Topic: Wanted v0.9 plugin ports (Read 758772 times) previous topic - next topic
Reply #375
It is not possible to split the functionality of an input service across multiple instances, so no, you cannot implement tagging and playback of a given format in separate components.
So what if you guys release a version of foo_input_std without WMA support, so that another dev can handle tagging. Win win situation?
hi
Reply #376
foo_music_title_bar.dll
Plugin home page
I don't know how many people use this plugin, it's not ver well known I think. But it's quite handy. It's able to place several buttons, and title song and elapsed time on the title bar of every on-top window. This enables you to handle foobar fast and everytime, without having to click outside your window, or minimize the window. I hope someone will port it soon!
Please add this plugin to wanted ports list...
Reply #377
I don't know if such plugin already exists, but I definitely could use a volume control that can be inserted in the DSP chain. I would also like it to include a peak/RMS meter so that I can see what is going in and coming out of various DSP plugins.
It would be nice if could acommodate multichannel audio streams.
My favorite headphone processing plugin- the dolbyhph.dll loaded via the Dolby Headphone bridge seems to have a limiter built in that chokes on 5.1 streams if the music is mastered hot.
Some music sounds really good on headphones if preprocessed by the Channel Mixer first. But it too lacks master output volume control. It only has a few relative volume controls.
A volume control/meter with multiple instance support would be sweet.
I know there is the RG control- I would like something a bit more flexible and advanced.
Reply #379
foo_oggpreview
realy useful plugin
Reply #380
foo_oggpreview has been integrated into the converter, and it's not limited to Ogg Vorbis anymore.
Right click - Convert - Generate previews
Reply #381
foo_infobox updated to 2.0.3      2006-06-25
http://gro.clinux.org/frs/download.php/160...infobox_v203.7z
foo_dsp_atsurround
Latest version:     0.1.4c
Released:    5th July 2006
Page:http://www.andrewlabs.com/atsurround/introduction.php
Download:http://www.andrewlabs.com/cgi-bin/unicount...ound_0.1.4c.exe
foo_dsp_ssrc    update
for foobar2000 Ver. 0.9.2 (161KB)
Latest Version : 0.55
Released : 2006/6/8
http://otachan.com/foo_dsp_ssrc_055.7z
Reply #383
I ported foo_dts to foobar2000 0.9. There is no configuration, tagging is always enabled and dynamic range compression disabled. It will use tag formats present in file when possible, but adds APEv2 when there are no tags or only ID3v1. foo_input_dts / sources.
Edit 2006-07-12: Uploaded new version, .cue playback started always from the beginning of the file.
Reply #384
Hey Case, any chance of a port for foo_record?
Reply #385
I´m waiting for  foo_uie_simple_spectrum
Reply #386
I ported foo_dts to foobar2000 0.9. It will use tag formats present in file when possible, but adds APEv2 when there are no tags or only ID3v1.
Hi Case, welcome back.
You might have noticed that, in the mean time, Acropolis has also ported this plugin to 0.9 (and foo_dsp_skip_silence too). It does the job (when you have the VC++2005 runtime installed). I just mentioned this here in case (no pun) confusion arises between these plugin versions.
I guess your plugin will write tags only when a tag changes? Well I hope so.
Reply #387
foo_bluetooth_ctrl
Unless I've completely missed something, there's currently no way to use a symbian phone as a bluetooth remote for foobar 0.9 (I haven't even been able to find something that sends global hotkeys to windows). I've just upgraded from 0.8.3 and it's the one thing I really miss. I don't think the author is planning further development but the sources are available.
topic:
http://www.hydrogenaudio.org/forums/index....showtopic=18670
project page:
http://fb2k.oxygenite.org/
Reply #388
"foo_input_std (update requested to read LAME encoder infos + option to force tags format)"
As of 0.9.2 there is an option to force mp3 tag formats under the advanced section in preferences.
I would still like the ability to read LAME encoder info again though.
Reply #390
I really miss foo_uie_dbexplorer. It was simply the quickest and easiest way to access my audio libray in foobar. At the click of a mouse I could switch genres, artists, albums, even listen to music by year. I could combine genres, ie. listen to just Jazz and R&B or Metal, Rock and Classic Rock. I don't know who created this gem, but please, oh please update it for 0.9.
Reply #393
Foosic was updated to v1.0 beta 8
Get it here: http://foosion.foobar2000.org/0.9/foo_sic-1.0_beta_8.zip
EDIT: Postet wrong link
Context menu now features "get tags from foosic.org" but it seems to be non functional right now.
Version 1.0 beta 8 of foo_sic is available for download.
This release should fix issues with foobar2000 0.9.3. It also caches FooID fingerprints, so if the same song gets played twice while foobar2000 is open, the fingerprint will only need to be computed once. The cached fingerprints are not saved persistently.
The option on the advanced preferences page have no effect yet.
Reply #395
Will you recompile and upload it again or will it stay until beta 9 is ready?
Reply #396
welcome back, case!
do you think port your crossfader to 0.9 ?
Music is my first love.
Reply #397
Foosic was updated again (foo_sic 1.0 beta 9):
http://foosion.foobar2000.org/0.9/foo_sic-1.0_beta_9.zip
The nonfunctional stubs (context menu, CD ripper integration) have been removed. Submitting fingerprints works again. The switch in advanced preferences regarding remote files is now functional.
Reply #398
foo_dsp_hrtf
Reply #399
foo_centercut can be taken off the wanted list, I did it here (it has been renamed to foo_dsp_centercut).
