Topic: Qicktime Audio Decode/Transcode (Read 3102 times) previous topic - next topic
Does anyone know how to decode Quicktime audio (*.mov) on a PC?  The file I was given is audio only,  no video.  Any help would be qreatly appreciated.
<Soapbox>
The standards war is over...  It ain't Windows.  It ain't Real.  It ain't Quicktime.  MP3 is pervasive.  Like it or not.
</Soapbox>
This should work:
* Open the .mov in QuickTime Player
* Click 'Window - Show Movie Properties'
* Select the sound track and click 'Extract'
* Click 'File - Save As...'
This should work:
[a href="index.php?act=findpost&pid=357201"][{POST_SNAPBACK}][/a]
Perhaps I'm running a different Quicktime player on my PC than you are.  I found 'Window - Show Movie Info'  Beyond that there was no way to select soundtrack, extract, or save as....
Thank you for your response.
Use VLC or MPlayer.  Should work fine unless it's QDM2.
[a href="index.php?act=findpost&pid=357211"][{POST_SNAPBACK}][/a]
It is QDesign Music 2.  Thank you for youe response.
Drag the .mov file into iTunes and then use advanced: Convert selection to AAC (or MP3 or whatever you have selected)
Actually qdm2 too, lavc has now qdm2 decoder.
This should work:
[a href="index.php?act=findpost&pid=357210"][{POST_SNAPBACK}][/a]
You need QT Pro for that
[a href="index.php?act=findpost&pid=357418"][{POST_SNAPBACK}][/a]
It does, but there are reportedly some bugs (audio fidelity issues).
If it doesn't work, and the file is available online somewhere, you could submit a bug report to the ffmpeg list.
