Topic: Optimized MPEG ALS encoders (Read 33814 times) previous topic - next topic
64 bit build: http://sjeng.org/ftp/lossless/mp4als_x64.exe
[a href="index.php?act=findpost&pid=356049"][{POST_SNAPBACK}][/a]
Does it required a win64 plateform ?
Which compiler did you use for sse/sse2 ?
btw, I'm testing your different builds. Thanks for your work.
Of course. All 64 bit programs need a 64 bit OS.
[a href="index.php?act=findpost&pid=356054"][{POST_SNAPBACK}][/a]
MSVC8
64 bit speedups on AMD X2 4400[a href="index.php?act=findpost&pid=356049"][{POST_SNAPBACK}][/a]
Daaaaaamn, you're making me lust after 64bit CPU's now?
[a href="index.php?act=findpost&pid=356071"][{POST_SNAPBACK}][/a]
This is a bit exceptional because:
a) core arithmetic in ALS is in 64 bits
b) compiler does a real bad job of optimizing it in 32 bit mode
Assembler coding can probably give a good gain in 32 bit mode, while 64 bit compiler code should be close to optimal.
64 bit speedups on AMD X2 4400[{POST_SNAPBACK}][/a]
Quite affordable: [a href="http://www.overclockers.co.uk/acatalog/AMD_Sempron.html]http://www.overclockers.co.uk/acatalog/AMD_Sempron.html[/url]
WavPack 5.2.0 -b384hx6cmv / qaac 2.68 -V 100
Meh. I want Dual Core, too.
