Topic: Output directory? (Read 2803 times) previous topic - next topic
Output directory?
ok im encoding with LAME and my command line is as follows:
-V 3 --vbr-new --add-id3v2 --pad-id3v2 --ta "%a" --tt "%t" --tl "%g" --ty "%y" --tn "%n" %s %d
Only thing i would like to do is have EAC put all my files in a folder with the syntax of:
%A-[%Y]-%N
A=artist name, Y=year, and N=name of album.
Is ther an EAC setting for this, or is it in the command line?
Output directory?
It is not in the command line, it is under EAC Options -> Filename.
Output directory?
[a href="index.php?act=findpost&pid=354194"][{POST_SNAPBACK}][/a]
No no, I would like EAC to create a folder to put the extracted fiels into, with said syntax above.  I can not find an option to do this... when i was big into the musepack scene i had it setup to accomplish this.... It however has escaped me how i had set it up.
Output directory?
Exactly, it's under EAC Option>Filename.  Use "/" to denote folders.
