Topic: WavPack 4.3 released (Read 44047 times) previous topic - next topic
David Bryant released today WavPack 4.3
WavPack is a high quality, efficient and featureful lossless/lossy/hybrid compressor. It is available for free, including source code released under a very liberal license.
Changelog is available in next post.
Obtain the Win32 binaries and plugins at WavPack's official site:
http://www.wavpack.com/
And compiles for several *nix platforms at RareWares:
http://www.rarewares.org/lossless.html
WavPack release 4.3 changelog:
wavpack.exe (command-line encoder) - 4.3
  fixed: bug causing termination error with very wide screen widths
  added: command-line option (-l) to use low priority for batch operation
  added: command-line option (-r) to generate a fresh RIFF header
  added: debug mode (rename to wavpack_debug.exe)
  added: automatically detect lower resolution data even without -x1
  added: src and dst dirs are searched also for tag source files (handy for EAC)
  added: wildcard accepted for tag source files (handy for EAC)
  added: handle non-standard sampling rates
  improved: returns error status for any error
  improved: use longer blocks in multichannel files (better "high" compression)
wvunpack.exe (command-line decoder) - 4.3
  fixed: very rare decoding bug causing overflow with hi-res files
  fixed: formatting error in duration display
  added: command-line option (-ss) to include tags in summary dump
  added: debug mode (rename to wvunpack_debug.exe)
  improved: more robust decoding of damaged (or invalid) files
in_wv.dll (winamp plugin) - 2.3
nxWavPack.dll (Nero plugin) - 1.2
WavPack_Apollo.dll (Apollo plugin) - 1.3
cool_wv4.flt (CoolEdit / Audition filter) - 2.6
  improved: handle ID3v1.1 tags (now includes track number)
foo_wavpack.dll (foobar plugin) - 2.3
  fixed: any error during WavPack file open caused crash if wvc file present
WavPack Library Source Code - 4.3
  added: automatic generation of RIFF wav header during encoding
  added: new functions to access tags by index (instead of item name)
  added: automatically detect lower resolution data during encoding
  improved: two structures renamed to avoid namespace conflict
  removed: legacy code for Borland compiler
WELCOME to the new baby, and a great THANK-YOU to David! (Yes, to you too, Roberto!  )
Sergio
Sergio
M-Audio Delta AP + Revox B150 + (JBL 4301B | Sennheiser Amperior | Sennheiser HD598)
Thanks, Roberto.
BTW, another important item not in the changelog is the new plugin for Steinberg's WaveLab 5 that's available. Anyone who got the first one should grab the latest updated beta:
http://wavpack.gl.tter.org/
Thank you David !
wavpack 4.8 -b3hx4cl
Muchas gracias, David!
Now all we need is for Andre to fix the file-extension error in EAC, and voila!, single step rip/compression/cue-embedding!
EDIT: added "rip".
Thank You David.
That -l switch will shure come in handy for archiving the mixes of our show here.
Thanks a lot! There's still the filename bug though, where a file with special chars in its name is "not found":
$ wvunpack "00 - [untitled].wv"
WVUNPACK  Hybrid Lossless Wavefile Decompressor  Linux Version 4.3  2005-11-01
Copyright (c) 1998 - 2005 Conifer Software.  All Rights Reserved.
file 00 - [untitled].wv not found!
On another topic, the detection of oversampled content works beautifully. I tested the stereo mix of the R.E.M. - In Time DVD-Audio with wavpack -hm; version 4.2 produced 2.659 GiB worth of data, versus 1.846 GiB for v4.3, for the same encoding time :-)
The file extension issue doesn't stop you doing any of these.
I don't think foobar pays any attention to the FILE command in an embedded cuesheet.
I'm on a horse.
thanks alot for your great work.
Great work bryant! Much appreciated.
I also have not implemented shadowking's noise-shaping improvement because I wanted to do it in a backward compatible way (which was more work). But it's scheduled.
[snip]
However, I believe that the existing -x mode could be overhauled in a way that would give a significant improvement to compression of real music without the huge speed penalty that exists now. Well see...
[a href="index.php?act=findpost&pid=337447"][{POST_SNAPBACK}][/a]
Is this next for 4.4?
Great work!  Hope WavPack keeps getting better and better.
An early Xmas present. Thank you!
[a href="index.php?act=findpost&pid=339974"][{POST_SNAPBACK}][/a]
You're right Synthetic Soul, it does work, Muchas gracias!
I had tried it with an already ripped and renamed WAV and it worked, but I thought that going straight from rip to encode to embed wouldn't work because of the extra extension.
Haha, just a day after I finished archiving my dvd-a rips with 4.2 =)
I'll give it a run and see how it will handle them compared to 4.2.
What a timing
OK, I reconverted one of them, and went from 4678 kbps (4.2) to 4671 kbps (4.3). Using the same settings (lossless, high).
Am I missing some kind of special switch used specifically for hires audio here?
I use -hx6 for MAXIMUM compression of DVD-Audio.  I don't care how long it takes to encode, and it plays back as fast as -h that I can tell.
Extra modes should actually be slightly faster (decoding) than -h.
Interesting. I guess thats what I get for using a frontend and not checking properly the documentation. I'll try to redo it with -hx6 and see if there are any big differences.
Could anyone explain what are these new features for and how do they work?
If you specify "-w CUESHEET=@cdimage.wv.cue" WAVPACK will look for cdimage.wv.cue in three folders (in addition to the folders in PATH):
  • The folder in which WAVPACK resides
  • The folder in which the source WAVE resides
  • The folder in which the WV file is to be created
Edit: obviously if you are using STDIN or STDOUT then only two folders are valid.
Wildcards can be used like "-w CUESHEET=@*.cue".  This will only work if there is one .cue file in the folder.  It is useful when the cuesheet name changes per image, but you don't want to have to change your command line every time you rip.
I rip to a "clean" directory from EAC, so it is useful to me.
By using "-w CUESHEET=@*.cue" WAVPACK will first check the folder in which WAVPACK.EXE resides for a cuesheet.  When unsuccessful it will check the directory in which the temporary WAVE file resides - where it should successfully find the cuesheet EAC just created.
I'm on a horse.
[a href="index.php?act=findpost&pid=340237"][{POST_SNAPBACK}][/a]
May I suggest using -hx only. I have encoded few albums with -hx and -hx6 and there was only 1-2 kbps difference in bitrate but the encoding time difference was like 3x or something.
EDIT: With albums, I mean normal audio CD's.
Interesting. I guess thats what I get for using a frontend and not checking properly the documentation. I'll try to redo it with -hx6 and see if there are any big differences.[a href="index.php?act=findpost&pid=340237"][{POST_SNAPBACK}][/a]
Honestly, I believe hx6 is madness. It takes ages to encode and won't do much better than, say, hx2 - that is several times faster.
[a href="index.php?act=findpost&pid=340334"][{POST_SNAPBACK}][/a]
I agree.  I've always used -hx2m for encoding any audio.  It's encoding speed is speed comperable to flac and compresses a good bit better in some cases. x6 is way too slow.  Generally if it takes longer than the length of the track I would consider it too slow unless it really made difference.  Glad to see 4.3 released, been busy re-ripping some stuff I ripped wrong using wavpack.  Looking forward to any improvements in speed and compression in 4.4.
