Topic: [CRASHWARE] updated foo_uie_albumart (Read 697724 times) previous topic - next topic
Reply #900
I just updated to the latest version of foo_uie_albumart (0.2.6) and now relative pathnames appear to be broken.
Make sure that foo_uie_albumart.dll is in the "components" folder in your foobar2000 installation folder.  relative pathnames won't work if the .dll is placed anywhere else.  It's a bug, and should be fixed in the next version.
Reply #901
I just wanted to say that foo_uie_albumart has a glitch with the Alt+Tab Replacement of Microsoft PowerToys for Windows XP.
Pic
The album art panel in the preview image of foobar2000 will be black; the album art will instead show up at the location the foobar2000 window is under all current windows, leaving an imprint there until you minimize and restore the open window(s).  It'd be nice if this could be fixed.
Reply #902
This isn't a foo_albumart problem, its a problem in GDI+. As far as I know, there is no Patch avaible.
Reply #903
Is there any negative impact to using big images versus small images for the albumart source?  For example, I only have a small panel for album art, fixed at 125x125.  Currently I'm manually resizing big album covers to ~50 kB jpegs just for use with albumart.  But if I was to use the original files that are 2+ MB, letting albumart find it using wildcards and resize it on the fly, would this have any noticeable cpu/memory impact?
Just doing some casual testing while watching the Task Manager window says no noticeable impact.  But I just would still like to have other people's input.
Reply #904
was trying to figure out how to resize the panel, but i figured it out...
thanks for the great plugin
Reply #905
Just found out that i have a lot of output in the console making everything hard to read.
Something like that
0 match(es) found
searching album art, preprocessed pattern: "F:\Bands\Midwest Product\Specifics\folder.jpg"
  Pattern found in history; previous search results used
Loading album art: "F:\Bands\Midwest Product\Specifics\folder.jpg"
searching album art, preprocessed pattern: "C:\Program Files\lastfmproxy\data\folder.jpg"
Is there a way to remove them?
Reply #906
carmenm
Maybe this can help you: Album Art Preferences -> Sources -> Debugging -> uncheck "Out preformatted sources to console"
Thinking Outside The Box
Reply #907
Thanks a lot, worked like a charm
Reply #908
I do not resize large covers. Auto resizing works very well for me.
Reply #909
Version 0.2.7 (October 23, 2007)
Plugin homepage
Download
Change log
Source
Wiki page (Help)
This release is primarily to fix the crashes on foobar2000 0.9.5 beta 1.  There are also a few small bugfixes I've been working on the past few months.
Please note: relative paths are now relative to the folder containing foo_uie_albumart.dll.  For most people, this is their "components" folder, so any "No-Cover" sources that used to read "--components\default.jpg" should now be changed to "--default.jpg".
Reply #910
Good to see that the 0.9.5 b1 crashes are fixed!
Cheers!
Reply #911
-$if($strstr(%_path%,http:),radio_stream.tif) still craches (worked before v0.9.5beta1).
-$if($strstr(%_path%,http:),radio_stream.tif,du.mmy) does the trick.
Reply #912
I've just had a crash with Version 0.2.7 when adding tracks from CD to playlist.
Replacing the patterns with
$replace(%path%,%filename_ext%,)cover.* and
--default.*
prevented the crashes
Reply #914
gfngfgf, what about implementing embedded picture support?
The one discussed here is based on an old version of yours.
As always, many thanks for your good work!
Reply #915
+1, I want it too!
Reply #916
Right now, I'm going to wait until the 0.9.5 final SDK is released before trying to tackle embedded art on my own.  Hopefully, the SDK will expose the embedded art support used by the Default UI's Album Art Viewer component and I won't have to reinvent the wheel.
Reply #917
Are you going to abandon Columns UI compatibility?
Reply #919
With foobar2000 0.9.5 beta 4 and foo_uie_albumart 0.2.7 I get an Unhandled exception: I/O error (win32 #123) error whenever I try to play an audio CD.  I guess that the problem is with foo_uie_albumart, because removing it solves the problem.
Is anyone else seeing this?
Reply #920
try editing your source list
Reply #921
So is that a no? I.e. foobar2000 with foo_uie_albumart 0.2.7 does not crash for you when playing audio CDs?
EDIT: Is there really no foo_uie_albumart user who ever listens to audio CDs and can answer this simple question?
Reply #922
Hello,
Under Vista with foobar 0.9.4.5:
Doesn't work. Any hints? Albumart 0.175 works under XP but crashed under Vista so I try the version 0.2.5.2. With 0.2.7 it's the same also.
