Topic: Aac Error Message? (Read 3511 times) previous topic - next topic
Aac Error Message?
I am getting the following error message when I try to encode a wav file to aac
ERROR[-1]: EncodeInit() error!
The commandline I used was
aacenc -normal -if "c:\original.wav" -of "c:\test\original.aac"
Aac Error Message?
That error was easy to reproduce, your output directory doesn't exist. Try to output the file to a directory that exists.
Aac Error Message?
I'v just realised that the wav file I'm using is corrupt!
However, when I encode wav to la why does the la playback in slowmo, when I decode la to wav again, the wav is ok???
Any ideas?
Aac Error Message?
You computer probably isn't fast enough to decode LA in realtime. It's probably the most CPU-intensive format in playback.
