WavPack 4.3 released
Reply #72 –
i also do it like that (correct filename + .wav extension) but i'm not sure if every player (is there any other than foobar that supports wv+cue?) behaves like foobar which doesn't care about the "FILE" line
...[a href="index.php?act=findpost&pid=341657"][{POST_SNAPBACK}][/a]
Well, the point is, IMHO, that if you have the cuesheet embedded it really doesn't matter what the filename is in it when you play the compressed file through foobar200 (the only player I know of that can handle WavPack with embedded cuesheets). If you extract it while decoding to WAV, then you very likely need the cuesheet with the .wav filename. Winamp, with the aid of a plug-in, can handle EXTERNAL cuesheets with the .wv filename. But in this case you will need to leave the cuesheet external, not embedded (unhapply).
Sergio
