Topic: LyricsDB discussion (Read 349859 times) previous topic - next topic
LyricsDB discussion
Reply #425
I'm currently unable to export my lyrics to the db: anyone else?
Site seems fine though.
Alessandro
LyricsDB discussion
Reply #426
I can't figure out how to add it as a UI element in foobar 0.9.5. It's not listed in the menu (with album art viewer, album list, etc)
LyricsDB discussion
Reply #427
That's because it's not possible (at the moment?).
LyricsDB discussion
Reply #428
Hi, I really like your component, the database is really huge, that's great.
However, I'm missing a functionnality, because I don't want to store the lyrics in Tags anymore but I would prefer to store directly the .txt in my lyrics folder where my other lyrics are store this way:
Lyrics\%artist% - %title%.txt
Is that possible to have this functionnality in future releases ?
Thanks,
BW
Sorry for the bad english, I'm french .
LyricsDB discussion
Reply #429
That's already possible.
Lyrics Show Panels -> Internet -> Save scheme
Set that to 'Save to My Directory' and define the path. that should do the trick.
LyricsDB discussion
Reply #430
We're not talking about the same component Andu.
- LyricsDB (this topic) has his own database, where you can add your lyrics (non timestamped)
- Lyrics Show Panel  is mostly a lyrics display components, which can also search for some lyrics on the internet, but a lot are missing.
edit:typo
LyricsDB discussion
Reply #431
Sorry I'm an idiot. I totally mixed it up :[
LyricsDB discussion
Reply #432
I've been using this plugin for a long time (since the 0.8 days at least) and have been periodically checking for updates. Today I decided to login, and I saw the todo list:
- add "request lyrics while playing" feature.
- add "save lyrics to a file" feature.
- make both plugin and web-face based on xml for version 0.0.5(done).
- add to the plugin it's own lyrics editor (hotkeyable one) (done).
- find some beta testers (done), thnx to hydrogenaudio forums.
- add some feature for guessing song titles (by dropping non-letters) (done).
- make one evil dinosaur try to write plugin for xmms/lunix.
- make one kind elephant try to write console *nix scripts for requesting lyrics.
I see that you have finished some things on that todo list, and I was wondering if there were any plans for an update soon? Thanks Dug .
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
LyricsDB discussion
Reply #433
I wasn't able to install it in foobar2000 0.9.5.1 - it doesn't show up in components.
Am I alone with this problem?
LyricsDB discussion
Reply #434
Did you take the foo_lyricsdb_007_beta 5  ?
You should have a subpage called LyricsDB in Tools. Is there an error in the console when lauching foobar ?
LyricsDB discussion
Reply #436
LyricsDB discussion
Reply #437
is there a way to view the lyrics in a tabbed panel in columns ui?
LyricsDB discussion
Reply #438
/\  Yes ! it's possible !
______________________________________________________
I'm trying to use de lyrics panel with default UI, but I think I should have the dockable panels, it's correct ? So, where can i download this plugin ?
LyricsDB discussion
Reply #439
Is anyone else having trouble accessing the mirkforce db... ?
LyricsDB discussion
Reply #441
I can't get to display more than 91 lines of lyrics. It's stored in tag but doesn't display. Is it a bug?
LyricsDB discussion
Reply #442
[quote author=Kirara-kun link=msg=563545 date=1210068879]I can't get to display more than 91 lines of lyrics. It's stored in tag but doesn't display. Is it a bug?[/quote]what plugin are you using for displaying? may be, just may be you are using lyrics panel or some? ;)
dezisehtnys eb lliw noitulover eht
LyricsDB discussion
Reply #443
[/quote]
yop, using foo_lyricsdb with foo_uie_lyrics
LyricsDB discussion
Reply #444
[quote author=Kirara-kun link=msg=563552 date=1210070361]yop, using foo_lyricsdb with foo_uie_lyrics[/quote]so you are using foo_lyricsdb for fetching lyrics and foo_uie_lyrics for viewing?
LyricsDB discussion
Reply #445
Yeah. Now who is making fun of who? You can say it straight. I just tried to ask because it was the first topic I found. You simply do/didn't know. Then I can possibly go and ask somewhere else.
BTW in edit window Ctrl+A for select all doesn't work. It's quite annoying. Could it be fixed?
LyricsDB discussion
Reply #446
[quote author=Kirara-kun link=msg=563558 date=1210072401]Yeah. Now who is making fun of who? You can say it straight. I just tried to ask because it was the first topic I found. You simply do/didn't know. Then I can possibly go and ask somewhere else.
BTW in edit window Ctrl+A for select all doesn't work. It's quite annoying. Could it be fixed?[/quote]no offence  I just don't use anything 'side foo_lyricsdb, bay be someone here is aware.
about ctrl+a: yes, that is bloody annoing
LyricsDB discussion
Reply #447
(2do list excerpt: )
Could a Python script be count as one of those?
If so, who should I send it to?
LyricsDB discussion
Reply #448
hey, jaggo
surely can. send it to me i'll place it on the web, if you don't mind.
LyricsDB discussion
Reply #449
Any word on this yet?