Thanx
Reply #923
Using ".." to refer to the parent directory no longer works.  Try this instead:
$replace(%path%,%directoryname%\%filename_ext%,folder.jpg)
Reply #924
hey, i too am also getting this error. thats why ive been sticking with the older versions for now. it took me ages to even bother figuring out what it was but this is it. even with no other active components it causes frequent crashes. im thinking of making a panelsUI imagebox to replace this until its ever fixed.
edit:
i've isolated this bug even more here. it seems the crashes only happen when the first source does not match an image. i tested it with a couple hundred tracks, every track that had a folder.jpg was fine. every track that did not caused foobar to crash. this only happens if the album art image actually changes. if follow cursor is off the crash only happens when a song plays that has no cover. i tried deleting foobar2000.cfg and removed all components except for columnsUI and the album art plugin, still crashes.
also there are 2 different types of crashes here depending on how you reproduce it.
-if you select a susceptible track in the playlist or add another track from within foobar you get "Unhandled exception : I/O error (win32 #123)
-if you drag and drop a file from another program (eg. explorer) you get "foobar2000 Aplication has encountered a user defined breakpoint." or "foobar2000 Application has encountered a problem and needs to close.  We are sorry for the inconvenience." with the following crashlog:
Illegal operation:
Code: 80000003h, flags: 00000000h, address: 0045077Fh
Call path:
entry=>initquit::on_quit
Code bytes (0045077Fh):
0045073Fh:  FE FF FF 59 5E 59 C2 04 00 FF 74 24 08 FF 74 24
0045074Fh:  08 E8 BA 8E FF FF 59 59 C2 08 00 FF 74 24 08 FF
0045075Fh:  74 24 08 E8 E8 8E FF FF 59 59 C2 08 00 55 8B EC
0045076Fh:  51 51 E8 D6 33 FC FF 80 3D BA ED 4E 00 00 74 01
0045077Fh:  CC A1 DC CA 4E 00 8B 0D D4 CA 4E 00 56 57 8D 34
0045078Fh:  01 33 FF 85 F6 76 20 8B C7 E8 96 A2 FF FF 8B 00
0045079Fh:  3B 45 08 74 07 47 3B FE 72 ED EB 0B 8D 45 F8 50
004507AFh:  8B D7 E8 C4 A1 FF FF 5F 5E C9 C2 04 00 55 8B EC
Stack (0012F194h):
0012F174h:  02C4E5A4 7C9C93C0 77F643DD 7C9C93C0
0012F184h:  00000004 00000000 02C4DAB0 00000000
0012F194h:  004ECC18 004ECC18 0012F1B8 00A732A8
0012F1A4h:  00A9820C 004ECC18 0012F1E8 00A8C2AB
0012F1B4h:  00000000 0012F1F4 00A7394F 00000000
0012F1C4h:  0042C0A8 004E5750 0000000C 0012FEAC
0012F1D4h:  00000009 003B8308 00000005 00A98238
0012F1E4h:  00000000 0012F250 004ABBDC 00000001
0012F1F4h:  0012FEB8 0042C7E1 00000103 004AB667
0012F204h:  004E5750 0000000C 0012F21C 004E56B8
0012F214h:  0012FEAC 0012FEB8 0012F260 004AAAF6
0012F224h:  004B6157 0012FEAC 00000103 851829E1
0012F234h:  E06D7363 1FFFFFFF 19930522 0000000C
0012F244h:  0000000D 0012F230 0012EDA4 0012F2D8
0012F254h:  00499830 8544A5C1 00000001 0012F284
0012F264h:  004AB5C4 0012FEAC 0012F3D0 004E5750
0012F274h:  FFFFFFFF 00000000 00000000 00000000
0012F284h:  0012F2C0 004AA1F8 0012F8A0 0012FEAC
0012F294h:  0012F3DC 0012F3D0 004E5750 00000000
0012F2A4h:  00000000 00000000 00000000 00000000
Registers:
EAX: 00000001, EBX: 00000000, ECX: 004EC190, EDX: 0012F12C
ESI: 00A98238, EDI: 00A98238, EBP: 0012F19C, ESP: 0012F194
Crash location: "foobar2000", loaded at 00400000h - 00520000h
Loaded modules:
foobar2000                      loaded at 00400000h - 00520000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F5000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F02000h
Secur32                          loaded at 77FE0000h - 77FF1000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D6000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 10032000h
COMDLG32                        loaded at 763B0000h - 763F9000h
GameHook                        loaded at 10D00000h - 10D0F000h
lgscroll                        loaded at 10100000h - 1010F000h
MSVCR80                          loaded at 78130000h - 781CB000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
NTMARTA                          loaded at 77690000h - 776B1000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
SAMLIB                          loaded at 71BF0000h - 71C03000h
foo_abx                          loaded at 00A10000h - 00A43000h
foo_autoplaylist                loaded at 00A70000h - 00AA0000h
foo_cdda                        loaded at 00AC0000h - 00AF5000h
foo_converter                    loaded at 00B20000h - 00BAE000h
foo_cwb_hooks                    loaded at 00BD0000h - 00C1D000h
foo_dop                          loaded at 00C40000h - 00CAC000h
SETUPAPI                        loaded at 77920000h - 77A13000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
foo_dsp_skip_silence            loaded at 00CE0000h - 00CF3000h
libmmd                          loaded at 00D10000h - 00FC1000h
foo_dsp_std                      loaded at 00FE0000h - 01027000h
