Topic: Copying Hidden Tracks (Read 3757 times) previous topic - next topic
Apologies if this has been asked, but I'm new to hydrogen audio and haven't been able to find the answer to my question through searching the forums.
I'm using EAC to copy cds to MP3 (just sticking with the alt-preset standard setting at the moment), and am pleased with the results. However, several albums I have include "hidden" tracks appended to the end of the last track on the album. I don't really want to copy & encode 6-7mins of silence so how can I split the track in three to create, say "Track 12", "Filler", "Track 13"? I can then just copy tracks 12 and 13, ignoring the silence in the middle. Do I need something like mp3directcut, or is there an alternative approach I can use?
Guidance would be appreciated.
Thanks,
Michael
You also could edit it in the wav editor and then encode it.
You could use the Copy Range feature of EAC.
[a href="index.php?act=findpost&pid=319762"][{POST_SNAPBACK}][/a]
Cool, thanks    Just started using EAC recently so I'm still getting to grips with all the features.
Michael
I'd use EAC's wav editor for this task. It's a very nice feature - when EAC is open, go to Tools --> Process WAV, and you're in business. The main downside is that each wav editor window is dependent on a parent main EAC window.
When I split a single cd track into multiple mp3 files, I generally give it the following tracknumber convention:
Artist--10_1--Final_Main_Track.mp3
Artist--10_2--hidden_track.mp3
God kills a kitten every time you encode with CBR 320
What I sometime do in this cases is to rip as image+cuesheet uncompressed.
Then I edit the cuesheet and manulay split the last track into 3 tracks (the first part, the silence and the last part). Of course to do that you must know the starting and ending point of the silent part, You can use EAC wave editor to check for those points
Finally I load the cuesheet in foobar2000 and use it to encode to MP3.
Sergio
M-Audio Delta AP + Revox B150 + (JBL 4301B | Sennheiser Amperior | Sennheiser HD598)
because i use my mp3's mainly for playback on my pc, i use a slightly different method.  i rip the cd's as they are, leaving all the tracks intact, but i use foobar2000 for playback, and have the "skip silence" component enabled.  so when i am listening to a track with a long silence, and then a hidden track at the end, foobar2000 will skip the silence, and play the hidden track directly after the main song.  this prevents me from having to tamper with the way the cd was designed by the artist.
a windows-free, linux user since 1/31/06.
There's one time I've tampered with a CD because of this; John Fahey's last. It's got 18 minutes of silence between the second last and the last track, which is just too ridiculous.... The artist was dead by the time the CD was put together, so the CD layout are due to the producers decisions. I left 30 seconds of silence to respect the wish for a pause, but can see no diminution of artistic content from dropping the 17 min and 30 secs. Its a fantastic record BTW, as sensible and spiritual and raw as they come. I cut with some wave editor. Maybe Audacity?
