Topic: Boost AC3 volume without re-encoding (Read 24864 times) previous topic - next topic
I've demuxed an AC3 file (DD 5.1 stream) from a DVD movie. Trouble is, i find the overall volume to be a little low. Is there a way to increase volume without reencoding, like mp3gain style?
Would like to avoid re-encoding as this will result in quality loss. Thanks.
ac3 is always low, enable DRC on your decoder (if its ac3filter turn on drc and crank up the preamp for it, maybe even move up the main gain)
Vorbis-q0-lowpass99
lame3.93.1-q5-V9-k-nspsytune
I'm not sure if this is the right thing to do here, but technically it is possible to do a lossless gain change like it can be done for AAC files -- but only in steps of 6 dB. (I guess no program has been written to do this yet. So this reply is not of much use for you unfortunately.)
I just wanted to mention it.
Sebi
Re: Boost AC3 volume without re-encoding
it's been more than 10 years since last replay.
maybe now there is a program that can boost AC3 volume losslessly like MP3 gain.
anyone?
Technically, you could overwrite the pre-applied dynamic gain information, which is encoded into the track. But then you'd have to rely on the decoder having the AGC processing turned on. Plus, I haven't looked at a52dec, so I don't know the precision of the gain values.
So there is no easy solution. I have to be expert to do this.
Or wait for an expert to write software to do it for you.
Closest solution I've come across is AC3Gain.
However, this is only a wrapper for Avisynth, which will eventually re-encode anyways.
Technically, one could adjust the global dynamic gain fields, which are pre-calculated and encoded into the stream, but that relies on the user enabling dynamic gain control in their player.
you may shove it into a container that allows you to store ReplayGain tags.
"matroska audio" would likely work.
this relies on user enabling ReplayGain volume matching, but this is something one'd normally do anyway, because otherwise music albums have the loudness all over the place.
some ANC'd headphones + AutoEq-based impulse + Meier Crossfeed (30%)