foo_fileops                      loaded at 01050000h - 01097000h
OLEAUT32                        loaded at 77120000h - 771AB000h
foo_freedb2                      loaded at 010C0000h - 01101000h
foo_input_monkey                loaded at 01130000h - 0117A000h
foo_input_std                    loaded at 011A0000h - 012E4000h
foo_masstag                      loaded at 01310000h - 01360000h
foo_playcount                    loaded at 01380000h - 013A5000h
foo_playlist_tree                loaded at 013D0000h - 01445000h
libmzsch360_000                  loaded at 10400000h - 105D0000h
WSOCK32                          loaded at 71AD0000h - 71AD9000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
libmzgc360_000                  loaded at 01470000h - 01514000h
foo_removeplayed                loaded at 01560000h - 01578000h
foo_rgscan                      loaded at 015A0000h - 015F0000h
foo_rg_trn                      loaded at 01610000h - 0162B000h
foo_run                          loaded at 01650000h - 0167B000h
foo_uie_albumart                loaded at 016A0000h - 016DC000h
foo_uie_albumlist                loaded at 01700000h - 01743000h
foo_uie_peakmeter                loaded at 01770000h - 0179D000h
foo_uie_powerpanels              loaded at 017C0000h - 017E3000h
foo_uie_queuemanager            loaded at 01810000h - 01849000h
mscoree                          loaded at 79000000h - 79045000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3D6000h
mscorlib.ni                      loaded at 790C0000h - 79B90000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
System.ni                        loaded at 7A440000h - 7AC06000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF6C000h
foo_uie_quicksearch              loaded at 03FA0000h - 03FE6000h
foo_uie_tabs                    loaded at 04000000h - 0402A000h
foo_uie_trackinfo                loaded at 04050000h - 0407E000h
foo_uie_vis_projectm            loaded at 040A0000h - 040EA000h
OPENGL32                        loaded at 5ED00000h - 5EDCC000h
GLU32                            loaded at 68B20000h - 68B40000h
DDRAW                            loaded at 73760000h - 737A9000h
DCIMAN32                        loaded at 73BC0000h - 73BC6000h
foo_ui_columns                  loaded at 0C110000h - 0C20D000h
UxTheme                          loaded at 5AD70000h - 5ADA8000h
foo_ui_panels                    loaded at 0C230000h - 0C2F7000h
IMM32                            loaded at 76390000h - 763AD000h
foo_unpack                      loaded at 0C320000h - 0C34E000h
foo_utils                        loaded at 0C370000h - 0C3E9000h
taskswitch                      loaded at 7E4D0000h - 7E4E0000h
taskcreate                      loaded at 7E4C0000h - 7E4D0000h
atioglxx                        loaded at 69000000h - 694D9000h
atioglx1                        loaded at 0DF50000h - 0E5C8000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC54000h
Msimg32                          loaded at 76380000h - 76385000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
xpsp2res                        loaded at 20000000h - 202C5000h
DBGHELP                          loaded at 59A60000h - 59B01000h
VERSION                          loaded at 77C00000h - 77C08000h
Stack dump analysis:
Address: 004ECC18h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00A732A8h, location: "foo_autoplaylist", loaded at 00A70000h - 00AA0000h
Address: 00A9820Ch, location: "foo_autoplaylist", loaded at 00A70000h - 00AA0000h
Address: 00A8C2ABh, location: "foo_autoplaylist", loaded at 00A70000h - 00AA0000h
Address: 00A7394Fh, location: "foo_autoplaylist", loaded at 00A70000h - 00AA0000h
Address: 0042C0A8h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004E5750h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00A98238h, location: "foo_autoplaylist", loaded at 00A70000h - 00AA0000h
Address: 004ABBDCh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0042C7E1h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004AB667h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004E56B8h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004AAAF6h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004B6157h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00499830h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004AB5C4h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004AA1F8h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 016C5EF4h, location: "foo_uie_albumart", loaded at 016A0000h - 016DC000h
Address: 7C9037BFh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlConvertUlongToLargeInteger" (+0000007Ah)
Address: 7C903804h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlConvertUlongToLargeInteger" (+000000BFh)
Address: 7C90378Bh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlConvertUlongToLargeInteger" (+00000046h)
Address: 004B6190h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 7C937B48h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlUnwind" (+00000108h)
