Topic: Convolver: DSP DirectShow filter / WMP plug-in (Read 6908 times) previous topic - next topic
Convolver, is a DSP filter for Windows, is available from http://convolver.sourceforge.net.
It will take a set of single-channel impulse response files and convolve them with the input stream.
Why would you want to do this?  With a suitable impulse response generated by a tool such as DRC you will be able to play sound corrected for your room response.
You will also be able to generate cross-overs, equalizers and other tools that require the source signal to be filtered and redirected to different output channels.
The plug-in can also be used as a DirectShow filter using the included ConvolverWrapper with media players such as Zoom Player Pro and TheaterTek 2.2 that accept DirectShow audio filters.  There is a  setup walkthrough for ZoomPlayer.
Feedback welcome to jrp [at] dial dot pipex dot com.  I have also started a support thread at http://www.hydrogenaudio.org/forums/index....showtopic=38767
Enjoy.
