Topic: LyricsDB discussion (Read 355268 times) previous topic - next topic
LyricsDB discussion
Reply #275
Great plugin and lyrics database!!
One questions though: I've played around enough with the plugin itself, now is there any documentation on the web api? I see references to it on the board, but haven't been able to find it.
Perhaps I'm not looking in some obvious location??
-P
LyricsDB discussion
Reply #276
I'm trying to write an application that does some processing on lyrics -- text summarization, keyword spotting, etc. For this reason, I'd like to query the lepserver.cgi script independently or through a web interface and feed that into my system.
Is this possible, or shunned? I tried following the query structure described in the lep page, but passing just the xml as a post to the script returns an error tag. I could always try to figure this out with ethereal, but I'm assuming (hoping) this is public info.
-P
LyricsDB discussion
Reply #277
nice plugin. does teh default database have a decent number of songs? also, i know it probably has nothing to do with the lyrics plugin, but when i display %lyrics% in a track info panel, there is a square at the end of every line. can i get rid of this square or somehow hide it with the same color as the background?
LyricsDB discussion
Reply #278
http://lyrics.mirkforce.net/cgi-bin/stats.cgi?period=1
http://www.hydrogenaudio.org/forums/index....st&p=409728
HTH.
Alessandro
LyricsDB discussion
Reply #279
HTH.
Alessandro
thanks for the quick responce. the string for the EOL char's works nicely, and that is one huge database. i should be able to find most of my music in there.
LyricsDB discussion
Reply #280
-P
You're probably looking for this page: http://lyrics.mirkforce.net/lep.html
LyricsDB discussion
Reply #281
Possible bug:
I was trying to get the lyrics for the album Ulver - Kveldssanger. Trying to retrieve the lyrics for the whole album gave no results, however when selecting only few songs separately the lyrics appeared
LyricsDB discussion
Reply #282
by the way: the database was moved to other hoster, and due some reasons posted lyrics for three or four days (i think 02-05 of august) were lost. Some new users maybe were lost too, sorry for that inconvenience...
dezisehtnys eb lliw noitulover eht
LyricsDB discussion
Reply #283
.. and there is a new website-design!
LyricsDB discussion
Reply #286
Possible bug:
Did the plugin find lyrics for the first song of the ones you selected? Because I have the feeling that, when searching for multiple lyrics, the pluign only finds/applies lyrics when the first song has lyrics. At least that's what's happening to me...
LyricsDB discussion
Reply #287
It seems, that when you try to recieve the lyrics for multiple files and a file with no db-entry is reached, the retrieving process is stopped. I think this bug was introduced when the database was moved (or with v0.07b4)
LyricsDB discussion
Reply #288
It was already in before 0.07b4. This is a realy weird behaviour. The plugin also fails if you tell it to get a huge number of lyrics from the database.
LyricsDB discussion
Reply #289
http://lyrics.mirkforce.net/ doesn't work
server down?
Where i can download foo_lyricsdb.dll now?
What about database - can i still download lyrics?
edit
nvm
LyricsDB discussion
Reply #290
can someone upload lyricsdb for foobar 0.9 for me to download
LyricsDB discussion
Reply #291
The link in the first post works for me.
LyricsDB discussion
Reply #294
try it here. If you get a 'You are not authorized' message, reload the page. That webhosting provider closed down some years ago, but somehow my account is still working...
Thanks I got it to work by browsing to your initial site before adding the /files/foo_lyricsdb_007_beta4.zip
LyricsDB discussion
Reply #295
I am seeing a similar problem.  It will stop searching the database if it comes across a song that is not present.  However, it did also stop searching when it reached a song of mine that is in the database.  It keeps telling me that it isn't there, although a search shows that it is there.  It is Beck's "QuĂ© Onda Guero"....I have it spelled the same way as it is in the database, but it won't allow me to download the lyrics.
LyricsDB discussion
Reply #296
Can s.o. please tell me how show Lyrics from Lyricsdb in the Trackinfo correctly (without the squares at line's ends) ...??
.THNX.
LyricsDB discussion
Reply #298
The FAQ says that one can edit lyrics via the web interface..how do i do that?
I've just submitted some lyrics, but i realized that i submitted the wrong lyrics for the wrong songs....
LyricsDB discussion
Reply #299
login first. And then use "my lyrics" link, for example.