Address: 004E5FE8h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 016A96EEh, location: "foo_uie_albumart", loaded at 016A0000h - 016DC000h
Address: 1001CFB0h, location: "shared", loaded at 10000000h - 10032000h
Symbol: "uCallStackTracker::~uCallStackTracker" (+00000000h)
Address: 0044976Eh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00405800h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004EEDBAh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004ACC52h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004503DAh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0C1CF488h, location: "foo_ui_columns", loaded at 0C110000h - 0C20D000h
Address: 004CDA84h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004EEDBBh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004502B3h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004ADDC8h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0C113EA1h, location: "foo_ui_columns", loaded at 0C110000h - 0C20D000h
Address: 7C809728h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GetCurrentThreadId" (+00000000h)
Address: 7E431E12h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "AttachThreadInput" (+00000000h)
Address: 0C1D59B4h, location: "foo_ui_columns", loaded at 0C110000h - 0C20D000h
Address: 7C830BCAh, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "GlobalDeleteAtom" (+0000000Fh)
Address: 0C1C2148h, location: "foo_ui_columns", loaded at 0C110000h - 0C20D000h
Address: 7E430429h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "SetWindowWord" (+0000008Eh)
Address: 775F8EC6h, location: "ole32", loaded at 774E0000h - 7761D000h
Symbol: "StgGetIFillLockBytesOnFile" (+000086CEh)
Address: 004AA1A9h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 77EF421Ah, location: "RPCRT4", loaded at 77E70000h - 77F02000h
Symbol: "NdrStubCall2" (+00000215h)
Address: 775F8DF9h, location: "ole32", loaded at 774E0000h - 7761D000h
Symbol: "StgGetIFillLockBytesOnFile" (+00008601h)
Address: 004104DAh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 774EFA88h, location: "ole32", loaded at 774E0000h - 7761D000h
Address: 7750F8D6h, location: "ole32", loaded at 774E0000h - 7761D000h
Symbol: "DcomChannelSetHResult" (+00000217h)
Address: 7750F8CBh, location: "ole32", loaded at 774E0000h - 7761D000h
Symbol: "DcomChannelSetHResult" (+0000020Ch)
Address: 77E70070h, location: "RPCRT4", loaded at 77E70000h - 77F02000h
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C910551h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 77E7C2BFh, location: "RPCRT4", loaded at 77E70000h - 77F02000h
Symbol: "NdrConformantArrayFree" (+000006E5h)
Address: 7C9010EDh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlLeaveCriticalSection" (+00000000h)
Address: 774EF95Ch, location: "ole32", loaded at 774E0000h - 7761D000h
Address: 774EFC6Ch, location: "ole32", loaded at 774E0000h - 7761D000h
Address: 774E9562h, location: "ole32", loaded at 774E0000h - 7761D000h
Address: 774E955Ch, location: "ole32", loaded at 774E0000h - 7761D000h
Address: 774E9552h, location: "ole32", loaded at 774E0000h - 7761D000h
Address: 004AAFFCh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004AB038h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004AB081h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004AB0BEh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004AB444h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004E6010h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 004AB630h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 7C9037D8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlConvertUlongToLargeInteger" (+00000093h)
Address: 004B6667h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 7C937860h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "LdrAddRefDll" (+00000247h)
Address: 1010860Bh, location: "lgscroll", loaded at 10100000h - 1010F000h
Address: 7E41F84Ah, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "EnableMenuItem" (+000000C3h)
Address: 774E4A02h, location: "ole32", loaded at 774E0000h - 7761D000h
Address: 774E4A48h, location: "ole32", loaded at 774E0000h - 7761D000h
Address: 7C90EAFAh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserExceptionDispatcher" (+0000000Eh)
Address: 7C812A5Bh, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RaiseException" (+00000052h)
Address: 00DEE0E2h, location: "libmmd", loaded at 00D10000h - 00FC1000h
Symbol: "_csqrtq_f90" (+000DB7A6h)
Address: 7E4188A6h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowLongW" (+00000000h)
Address: 7E4563BEh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetRawInputDeviceInfoW" (+000000C6h)
Address: 101073C0h, location: "lgscroll", loaded at 10100000h - 1010F000h
Symbol: "UninstallScrollHooks" (+00000C00h)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 77DDE0AEh, location: "ADVAPI32", loaded at 77DD0000h - 77E6B000h
