Topic: Monkey's audio commandline parameters for 0.9 (Read 4448 times) previous topic - next topic
I used to use 0.8.3 special, it converted my pae files keeping tags. Would like to do the same in 0.9, so I need MA commandline parameters. I know, that I must use -c4000 - what else?
[a href="index.php?act=findpost&pid=374257"][{POST_SNAPBACK}][/a]
pae=?
anyway, %s %d -c4000 should do the trick
pae=?
[a href="index.php?act=findpost&pid=374260"][{POST_SNAPBACK}][/a]
What is pae=?
And, BTW, your switch works very strange: although the files have all fetures of ape files including tags, they are wavs according to size!
What are you talking about?
%s %d -c4000
... will create Monkey's Audio files using Extra High compression.
pae=?
What is pae=?
3.142 approximately.
I'm on a horse.
My pae=ape! :-)
Nope, it creates huge ape files - the size equals to wavs!
bitrate is 1029! :-)
Aha, the problem is solved! I had to choose lossless instead of lossy in the settings. I didn't expect it could affect anything! :-)
However, I'm wondering, why is this, and what has happened.
Take a look at the text in the "Bit depth control" group on the "Commandline encoder settings" dialogue.
With lossy files the BPS in the dropdown will be used, with lossless the source bitdepth is used.  Therefore, if the dropdown is set to 24 the "lossy" file will be 24 BPS while the "lossless" will be 16 BPS, no doubt.
Have a look at the file properties and check the "bitspersample" under "Other info".
I'm on a horse.
Thanks a lot, now I see.
