Topic: Music files moved... (Read 9030 times) previous topic - next topic
This is my problem:
I have moved my music directory and now my playlists are inutils.... how can i point my playlist to my new song path???? There is a way?
This is my problem:
[a href="index.php?act=findpost&pid=364754"][{POST_SNAPBACK}][/a]
It depends what sort of playlists they are I think. If it's just library playlists or playlists generated by a set of parameters then update your database and refresh the query. If it's a playlist that you made by placing every track in it manually then I don't know of a way of updating them within foobar (though there may well be one).
There's two work around ways I can come up with off the top of my head, though I haven't tried either. You could move the files back to the original location (so foobar recognises them) then create a "playlist" metadata field and write the same value to all the tracks in each playlist. Once you move them to the new destination you could then just run a query using this value. Alternatively open up your playlists with a text editor and use a find and replace function to change part of the filepaths. I'm sure there is a beter way of doing this however.
This is my problem:
[a href="index.php?act=findpost&pid=364759"][{POST_SNAPBACK}][/a]
Very thanks... but what is the difference between a playlist generated by a set of parameters and one created by my self manually???
Ps: I don't understend all on the metadata question...
If you have them in a specific order and you don't want to put them back in that order manually then save the playlist to a file if you haven't already. Close foobar. Open your playlist file with notepad. Click Edit>Replace... and in the first field type in the old path that all of the songs are in (C:\My Music, D:\Downloads, etc.) and in the second field type in the path that they are now in. After it's done, save it and open it in foobar. That's how I would do it.
If you don't have them in a specific order, just empty the playlist and drag the folder that your music is in now into the foobar playlist and sort them how you want them.
[a href="index.php?act=findpost&pid=364771"][{POST_SNAPBACK}][/a]
I tried in this way but when i change the path my playlists in foobar are empty...
For example... I changed d:\Private with d: and all seems to be ok but when i try to load a playlist this one is empty... and if I change it again to the original path (d:\Private) in the playlists there are all my songs but i can't hear them for the different location.... what i'm doing wrong?
I used textpad to do this work because when I tried to do this with notepad on restoring the original text parts, the playlist result empty yet....
ps: Sorry for my english... im italian
I just meant if you can generate a playlist buy using a tag such as %play_counter% or %rating% you wouldn't have a problem. And I'd ignore the metadata method, using a text editor would probably be easier. I'm afriad I don't understand the problem you're having with it though.
[a href="index.php?act=findpost&pid=364790"][{POST_SNAPBACK}][/a]
The problem is that if I replace the text in my playlist file with a text editor (I use textpad) and after i load the playlist in foobar, this one is empty...
You replaced D:\Private with D: right? Hmm, I just tried it and it doesn't work. That's odd. It always worked with Winamp playlist files. Maybe foobar writes them a certain way. I guess the only thing is to create a new playlist and just drag the whole lot of them into foobar. Did you have them sorted in any special way?
foobar2000's .fpl files are a binary format, and the user cannot edit them directly (ie, with a text editor).  What I would try doing is saving all your playlists to .m3u (which is a text format), then doing the search and replace.  If you have many playlists, you can right-click the playlist tabs or playlist switcher and select "save all playlists" (at least with Columns UI, you can).  Then you can load the .m3u's back into foobar2000.
[a href="index.php?act=findpost&pid=364878"][{POST_SNAPBACK}][/a]
Yes... i tried this and now work... thanks very much...
Another question... there is a possibility to autoupdate a playlist on foobar start?
not that I know of. Unless foo_playlist tree can automatically scan the database, refresh a library node and then send this to the playlist on startup. I'd have a look at this plugin anyway if you haven't got it already. Oh and foo_dirwatch is currently in development and might be able to do some useful stuff but I haven't been keeping up with it.
I have a question of my own. Is there a way to find and replace text from multiple files rather than opening up each m3u playlist individually, when the text to be replaced is  the same in each case?
Edit: Ignore that, a word macro can do it very easily
Hi there,
I have the same problems after I relocated some music folders.
After all these years, is there any way foobar can handle that issue natively or any component that can do that?
Or do I have to process dozens of playlists the same way that was mentioned above (save m3u8 playlist > edit with notepad)...
Well at least there is Notepad++ and Regular Expressions...
Nevertheless, any help appreciated
P.S. I have my playlists organized with plorg
Thank you both for the quick reply!
Just tried it, works as it should.
