Topic: Infobar ? (Read 1763 times) previous topic - next topic
Infobar ?
Hi ! Sorry for my bad english. I have just one question , and it is about a '' infobar '' .This infobar are just above the Windows Bar ... He have lengh of the song who play , the progress bar, the quality of sound ,the Db , ... ect.
How change the style of this bar ?..  I would like to change the style of the progress bar, and to put more information.
Thanks !
Infobar ?
your "infobar" is called status bar. you can configure it here:
under preferences (foobar2000 menu) find "Display", then "Title formatting"; go inside "Status bar" TAB and make your changes. this is mine (ripped from someone else cfg)
// set colors
$puts(col_paused,0000FF)
$puts(col_streaming,008800)
$puts(col_cue_file,880000)
$puts(col_progbar_symb1,888888)
$puts(col_progbar_symb2,000000)
$puts(col_time_remaining,000000)
$puts(col_bitrate,7E7674)
$puts(col_bitrate2,606060)
$puts(col_stereo,606060)
// set variables
$puts(text_streaming,'Streaming')
$puts(text_listened_for,'Listened for:')
$puts(text_cue_file,'Cue File')
$puts(text_paused,'PAUSED')
$puts(text_time_remaining,[%_time_remaining%])
$puts(spacer_symb,' ')
$puts(spacer_width,2)
$puts(progbar_symb1,'O')
$puts(progbar_symb2,'|')
$puts(progbar_length,30)
$puts(text_bitrate,$get(col_bitrate)$if2($pad(%__bitrate_dynamic%,3)606060'
kbps',$if2(%__bitrate%' kbps',)))
$puts(text_extrainfo,[%__extrainfo%])
// add colors and formatting
$puts(spacer,$repeat($get(spacer_symb),$get(spacer_width)))
$puts(text_streaming,$get(col_streaming)$get(text_streaming))
$puts(text_listened_for,$get(col_streaming)$get(text_listened_for))
$puts(text_cue_file,$get(col_cue_file)$get(text_cue_file))
$puts(text_paused,$get(col_paused)$get(text_paused))
$puts(text_time_remaining,$get(col_time_remaining)$get(text_time_remaining))
$puts(progbar_symb1,$get(col_progbar_symb1)$get(progbar_symb1))
$puts(progbar_symb2,$get(col_progbar_symb2)$get(progbar_symb2))
// streaming
$puts(streaming,
$if(%_time_total%,,
$get(text_streaming)$get(spacer)
// cuefile
$puts(cue_file,
$if(%__cue_audiotype%,
$get(text_cue_file)$get(spacer)
// codec
$if(%__codec%,
$if($stricmp(%__codec%,musepack),$puts(codec,'MPC'),
$if($stricmp(%__codec%,vorbis),$puts(codec,'Ogg'),
$get(spacer) $puts(codec,%__codec%)
//If no codec tag and not streaming, read file extention
$if($and(%_time_total%,$not(%__codec%)),
$puts(codec,$upper($ext(%_path%)))
// bitrate
$puts(bitrate,$get(spacer)$get(text_bitrate))
$if(%__mpc_profile%,
$puts(bitrate,$get(spacer)%__mpc_profile%$get(spacer)$get(text_bitrate))
// extrainfo
$puts(extrainfo,$get(spacer)$get(text_extrainfo))
$if($stricmp(%__codec%,MP3),
$if(%__extrainfo%,,
$puts(extrainfo,$get(spacer)'CBR')
$if(%__mpc_streamversion%,$puts(extrainfo,$get(spacer)'sv'%__mpc_streamversion%))
// samplerate
$puts(samplerate,
$if(%__samplerate%,
$get(spacer)$cut(%__samplerate%,2)'kHz'
// channels
$puts(channels,
$if(%__channels%,
$get(spacer)$ifgreater(%__channels%,2,%__channels%ch,$ifgreater(%__channels%,1,Stereo,Mono))
// mp3 stereo mode
$puts(stereo_mode,
$if2( $get(col_stereo)'['$caps(%__mp3_stereo_mode%)']',)
// Replay Gain
//track gain
$puts(rpg,
$if(%__replaygain_track_gain%,
$get(spacer)
' TGain:'$cut(%__replaygain_track_gain%,5)'dB'
$if(%__replaygain_album_gain%,
$get(spacer)' AGain:'$cut(%__replaygain_album_gain%,5)'dB'
// progress bar
// (checking total because of streaming)
$puts(progress_bar,
$if(%_time_total_seconds%,
$get(spacer)$get(spacer)
$progress2(%_time_elapsed_seconds%,%_time_total_seconds%,$get(progbar_length),$get(progbar_s
ymb1),$get(progbar_symb2))
// progress %
$puts(progress_%,
'808080$pad_right($muldiv(%_time_elapsed_seconds%,100,%_time_total_seconds%),3)808080'%'
// 'Listened for:'
// (used for streaming)
$puts(listened_for,
$if(%_time_total%,,
$get(spacer)$get(spacer)$get(text_listened_for)
// time
$puts(time,
$get(spacer)
' '[%_time_elapsed%]
$if(%_time_total%,
'/'%_time_total%' ' $get(spacer)$get(spacer)$get(spacer)
'Time left: '$get(text_time_remaining)
// paused
$puts(paused,
$if(%_ispaused%,
$get(text_paused)
// create string
$get(streaming)
$get(cue_file)
$get(codec)
$get(bitrate)
$get(extrainfo)
$get(samplerate)
$get(channels)
$get(stereo_mode)
$get(progress_bar)
$get(progress_%)
$get(spacer)$get(listened_for)
$get(time)
$get(spacer)$get(rpg)
//$repeat($char(32),3)
//Right adjust from now on
$char(9)
$get(paused)
you should find hints & examples about statusbar @ http://www.hydrogenaudio.org/forums/index....c=30988&st=1575
any other help will be appreciated, btw.. i'm a noob too
and sorry 4 bad eng
