Topic: Cuesheet Question (Read 5181 times) previous topic - next topic
Cuesheet Question
Ripping a CD to a FLAC image and Cuesheet.  When I load the cuesheet into Foobar2000, all of the artist/album/track information is displayed, but the genre and date information is not.
I noticed when looking at the cuesheet that those entries havd a REM statement.  Is that why it's not displayed?  I'm at work and can't test at the moment.
REM GENRE Rock
REM DATE 2005
REM DISCID 7E10C308
REM COMMENT "ExactAudioCopy v0.95b3"
I didn't see this mentioned in the sticky's or FAQ's, but I may have missed it.
Edit:  I just noticed that I posted this in the wrong (sub)forum.
flac > schiit modi > schiit magni > hd650
Cuesheet Question
I can use %date%, %genre%, etc. to access these fields (0.9b13 - but ever since I can remember).
I just tested with a cue + wav, but I don't see why it would be different for your FLAC file.
I'm on a horse.
Cuesheet Question
Do those entries have a REM statement in front of them in the cue file, like mine does?
Cuesheet Question
REM just means that this is not a standard tag which is correct for date and genre
0.8.3 can not read date and genre in cue sheets but 0.9 can. you can also try cue_ex but i had various problems with that plugin.
Cuesheet Question
OK, I just tested this again.  I have a FLAC image and CUE file.  I verified that the FLAC image has no tags at all.  If I load that file into Foobar2000, it only displays the filename, no tags.  That is what I would expect.
If I load the cue file into Foobar2000, Foobar2000 will display the artists, the album title, all of the individual track titles.  Looking at the properties of one of the tracks will show the field populated with the correct data.  What is missing is the genre and date information, both of which are present in the cue file.  Foobar2000 is ignoring those fields.
Cuesheet Question
[a href="index.php?act=findpost&pid=352846"][{POST_SNAPBACK}][/a]
Ahhh, that explains it.  Thanks.  Guess I should have mentioned what version I was using.
I could actually apply those two tags to the image file, and that would work.  I was wanting to not use any tags at all, and just have the information read from the cue file.
Cuesheet Question
Or just use 0.9
A riddle is a short sword attached to the next 2000 years.
Cuesheet Question
That is what I am doing since yesterday.  Works perfectly.
Cuesheet Question
I'm curious...
Since Metaflac strips out the tracknames when embedding the cuesheet, how does it work when you embed the cuesheet with Foobar2000.  I'm not looking for a real technical anwer, just a general overview.  Am I creating a "non-standard" FLAC file, and should I even care if I am?
Cuesheet Question
Embedding with foobar uses a Vorbis comment.  You can set any Vorbis tag to any value - there's nothing inherently special about one called CUESHEET.
However, foobar recognises a CUESHEET tag in various lossless files (Monkey's Audio, WavPack, FLAC, etc.) as do other applications like ACDIR, and even my latest mod of Tag.
As you are not using FLAC's native CUESHEET meta block I guess you can't expect FLAC to acknowledge your Vorbis comment.  However, foobar, ACDIR, etc. does, and you can  always just extract from the CUESHEET tag to a CUE file if an app requires an external file.
So, by using a Vorbis CUESHEET tag, you are simply using FLAC's tagging facility to store your cuesheet, in its totality, in a tag - but luckily some great apps like foobar and ACDIR recognise this tag and can use it like an external cuesheet.
Edit: To actually answer your question () you are not creating a non-standard FLAC file - just a file with an additional Vorbis comment.  This (using a Vorbis comment and not the FLAC meta block) does of course mean though that the cuesheet is not elligable for some nifty inherent cuesheet wizardry, like the --cue switch.
I'm on a horse.
Cuesheet Question
Thank you.  I understand perfectly now.  That was a great explanation.
