Topic: oggdropXPd V1.8.7, oggenc2.8, oggdec V1.9.2 - new (Read 39891 times) previous topic - next topic
Why oggenc2.8 encoded files not played by http://www.illiminable.com/ogg/ ?
Atlon XP 3200+
I registered to HA finally, after reading it for so long, so hi guys.
Let me start with a question about OggDropXPd:
Why is it that specific FLAC's are not decoded by it?
Can't seem to figure that one out.
I can, however generate one of those flac's for you by using EAC, and setting it to directly rip to FLAC, directed to the latest 1.1.2 flac.exe with the following commandline:
-T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" %s
+++ UPDATE +++
I found out why by trying some stuff....  It was the genre tag made oggdrop quit without errormsg, log or whatever. The genre line was like this:
GENRE = Alternative Rock
With a genre tag like: GENRE = Misc it's all ok.
Might it be the space in "Alternative Rock"?
Welcome.  It's always more fun as a member.
+++ UPDATE +++
[a href="index.php?act=findpost&pid=367286"][{POST_SNAPBACK}][/a]
Can you tell me exactly what options you selected?
As a matter of fact I had none selected, because I deleted the .ini during trying other stuff.
So all the settings in the Tagging Setup where at their defaults.
The only changes i made to the default setting (ie, after deleting the ini) was:
- Set ogg q to 7.00
- delete input file to true
- Set ogg q to 7.00
[a href="index.php?act=findpost&pid=367298"][{POST_SNAPBACK}][/a]
Not that I think it relates, but which compile are you using?
Clearly there is a problem somewhere, but what puzzles me is that with the default tagging settings, no tagging takes place which means that no attempt is made to process the FLAC tags in any way.
Even if the option to copy the FLAC tags was set, the length of the Tag is determined by reading the tag length variable rather than relying on any terminator within the tag data, so the content of the Tag shouldn't be relevant.
Have you tried encoding using oggenc2.8? This uses identical routines for processing FLAC input files. If you don't want to copy the FLAC tags, you'll have to add the option '--discard-comments' to the command line. Actually, these routines are identical to those in the standard oggenc.
Hi John,
Can you comfirm this problem which is exists in oggenc 2.8 or not?
If so, is there's any fix for it?
Thanks in advance.
Sorry for my English.
Hi John,
Thanks in advance.
[a href="index.php?act=findpost&pid=367422"][{POST_SNAPBACK}][/a]
This quote
even though piping works fine with it in foobar2000, it is obvious to me that something is wrong
suggests to me that the problem is elsewhere. The processing via "stdin" is unchanged from the standard oggenc from xiph.
I would need to know exactly what is being passed from dbpoweramp to make any other comment.
Reply #32
oggdropXPd V.1.8.7 using aoTuVb4.51, P4 Only
If it helps I can add it doesn't even try to do anything. No reaction on drop whatsoever.
Again, using "Alternative Rock" for GENRE did NOT work, and using "Misc" did.
BUT: I just tried to set the GENRE back to Alternative Rock and now it works!
Could it be that the tags are corrupted in some way that foobar can read them still?
I haven't tried that. However, I will first try to recreate the erroneous flacs tonight, because by resetting the GENRE they all work now, so there's not much to test with anymore.
It does rather sound like the tags are malformed in some way, but do keep me informed. Clearly if there is a problem, I'll try to fix it, but it is also necessary to identify exactly the nature of the problem.
Reply #34
Hi John,
Thanks in advance.
This quote
[a href="index.php?act=findpost&pid=367426"][{POST_SNAPBACK}][/a]
You're right, STDIN is fine. But the raw(pcm) file/stream input doesn't work in oggenc 2.8.
Reply #35
yup, raw pcm input isn't working in oggenc 2.8
in the case of dbpoweramp... sense all the commands are the same from the previous lancer release (2.6 aint it?) it should have been just a quick swap of the executable (since piping works fine with that version). I have also tried sending the wave riff too, but that didn't work either. Other than that I don't know, I haven't actually tried anything more after that 10min or so.  I just reverted back to the previous version  ... maybe I'll try more stuff in a week (spring break and I'll actually have free time.. maybe)
Vorbis-q0-lowpass99
lame3.93.1-q5-V9-k-nspsytune
Reply #36
[a href="index.php?act=findpost&pid=367914"][{POST_SNAPBACK}][/a]
And you're right, too!!  I've uploaded oggenc2.81 in all varieties to Rarewares. I believe this fixes the raw input and aiff file processing, both of which I broke when I added the corrected multi-channel processing.
Reply #37
Ok, you could say that this is a bug in OggdropXPd that I just ran across.  When you specify a specific directory to output to, you just type it in manually, and you type in more than one non-existing directory deep, you get "cannot write to location"-type errors, instead of it creating that folder structure.
