Topic: Lame4Dos.bat (Read 4824 times) previous topic - next topic
Lame4Dos.bat
I am trying ti use the Lame4Dos.bat file to convert many .wav phone recordings to .mp3 and save some space.  I have dowloaded the .bat file and edited the path to the Lame.exe and set my options.  When I attempt to execute the batch file, I receive:
>& was unexpected at this time.
Here is my .bat filefor those who have never looked at it:
@echo off
rem  ---------------------------------------------
rem  PURPOSE:
rem  - put this Batch-Command on your Desktop,
rem    so you can drag and drop wave files on it
rem    and LAME will encode them to mp3 format.
rem  - put this Batch-Command in a place mentioned
rem    in your PATH environment, start the DOS-BOX
rem    and change to a directory where your wave
rem    files are located. the following line will
rem    encode all your wave files to mp3
rem     "lame.bat *.wav"
rem                         C2000  Robert Hegemann
rem  Changes to support long filenames using 4DOS
rem  by Alexander Stumpf <dropdachalupa@gmx.net>
rem  please set LAME and LAMEOPTS
rem  LAME - where the executeable is
rem  OPTS - options you like LAME to use
        set LAME=c:\lame\lame.exe
        set OPTS=-f
   set thecmd=%LAME% %OPTS%
        for %%f in (%&) do (%thecmd% %@sfn[%%f]^(ren %@sfn[%%f].mp3 "%@lfn[%%f].mp_">NUL))
        ren *.mp3.mp_ *.new.mp3 >& NUL
        ren *.wav.mp_ *.mp3 >& NUL
        goto endmark
:errormark
   echo.
   echo.
   echo ERROR processing %1
   echo.
:endmark
rem
rem   finished
rem
I am using XP Professional.  Any help/suggestions is greatly appreciated.
Thanks,
Mark
Lame4Dos.bat
@echo off
set OPTS=-f
%LAME% %OPTS% %1 %1.mp3
ren *.wav.mp3 *.mp3
This will do the trick.
Lame4Dos.bat
didnt test but instead:
things should probably be:
for %%f in (%1) do (%thecmd% %@sfn[%%f]^(ren %@sfn[%%f].mp3 "%@lfn[%%f].mp_">NUL))
Lame4Dos.bat
ren *.wav.mp3 *.mp3
FYI: Minor improvement:
%LAME% %OPTS% %1 "%~dpn1.mp3"
If %1 is "C:\My Music\My File.wav" then %~dpn1 is C:\My Music\My File
... is just the same as:
%LAME% %OPTS% %1
I'm on a horse.
Lame4Dos.bat
shade, syntetic soul, yes but that wont work with 'lame4dos *.wav'.
minimum would be:
for /f "delims=++" %%i in (%1) DO lame --alt-preset standard "%%i"
Lame4Dos.bat
@mark
it's not clear from your post, are you using 4dos or the xp command shell?
