Topic: Wanted v0.9 plugin ports (Read 749587 times) previous topic - next topic
Reply #225
I need a shoutcast DSP, sigh
Reply #228
umm amip?
Reply #230
did some digging, and is it true that there is no way right now to skin foobar 0.9? every component that used to do that (that i found  ) has been discontinued. or is there any other way i'm not seeing here to tune the foobar looks after columns_ui??
Reply #231
pano: An UI plugin is among the most complex kind of plugins you can do for fb2k. The set of users capable of writing a good UI plugin and the set of users wanting a shiny skinned UI are probably quite disjoint. It's not that impossible though, all you need is good knowledge of the Windows API, the fb2k API and C++.
Stay sane, exile.
Reply #232
foo_dsp_ssrc is updated by Otachan.
I'm Korean.
My english is poor. : (
Reply #233
I'd like to have the ability back to save http streams, like it was possible with messer's modification of foo_read_http.
Reply #234
At this point there is no way, except for changing your Windows theme.
Reply #236
Hi, I have once seen a screenshot of a plugin that provided a "user friendlier" interface for creatingthe tag data. Common fields like Artist, Album, Year, Genre etc. were given with boxes next to them to insert the information.
I cannot remember the name of that plugin and cannot  find the site where I have seen that screenshot, screening the 2 lists at the start of the thread did not help either. Therefore I cannot determine if it is already mentioned or not. Can anyone help or have I been taking crazy pills?
Thanks,
preatorian
Reply #237
I think you mean foo_infobox.
Reply #238
update for:
album art and track info @ http://stephan.kochen.nl/proj/foobar2000.html
columnui @ http://music.morbo.org/components.php
WARNING:
Dunno if I'm the only one but, I updated track info, and lost all my configs... now I have to do it all over again
Same goes when I updated colomnui. And old album art isn't detected anymore, I had to update it too (see the "note:" link, its a version made by foosion).
EDIT:
foo_browser and foo_playlist_tree also updated for new columnui
Reply #239
Yep, all these were already marked updated in the first post;)
Although I just had the same issue with TrackInfo so I'll add a warning..
Reply #240
oh I havn't checked before, my bad
at least I'm not the only one who had problem
Reply #241
wont update anything til i need it. im fine with my actual 9.1 config with the older ui-columns version.
why do u update everything even if there isnt any improvement?
Reply #244
Is there any plugin for 0.9 that will show just a search box and will search the current playlist, compatible with columns ui? Some sort of interface version of the shift+f search.
Yes, it's called foo_playlistfind, but afaik it's not out for 0.9 yet.
Any news on the 0.9 port of foo_playlistfind?
Reply #247
My bad, sorry mate
Reply #248
foo_uie_quicksearch offers this capability, among others. I will port it to 0.9 but it may take a while since I want to finish all foreseen improvements before.
The owner of this thread may want to add foo_uie_quicksearch [derived from foo_uie_search] to the first post.
Reply #249
foo_ui_minilyrics
MiniLyrics v4.3.2175 for foobar2000 v0.9 is out today.
This is a similar program to foo_uie_lyrics but more lyrics database to download.
ps: It sometimes crashs my foobar (c++ run-time error).  Try out yourself if you interested.
[edit] It now works fine now.  Probably fresh installed minilyrics being blocked by firewall cause it to crash? Don't know... But it works all fine now.
There is one vital thing that minilyrics doesn't (and probably can't) offer that foo_uie_lyrics had. That is the ability for total integration into the user's layout. I do not want a floating window above the player and everything else. I want a plugin that would be a part of my foobar layout that will never move and when i minimize foobar, it will go with it. I am just saying this because I am hoping that the statement to have us try minilyrics doesn't mean that this one will not be ported. foo_uie_lyrics and minilyrics are just too different and the latter will not serve my needs.
Anyone who takes himself too seriously always runs the risk of looking ridiculous; anyone who can consistently laugh at himself does not. -- Havel