Symbol: "ObjectOpenAuditAlarmW" (+00000515h)
Address: 010800CCh, location: "foo_fileops", loaded at 01050000h - 01097000h
Address: 77DDE32Eh, location: "ADVAPI32", loaded at 77DD0000h - 77E6B000h
Symbol: "ObjectOpenAuditAlarmW" (+00000795h)
Address: 7C90E1FEh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "ZwQueryValueKey" (+00000000h)
Address: 7C90FB6Ch, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlNtStatusToDosError" (+0000002Fh)
Address: 77F643D0h, location: "SHLWAPI", loaded at 77F60000h - 77FD6000h
Symbol: "SHRegGetValueW" (+000000B1h)
Address: 7C9C93C0h, location: "SHELL32", loaded at 7C9C0000h - 7D1D6000h
Symbol: "Ordinal517" (+000093C0h)
Address: 77F643DDh, location: "SHLWAPI", loaded at 77F60000h - 77FD6000h
Symbol: "SHRegGetValueW" (+000000BEh)
Address: 0042EEE0h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 7E41F805h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "EnableMenuItem" (+0000007Eh)
Address: 7E41F94Bh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CallNextHookEx" (+000000F0h)
Address: 7E41F95Bh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 0049B5D9h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0043B99Fh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004C4CACh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004CBFA4h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0042EEF8h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 7E418734h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+0000006Dh)
Address: 004D0318h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 7E418816h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E440457h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetDC" (+00000169h)
Address: 7E4189CDh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 7E41DAEAh, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 7E4189F0h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 7E418A10h, location: "USER32", loaded at 7E410000h - 7E4A0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 0042C4DFh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0042D0A2h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004D2C44h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004C6FA8h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004D2C28h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 00497671h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 1001D07Bh, location: "shared", loaded at 10000000h - 10032000h
Symbol: "uCallStackTracker::~uCallStackTracker" (+000000CBh)
Address: 004CA100h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0042D2DEh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 0049A86Eh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00497C51h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00497C4Bh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004BCF9Ch, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004BB270h, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 00497C5Fh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004995DFh, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0049964Ah, location: "foobar2000", loaded at 00400000h - 00520000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 00520000h
Version info:
foobar2000 v0.9.5 beta 6
UNICODE
Windows 5.1
Additional info:
Autoplaylist Manager 1.0  (foo_autoplaylist)
ReplayGain Scanner 2.0.2  (foo_rgscan)
freedb Tagger 0.5.2.1  (foo_freedb2)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
RAR reader 1.1  (foo_unpack)
Playlist Tools 0.6.2 beta 3  (foo_utils)
Peakmeter Panel 0.0.4.0 alpha preview  (foo_uie_peakmeter)
Track info panel 0.8  (foo_uie_trackinfo)
Masstagger 1.6  (foo_masstag)
ABX Comparator 1.3.1  (foo_abx)
Run services 0.3.2  (foo_run)
Skip silence 0.1 (Intel SSE)  (foo_dsp_skip_silence)
Panels UI 0.14.12 beta [Jul 18 2007 - 13:39:30]  (foo_ui_panels)
Album Art Panel 0.2.6  (foo_uie_albumart)
foobar2000 core 0.9.5 beta 6  (Core)
Standard DSP Array 1.0  (foo_dsp_std)
Remove played Files 1.3.0  (foo_removeplayed)
File Operations 2.0  (foo_fileops)
projectM visualization (Panel) 0.4  (foo_uie_vis_projectm)
Columns UI 0.2.1 alpha 9  (foo_ui_columns)
ReplayGain override 0.1.1  (foo_rg_trn)
Seek Panel 0.1  (foo_uie_powerpanels)
Playlist Tree Panel 3.0.BETA_3 [Apr  3 2007 - 11:39:32]  (foo_playlist_tree)
Tabbed panel modified 0.2.6  (foo_uie_tabs)
Converter 1.0.2  (foo_converter)
Queue manager panel 0.2.1  (foo_uie_queuemanager)
Playback Statistics 2.0  (foo_playcount)
Volume Panel 0.1  (foo_uie_powerpanels)
CD Audio Decoder 2.1.2  (foo_cdda)
ZIP/GZIP reader 1.0  (foo_unpack)
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00]  (foo_cwb_hooks)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
iPod manager 0.4.3 TEST  (foo_dop)
cwbowron's title format hooks 1.2.5 [Jun  8 2007 - 08:49:42]  (foo_cwb_hooks)
