Topic: Title Formatting Help (Read 4392 times) previous topic - next topic
Can some one point me to a site that has the complete listing of title formatting syntax for FB2K v8.3.  The "titleformat_help.html" that is packaged with the installer is for FB2K v.7.  Specifically, I (was) am looking for the definaition "%_is_single%" in the html help file, but it isn't listed in the v.7 html help file.  Is there an updated html help file I can download, or is there a more comprehensive help site for title formatting?
titleformat_help.html is labeled as 0.7, but it is still valid for all versions up to 0.8.3. %_is_single% is not one of the fields provided by the player; I think it is a global variable defined and used by your Columns UI scripts.
The content is still valid, I must agree, but it hasn't been updated to include new features. $tracknumber() comes to mind, and I think there were one or two other things too.
Wiki
Both %disc% and %discnumber% are mapped to $if3($meta(discnumber),$meta(disc)) in the latest betas. (The actual remapping is done in C++, but it has the same effect.)
Wiki
[a href="index.php?act=findpost&pid=335465"][{POST_SNAPBACK}][/a]
Thank you.  That helps.
Wiki
After linking to your suggestion I couldn't find a thing about formatting syntax associated with Columns UI.  Even clicking to Columns UI site page and then clicking to Columns UI formatting strings thread, there are numerous posts of people formatting their columns with "code."  Where did they find the syntax resource to do so?
OK, albeit I'm stupid, I guess it has to spelled out to me.  Where is the syntax resource?
[a href="index.php?act=findpost&pid=335468"][{POST_SNAPBACK}][/a]
Isn't it:
$if3($meta(discnumber),$meta(disc),$meta(partinset)), because PARTINSET works with %disc% & %discnumber%...
</signature>
No, the titleformatting code does not remap PARTINSET at all. It could be that it is translated to DISCNUMBER by the tag reading functions.
http://wiki.hydrogenaudio.org/index.php?ti...at_Introduction
http://wiki.hydrogenaudio.org/index.php?ti...#General_Guides
[a href="index.php?act=findpost&pid=335601"][{POST_SNAPBACK}][/a]
Cosmo,
Used your links, very helpful, but nowhere, specifically, is the script syntax found "%_is_single%" anywhere.  If someone used this particualr syntax it should be found in the syntax list:
// text
$if(%_is_single%,$if(%_isplaying%,%_tplay%,%_normal%),
$select($min(5,%tracknumber%),
%_album%,%_album%,%_album%,%_album%,%_normal%))|
I cannot find "%_is_single%" anywhere.
I'll have to quote foosion here:
[a href="index.php?act=findpost&pid=335370"][{POST_SNAPBACK}][/a]
[a href="index.php?act=findpost&pid=335701"][{POST_SNAPBACK}][/a]
You miss the point I am making.
You miss the point I am making.[a href="index.php?act=findpost&pid=335715"][{POST_SNAPBACK}][/a]
I don't think so. Try going to prefs > Display > Columns UI > Globals tab. If it is a user-defined global variable, you'll find your definition of %_is_single% there in the form of is_single=blah. Note that this has changed to $set_global()/$get_global() in the columns ui betas for 0.9.
f to c to f to c
[a href="index.php?act=findpost&pid=335720"][{POST_SNAPBACK}][/a]
Silverbolt,
You made the point I was looking for, or asking for, after reading what you described I looked where you specified:
// Singletrack
$if(%singletrack%,is_single=1,
$if($not(%tracknumber%),is_single=1,
$if($strcmp(1,$get(salbum)),$if($not(%album%),is_single=1),
$if($strstr($upper(%_directoryname%),$upper($get(single_indicator))),is_single=1,
$if($strstr(%_directoryname%,'=SINGLES='),is_single=1,
$if($strcmp(1,$get(replaya)),$if($not(%__replaygain_album_gain%),$if(%__replaygain_track_gain%,is_single=1))))))))
After all the previous, (un)helpful, replys to my original question your reply was the only direct "puting my nose to the spot" point.
That was the point I was making, or asking.
Thanks for the help!!!
