Topic: Helix fixed-point AAC/Plus decoder Win32 bin (Read 8701 times) previous topic - next topic
As kurtnoise requested, I asked CML to compile this win32 binary.
It can only decode raw AAC/Plus files to wav or PCM.
The cvs contains the whole project, so it's quite easy compared to compiling of Helix mp3 coder.
Thank you guys...  I'll try it asap.
Hi
I downloaded the above  aac_decoder.rar.
With this I am getting an exception while decoding an AAC+ files.
I got error “aacdec.exe has triggered a breakpoint” in this DecodeSectionData() at ASSERT(sfb == maxSFB); in noiseless.c file.
And I got error value-15 ( ERR_AAC_NCHANS_TOO_HIGH) at console output.
Could you please tell me the solution.
See the below attached file, this file is input file for this decorder.
Thank you in advance.
Regards,
Swathi.
That is a 7 year old version of the decoder.  Maybe try compiling a recent version and see if they have fixed it since then?
I already tested the recent version of the AACdecoder. This decoder also gave same exception.
Could you please provide working AAC decoder.
Regards,
swathi.
Hi
I followed below method for decoding a file using helix-aac-decoder.
1. Downloaded the source code from CVS.
  CVS path: cvs -z3
-d:ext:swathijakkam@cvs.helixcommunity.org:/cvsroot/datatype co aac/codec/fixpt/decoder
2. Opened the aacdec.dsw in visual studio 8.0
  File Path: aac->codec->fixpt->decoder->real->projects->visual.
3. I ran the project without any modifications.
Then I got exception while decoding an AAC+ files.
Exception message: "aacdec.exe has triggered a breakpoint".
I got this exception in DecodeSectionData() at ASSERT(sfb == maxSFB); in noiseless.c file.
And I am getting error value-15 ( ERR_AAC_NCHANS_TOO_HIGH) at console output.
Console output is :
0 bytes in 0 Free Blocks.
37072 bytes in 2 Normal Blocks.
0 bytes in 0 CRT Blocks.
0 bytes in 0 Ignore Blocks.
0 bytes in 0 Client Blocks.
Largest number used: 35396 bytes.
Total allocations: 37072 bytes.
Error - -15
Memory leak test:      no leaks
Memory integrity test: okay
FYI, I downloaded live stream of a radio station on Shoutcast to a file which is in AAC+ format.
I used this file to decode. While decoding I got the exception.
But I can able to decoded AAC file after converting that AAC+ file to AAC.
Best Regards,
Swathi.
