Topic: lock foobar-window (Read 7199 times) previous topic - next topic
lock foobar-window
hello, there!
is there a way to lock foobar's window, so that noone can alter it (e.g. the columns, tabs, etc.) and/or is there a way to maximize foobar and to keep it like this, for example for a party-jukebox, so that noone has access to the desktop, explorer, and so on. (could be done with another app)
also, how do I save my config for columns_ui including all my prefs regarding the panels, titleformatting and stuff?
(I am a bit confused about all the different configs, I can save, import/export.)
thank you !
lock foobar-window
is there a way to lock foobar's window, so that...
I'm pretty sure the answer is basically "no". A kiosk mode/plugin would certainly be great, but I haven't been able to find a good solution for foobar2000.
A search for "kiosk" returns these relevant threads -
http://www.hydrogenaudio.org/forums/index....=37204&hl=kiosk
http://www.hydrogenaudio.org/forums/index....=37258&hl=kiosk
http://www.hydrogenaudio.org/forums/index....=33377&hl=kiosk
http://www.hydrogenaudio.org/forums/index....=19990&hl=kiosk
also, how do I save my config...
For a complete backup:
1) backup foobar2000.cfg. If "preferences > core > startup > enable user profile support" is enabled, then the config files are stored in "C:\Documents and Settings\<user-name>\Application Data\foobar2000\..." for each user. If not, then the config is just stored in the foobar2000 installation directory.
2) Your columns ui config can be backed up as an .fcs file via "preferences > display > columns ui > 'other' tab > importing/exporting"
3) backup all your plugins by copying/zipping the "foobar2000/components/" directory.
lock foobar-window
is there a way to lock foobar's window, so that noone can alter it (e.g. the columns, tabs, etc.) and/or is there a way to maximize foobar and to keep it like this, for example for a party-jukebox, so that noone has access to the desktop, explorer, and so on. (could be done about another app)
best solution I've come up with:
Using foo_fullscreen and a Stickie program
lock foobar-window
[{POST_SNAPBACK}][/a]
thank you for the information! didn't know that this is called Kiosk-mode..
[a href="http://img98.imageshack.us/my.php?image=partmodefoobar5xu.png][/url]
[a href="index.php?act=findpost&pid=359762"][{POST_SNAPBACK}][/a]
thank you too! especially the hint for the users to not piss about... is great!
this could be also be done oral, though.. ;-)
lock foobar-window
yeah I know
I've even got it set so that the sticky comes up when they start playback using foo_scheduler though for some reason the note likes resizing itself slightly. It would be cool if this could be done via a plugin but I guess it's not worth anyone's effort.
lock foobar-window
yeah I know
[a href="index.php?act=findpost&pid=359877"][{POST_SNAPBACK}][/a]
would be a nice gimmick, though
lock foobar-window
Such a cool idea! I would love to see a plugin that incorporates all of this once .9 is finalized.
