Topic: XMMS and Wavpack (Read 4332 times) previous topic - next topic
XMMS and Wavpack
I installed a fresh copy of Ubuntu Linux and updated it to Breezy.
Now i have the latest packets installed. But no plugins for XMMS-Wavpack.
I downloaded that one from wavpack.com copied it to the plugins folder but it wont be loaded by xmms.
What Im doing wrong?  I saw there is that LAMIP player that supports a lot of formats but i will only stick with it when there is no other choice.
Forum search and google give me not very usefull  advices.
XMMS and Wavpack
I had the same problem under FC4. It would not work from the local plugin directory or the system input directory. Never found a solution.
Edit-spelling
Eric
XMMS and Wavpack
Maybe you guys can contact Kuniklo and ask for guidance? Maybe report whatever errors you might be experiencing...
XMMS and Wavpack
It didn't work using the precompiled binary in local plugin directory?
Anyway WavPack XMMS plugin are very alpha, and it seems Kuniklo haven't developed it for a long time. Anyway, if anybodys competent, source can be found here ( hint, hint  ).
XMMS and Wavpack
i've had it working with debian SID (rarewares) for a while now -
if doesn't work now, then perhaps it is a GCC4 issue.  i'll check when i get home (i'll need to recompile on my dev box at home).
[edit]
btw, LAMIP is pretty amazing - try 0.0.3rc (you'll need to compile from source until i package it for RW/Debian)
it seems about that time to update the RW/Debian packages again...
[edit2]
i've just tried the RW/Debian xmms-wavpack plugin and it seems to playback at warp speed.
i'll take a look at it.
i'm pretty sure that kuniklo is AFK/MIA/etc.
later
XMMS and Wavpack
You should launch xmms from the command line and see what messages you get, if any. Depending on the options used when compiling xmms, you might have to create subdirectories in your ~/.xmms/Plugins dir. On my setup, libwavpack.so is located in ~/.xmms/Plugins/Input/.
Edit: nevermind, putting plugins in ~/.xmms/Plugins/ directly works no matter what.
Also issue the following command in the directory where libwavpack.so is located:
$ ldd libwavpack.so
and see what it says. If you find a line that says "not found" then you're missing a library.
XMMS and Wavpack
(I copied the plugin to my home directory and the original location of xmms for sure)
nin9@biatch64:/home/nin9/# sudo xmms
/usr/lib/xmms/Input/libwavpack.so: cannot open shared object file: No such file or directory
Message: device: default
Sorry I gave up with xmms.
Now I wanted to take a look on Lamip, but I have absolutely no idea how to install/compile it.
Already checked Google and Wiki for some Howto or guides...nothing.
I'm a completely new to Linux.....using it for 3 days now, sorry for my incompetence
but everyone had to start once from the beginning
xmixahlx are you going to package it in the next weeks ?
[edit typos]
