in a way that each disk will be filled to its maximum, but not in image form but just mp3s so the disk will be playable in my rio volt (-;
I've just found some soft called "burn to the brim". It's able to make a files lists so they can be exported to Nero, but it doesn't make a list for the last disk, so it's useless... Do you know something else that is able to do this? Thanks!
I don't have any other software to recommend, but I do use Burn to the Brim (and love it!!)
I'm not sure if you've used the move option but it will accomplish what you want...here's what I do:
Set the checkmark next to the move option on and set a directory (I usually create a directory called X:\Burn).
When you run the program it will create directories called 1, 2, 3,..etc (depends how many full CDs worth of files you have) and move the contents for each respective CD to these directories.  It makes for easy burning with Nero.
It also leaves whatever is leftover (usually less than a full CDs worth) in it's original folder.
Hopefully, that solves your problem.
The problem is that it's my collection that I want to leave on HDD... So if I move it, I'll just break all my music folders order...
