Topic: Wanted v0.9 plugin ports (Read 749577 times) previous topic - next topic
Reply #300
Just a suggestion. This thread should be stickied, if at least temporarily. I don't know anywhere else where you can find such a complete collection of ported plugins.
Reply #302
May I add, the most complete English collection of ported plugins.
Reply #304
foosion's panel-free foo_vis_simple_spectrum
stimulating the audio nerve directly
Reply #305
Who will write plugin like foo_openwith....  I really indeed to write it since now it is possible to assign buttons to commands
Reply #306
Acropolis ported foo_dts to 0.9
Reply #307
foo_info_samurize.dll is updated and and a new  plugin called foo_vis_samurize2.dll is included in the new-released samurize 1.64 package.
Download @ http://www.samurize.com/
Reply #308
AlbumArt Panel has been updated by gfngfgf
Version 0.175 (May 26, 2006)
Plugin homepage
Download
Change log
Source
Known bugs and planned features:
  • BUG: display is blank on startup if image path is relative (i.e., "components\default.*")
  • BUG: when switching to a playlist with no items, display is blank
  • CTRL+drag to copy image
  • allow multiple instances (very low on the priority list)
Please be aware that your "transition time" setting will be reset to 300ms when you upgrade to this version.
I added automatic cycling of sources during playback in this version.  If you don't like the automatic cycling, it's easy enough to disable on the "Behaviour" tab.  Another feature I added was that Album Art Panel now responds to items being added to the playlist.  The main benefit is that now, if you have "Auto send to playlist" enabled in Album List Panel, the album art will be updated as you browse the Album List.  It's not exactly the same as the old "external control" option from 0.8.3, but I think it's a pretty good approximation.
I've been making a lot of tweaks to how the album art changes when you change tracks or use "Next Source" and "Previous Source", so any kind of unexpected behaviour you see, please let me know and I'll take a look at it.  I'm probably going to make the location of the "No Cover" art separate from the regular sources list in the next version, and that should take care of a few of the lingering bugs that I'm seeing.
Reply #310
seldaek, THANK YOU for this thread, it is indispensible
wouldn't it be great if it were stickied?
Reply #311
foo_g15
Reply #312
Indeed, it's not in list: that little and useful plugin written by phi.
foo_follow_cursor_reset
Reply #313
Yes. At first it was, then it became unstickied (don't know why). Well, OK. We're the foobar2000 search community. Searching for updates, finding out about new fb2k betas (0.92b4) by accident...
Reply #314
This post should be sticked!
Reply #315
source to foo_run ,but i dont exacly witch version of API it is....
Reply #316
foo_music_title_bar.dll
Plugin home page
I don't know how many people use this plugin, it's not ver well known I think. But it's quite handy. It's able to place several buttons, and title song and elapsed time on the title bar of every on-top window. This enables you to handle foobar fast and everytime, without having to click outside your window, or minimize the window. I hope someone will port it soon!
Reply #317
foo_infobox updated (2.0.2 version)
Reply #319
You may want to update the download link for foo_uie_quicksearch. The real link is this one.
Reply #320
I would also add that you made the need for a foo_playlistfind port obsolete, with the inline search feature you added in the last version of quicksearch (thanks for that, by the way).
Reply #321
update
foo_uie_lyrics   0.3.0.0     June 4, 2006
0.3 (fb2k 0.9)
update
Tube Sound (foo_dsp_tube) 0.6    25.05.2006
- added: New limiter algorithm.
0.6 (fb2k 0.8.3)
0.6 (fb2k 0.9)
Reply #323
Thank you, Seldaek, for this very useful thread.
And if I may add a request to the moderators, please, make this a sticky.
Reply #324
It used to be sticky at the very beginning, but for some reason it didn't stay long.
Nevertheless I third this request.
