Topic: A question about flac (Read 2990 times) previous topic - next topic
Compaired to a 320kbps mp3, how much processing power does it take to decode a flac file compressed at the highest compression setting?
As far as i know the compression level of flac doesn't affect the decoding time.
I tried to test how much faster a flac will be, but my hard disk is too slow.
MP3 has got a decoding speed about 70-80x realtime on my system, and flac above 120x. Flac will be even faster if i would have a better drive.
You can test the decoding speed on your own system by using foobar2000.
Mit freundlichen Grüßen aus Österreich, Matthias
decoding is not affected, but the encoding is real slow
If time factor is not a problem, you can take your time encode with "8"
Decoding time *is* affected. See link above, please..
[a href="index.php?act=findpost&pid=334757"][{POST_SNAPBACK}][/a]
OK, OK... it is affected, but the difference is, for pretty much all purposes, negligible.
