Topic: Wanted v0.9 plugin ports (Read 698704 times) previous topic - next topic
Reply #526
hi,
could someone post the menu addons plugin?
I cant find it and  acropolis.lokalen.org seems to bie offline.
thanks in advance
Reply #528
...although that subject seem to be somehow avoided in the whole forum, I dare to mention it: CD-TEXT
Will I be banned now or just ignored like all who asked for cdtext - extraction ability of Foobar before?
Reply #529
foo_input_usf now exists! Only gsf to go and finally foobar can play every format I used Winamp for! =P
Yep, I'm glad foobar2000 now has USF support. There's now a official page for the fb2k port of 64th Note here:
http://joshw.info/?page_id=6
Seems that the dev is going to rewrite the CPU emulation code into seperate classes to allow for multithreaded conversions using foobar2000's convertor component...
Reply #530
My wish:
A foobar2000 DVD player plugin!
I need my concert DVDs sounding as good as when having to rip them to play through foobar2000 with all my favorite DSPs settings etc.
It's a lofty goal but I thought I'd put it out there anyways.
Maybe someone could just reverse engineer from here to get a head start or something:
http://www.videolan.org/vlc/download-sources.html
Regards,
Steven
Reply #531
I would very much like my CrystalFontz 634 screen to work so...
foo_crystalcontrol2.dll
[Juli@ v0.979][foobar2000 v0.9.5.1b2][foo_out_asio.dll v1.2.6]
Reply #532
One of the the Great Ones (Foosion or Kode54, I don't remember) mentioned that he'd like to make a bassmidi plugin. That would be reallly great, that's a very good, fast and small midi player which can use the sf2 patches that come with Creative cards or can be downloaded. It would be so very great not having to load xmplay when I'd like to play midi
Reply #533
AFAIK,  kode54 expressed interest in making a BASSMIDI-based MIDI component.
Reply #534
Hi! my first post here:) any chance for foo_winamp_input for v0.9? or is there any other way to use winamp's input plugins with foo v0.9?
Reply #535
Thanks a lot for info !
what about foo_ui_panels.dll? Doesn't seem to be developed yet!
besides,Is there any components superseded for foo_cwb_hooks ?
Thanks in advance
Reply #536
foo_dmusic (plays dml files used by certain games like blood 2 etc) was nice to have though not it has never been essentiell. I would like to see it ported, but I guess there is no demand but for me ^^
EDIT: Link to source is here http://209.200.127.55/products.aspx?id=foo_dmusic
I'd like to see it ported as well, although only if it gets redone so it is not as unstable/slow as it is now (if that is even possible for the task that plugin is accomplishing).
Reply #537
Can't I know is this foo_input_monkey new version component can't run in foobar2000 0.9.5.2?
So the latest version foo_input_monkey can run in at foobar2000 0.9.5.2 is which version foo_input_monkey?
Reply #539
Hello,
the upper link is very strange. There's written, post is out of date. But if I click it, I'm coming on the same page.
If got a request. I'm searching a foo_dsp_nogaps or foo_gapkiller dsp. I've got mp3 contineus mixsets, splitted in serveal files with this typical annoying gaps on track change.
I'd like to export the file names as cue-sheet (works, 'cause correct plugin) AND export all files as a single mp3-File. I've got several foobar version from 0.8 to 1.1. I've also got c/c++ skills. If there is no current port I'd like to convert it myself. I'd like to have that DSP very much.
So, how do I start, where do I get the source code, what do I have to change in the code to get it running?
Greetings from Germany
Reply #540
Might the skip silence DSP, built-in to foobar2000, be of use in this case?
Reply #541
If you refer to my nogaps / gapkill dsp, I already tried that skip silence DSP out. It doesn't work. The smallest value for that dsp are 200ms. Thats still to large.
I also think there is need something special to obtain a continues mix without any gaps as output.
Reply #542
There is also Gapless Crossfader (foo_dsp_crossfader.dll) by Acropolis.
Reply #543
Thank you very much. It's working very well except it's not reliable to 100%. It's a little difficult to configure it. I set the dB threshold to 97 but it still cuts to much of the track of. See here:
It seems even if the threshold is set to 100 it still works not accurate enough.
