foo_browser Reply #775 – 2008-11-04 13:20:08 I am looking to use the album panel to browse for %album artist% if present, if not %artist%. is this not the way to go?Code: [Select]$if3(%album artist%,%artist%,<MISSING>)thank you
foo_browser Reply #777 – 2009-09-20 22:02:19 it's not needed. the functionality is already built into columns UI. just add some filter panels to your layout.
foo_browser Reply #778 – 2009-10-01 09:23:12 Hey guys please check this out.I'm trying to make fb2k look like iTunes using THIS tutorial. Now it says you need foo_browser.dll. I read here it's not needed. In step 11 it tells you to add browser panels. They're not available without this plugin. I can't find a download link. Can somebody help me out plz? Thx.
foo_browser Reply #779 – 2009-10-01 09:52:37 foo_browser is as outdated as the tutorial you are mentioning. You should follow the advice, which is given in the post above yours, and use the filter panels instead of the browser panels.
foo_browser Reply #780 – 2009-10-06 09:50:50 Quote from: fbuser on 2009-10-01 09:52:37foo_browser is as outdated as the tutorial you are mentioning. You should follow the advice, which is given in the post above yours, and use the filter panels instead of the browser panels.Hi, this is my configuration for use with 7" touchscreen lcd:since the browser is outdated and I fear it will always be less compatible with future versions of foobar, is there a way to get tabs with linked filters (genre/album artist/artist/album so when i click a genre it change the album artist/artist/album filters) inside with the current plugins? I've tried and searched around but without results; Many thanks to whoever can help me in some way.Fabio
foo_browser Reply #781 – 2009-10-06 10:35:32 Realy nice - which kind of display is used in your scenario?
foo_browser Reply #782 – 2009-10-06 11:42:53 Quote from: allerlei on 2009-10-06 10:35:32Realy nice - which kind of display is used in your scenario?It's a carpc vga touchscreen monitor like this: http://www.cartft.com/catalog/il/442
foo_browser Reply #784 – 2009-10-06 11:59:28 Quote from: Fabio258 on 2009-10-06 09:50:50is there a way to get tabs with linked filters (genre/album artist/artist/album so when i click a genre it change the album artist/artist/album filters) inside with the current plugins?For all those that won't read the thread here goes:This (foo_browser) component is obsolete as ColumnsUI already includes a panel with the exact same function. It's called "Filter Panel" instead of this "Browser Panel"....now can we close this thread?
foo_browser Reply #785 – 2009-10-06 12:18:48 Quote from: odyssey on 2009-10-06 11:59:28Quote from: Fabio258 on 2009-10-06 09:50:50is there a way to get tabs with linked filters (genre/album artist/artist/album so when i click a genre it change the album artist/artist/album filters) inside with the current plugins?For all those that won't read the thread here goes:This (foo_browser) component is obsolete as ColumnsUI already includes a panel with the exact same function. It's called "Filter Panel" instead of this "Browser Panel"....now can we close this thread?I've tried to obtain linked TABBED filter panels with current ColumnsUI without success. Can you please explain me how to do this? Otherwise I must use this obsolete component and yes, you can close this thread...Thanks Fabio
foo_browser Reply #786 – 2009-10-06 12:23:41 Quote from: allerlei on 2009-10-06 11:52:21Thanks - quite expensive, isn't it?Yes, but you can find a lot of similar more inexpensive monitors (e.g. on ebay)Fabio
foo_browser Reply #787 – 2009-10-06 13:51:46 Quote from: Fabio258 on 2009-10-06 12:18:48I've tried to obtain linked TABBED filter panels with current ColumnsUI without success. Can you please explain me how to do this? Otherwise I must use this obsolete component and yes, you can close this thread... Thanks FabioIn Filter preference page, set 'Filter precedence' to 'By field list above'. It works
foo_browser Reply #788 – 2009-10-06 14:25:23 Quote from: Hamallainen on 2009-10-06 13:51:46Quote from: Fabio258 on 2009-10-06 12:18:48I've tried to obtain linked TABBED filter panels with current ColumnsUI without success. Can you please explain me how to do this? Otherwise I must use this obsolete component and yes, you can close this thread... Thanks FabioIn Filter preference page, set 'Filter precedence' to 'By field list above'. It worksMany thanks Hamallainen, it works! Fabio
foo_browser Reply #789 – 2009-10-06 15:35:48 Quote from: odyssey on 2009-10-06 11:59:28For all those that won't read the thread here goes:This (foo_browser) component is obsolete as ColumnsUI already includes a panel with the exact same function. It's called "Filter Panel" instead of this "Browser Panel"....now can we close this thread?<xiphmont> OK