John, btw, is there any chance you could write in that code again that would allow me to set a "Start at Logical Stream Number" value, and also be able to "Disable incrementing of serial number"?  I am doing some more bit difference testing, and I need to be able to use OggDropXPd with the latest builds of the Pentium 4-optimized Vorbis encoders to do that stuff in batch again.  If you have lost the code, I can at least send you the executable from before so you can see how you had the option menu configured (yeah, I know it wouldn't help you code it again, though).
WARNING:  Changing of advanced parameters might degrade sound quality.  Modify them only if you are expirienced in audio compression!
Reply #38
That's standard functioning with what's available with the VC6 compiler. I've produced a VC7.1 based ICL9.0 compile that adds the option to create a new folder in the folder browser window when specifying a different output folder; you can d/l it from: [a href="http://homepage.ntlworld.com/jfe1205/oggdropXPdV1.8.7b-P4.zip]http://homepage.ntlworld.com/jfe1205/oggdr...dV1.8.7b-P4.zip[/url]. Can you let me know what you think? Personally, I think this is a better route than allowing typing in the edit box. I'll add this to the temp dir option, as well.
[a href="index.php?act=findpost&pid=368507"][{POST_SNAPBACK}][/a]
Can you mail me the exe and I'll see what I can do for you.
Reply #39
So in conclusion: I should be using the aoTuVb4.51.
Am I reading this correctly?
No, latest [a href="http://homepage3.nifty.com/blacksword/index_e.htm]Lancer[/url]
sarcastic note: those 'yellows' (Japaneses) are great !
[a href="index.php?act=findpost&pid=350756"][{POST_SNAPBACK}][/a]
Wow! This Lancer built is well above 40x encoding here. Never tried it before.
I somewhere read it "may" produce different results due to its optimisations. Is there a degraded example documented?
[a href="index.php?act=findpost&pid=350768"][{POST_SNAPBACK}][/a]
Even I recommend using LANCER .... Yes it is very fast!
It was optimised for 2x speed retaining the same quality!!
The virtue of love isnt finding the perfect person, but by loving the imperfect person perfectly.
Reply #40
Yeah, that is agreeable, because it at least solves having to go and browse to the location in a Windows Explorer window manually to create a new folder structure for a set, and also you don't have to go and code anything separately.  Using that, I shouldn't need to have to type it in manually.
The thing that this doesn't fix, however, is the case where someone goes and deletes the "more than one deep" folder structure later, because then it will still bug out the next time you use the program.  It might be helpful for you to code the program to check on startup whether the Output and Temporary folders still exist, and prompt the user if they don't, instead of having it bug out when you start encoding.  Just imho, that is.
[a href="index.php?act=findpost&pid=368885"][{POST_SNAPBACK}][/a]
I sent you a link to download it.  Thanks!
Reply #41
Would it be possible to also include direct encoding from WavPack files in OggdropXPd, as it already does this for Monkey's Audio, LPAC, FLAC and OptimFROG? WavPack is under BSD license, so that part at least shouldn't be a problem.
Reply #42
[a href="index.php?act=findpost&pid=371017"][{POST_SNAPBACK}][/a]
I'll look into it and get back to you.
Reply #43
I have a test version running that uses a very simple wvunpack dll that I created. It seems to run as expected but I need to do some further testing and I also want to add one or two other changes before I release a new version.
Reply #44
[a href="index.php?act=findpost&pid=372940"][{POST_SNAPBACK}][/a]
Thanks, mate!    Take your time, take your time...
Reply #45
Well, I believe I have a solution for mmortal03 and for Mr_Rabid_Teddybear, so I should be able to put a new version out in the next few days after some more testing.
Reply #46
Right, and would you please do it using aotuv prebeta 5, if this is possible John33.
Reply #47
[a href="index.php?act=findpost&pid=373639"][{POST_SNAPBACK}][/a]
As soon as the source becomes available, sure.  Right now, there is just a stripped down oggenc available.
Reply #48
Mmmmmm.. btw...the link to prebeta5 *clearly* states :  "Quality -1 only!". I believe we should AT LEAST believe the guy...
Reply #49
oggdropXPdV1.8.8 is now available at Rarewares.
Now includes direct input of Wavpack files with, or without, correction files. Also, the Output Directory Dialogue has been updated. Previously, a saved output directory that was subsequently deleted and was more than one level deep would cause an error. This is no longer the case, it will be recreated however many levels deep.
The consequence of this is that Windows 2000, or better, is now required. These are MSVC7.1/ICL9.0 compiles. The wvunpack.dll required for Wavpack input is available for separate download. As before, if you're not going to input Wavpack files, you don't need this.
